Have a 30 day old haier lcd dvd combo. the dvd player does not play any dvd's i tried 10 different ones. I turned off the parental lock what else can I try?
  • 10,594 Answers
What do you see as an error message when DVD Player refuses to play dvd? Is it NO DISC or CAN NOT PLAY message or some region code mismatch message? Was it playing DVDs before properly?
If player says, can not play or no disc then its problem of optical lens that sled mechanism got stuck and does not move.
I hope this unit would be under warranty so best option is to ask warranty cover and do not take off top cover of unit as that will void warranty.
Thanks.
Posted on Jun 17, 2009
Zenith XBR716 DVD Recorder / VCR Combo parental bypass
I don't know if this will work but try entering four 0 (zeros) first. If it doesn't work enter as many 0 (zeros) that you can and see if that works. Hope this helps :)
Apr 20, 2014 | Zenith XBR716 DVD Recorder / VCR Combo
Parental controls
try giving the reset ...........
Jun 29, 2008 | Sansui DTV2760 27" TV
Dvd on tv/dvd combo doesn't work on fairly new haier tv
Dvd players don,t use (Heads) They have a (Lazer) Eye, The tray was probally Knocked out of (Alighnment) End needs to be Adjusted.Or with Haier from my expierance with there stuff,Its like a (Disspossiblle) Liter or (Flashlight) Once they Quit working fire it, The drive motors in there (DVD) Players don,t last to long.,I have seen some only a month old where the drive motor burnt out on them.
Oct 02, 2012 | Haier HLC15R 15 in. LCD TV TV/DVD Combo
I have a Haier HLC19K1 19" tv/ DVD combo that
If you have tried more than one commercial DVD and are getting the same results then the problem is the player has failed. Actually what happens is the heads go out of alignment and it doesn't have the accuracy to read the tracks any more. This is a typical failure of dvd players in desktop and laptop computers and standalone players. While the heads can be aligned it isn;t worth doing. It was when a dvd or cd player was $1500 but not now.
Unfortunately the only cost effective fixes are replacing the dvd drive or replacing the entire unit. The replacement dvd would cost more than a new replacement tv/dvd combo. So you can buy a new tv or buy an external player ($40ish).
Feb 02, 2011 | Haier HLC19K1 19 in. LCD TV
MY CHILD OF 3 YRS OLD ACCIDENTALLY PUT PARENTAL CONTROL ON MY DVD/VHS COMBO IS THERE ANY WAY TO UNLOCK IT
By parental control I don't know if you mean child lock. If that's the case you should be able to turn it off by pressing child lock on the remote control until off shows in the display window.
Aug 07, 2010 | GoVideo DV1140 DVD Player / VCR Combo
Need the code for parental control.
I found the default password for the RCA DVD/TV combo player - if your model is 20F510TD - the default password is 8888. Hope this helps!
Dec 21, 2008 | RCA 20F510TD 20 in. TV/DVD Combo
Vchip was accidentaly set by guest and password was forgotten
For Panasonic:
Parental Lock Feature
Combo's, Screen will say VCR Lock Activated.
During stop or power off, hold the stop/eject button on the unit for at least seven seconds.
Combo's, Another method
With unit on and no cassette inside, hold the rec/time button on the front of unit for 7 seconds.
CTV's Lock Mode
Only the on/off button will work,the others have no effect. Press the action and power buttons at the same time on the front of the set for 10 seconds or so.
LCD TV's, Lock Mode
If customer forgot Parental Lock Code, unit must be re-initialized.
Press and hold the Volume down button on the front panel, press the OK button on the remote for 5 seconds.
DVD's Lock Mode
Setting Method
The sales demonstration lock function is set by simultaneously pressing the "POWER" button of DVD Player on the remote control unit and the "STOP" button on the main unit. ("LOCKED" is displayed when the lock function is engaged.)
Release Method
The function can be released using the same procedure as for setting. If the remote control unit is not at hand, the function can be released by using the same method as for player initialization (pressing the "PAUSE," "SKIP/SEARCH<<"and "OPEN/CLOSE" buttons simultaneously).
VHS-DVD Recorder (DMR-ES40V), Forgotten Ratings Password
From the Owners manual: Open tray, Keep Pressing Rec and Play/X 1.3 buttons on the remote for 5 or more seconds.
Another servicer found resetting to defaults worked well.
(VCR>DVD Dub) + (Open/Close) + (DVD Rec)
Bill
Apr 01, 2008 | Panasonic CT-27E13 27" TV
How do you reset the parental control code?
Called Zenith.  They said: turn on the DVD player.  Hit "set-up". Scroll down to the "lock" icon.  Scroll over to "Rating". Scroll over to unlock.  Enter 0000.  Click on Ok.  Enter 0000 again, click Ok again.  Menu should read unlock.  Voila!
Aug 24, 2007 | Zenith DVB412 DVD Player
Haier TV/DVD Combo will not accept the DVD.
The player has failed, they are not repaired just replaced.
Mar 25, 2017 | Haier DVD100 DVD Player
DVD won't play on any disk.
How old is your dvd and how long is this problem going on?once you can answer thequestion i wil be able to give you advice.send your answer to nicodhem@yahoo.com goodluck.
Mar 19, 2007 | Sylvania SRCD227 27 in. TV/DVD Combo
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
