Question about Epson Stylus C88 InkJet Photo Printer
Need to clean print head. some lines are blurred
When printing a document some lines are clear but the next line may be blurred and unreadable. I am using my reliable HP Epson C88+.
  • 23 Answers
The following solution is under the assumption you have installed the complete software via the supplied CD with your Epson Printer.
Windows:
Right-click the printer icon on your taskbar (in the lower right corner of your screen).
Select Head Cleaning.
Note:
If you don’t see the icon, go to your printer properties window and click the Maintenance tab, then select Head Cleaning.
The link to your Printer Documentation / Drivers:
www.epson.com
Select Drivers & Support
Posted on Jun 17, 2009
How do I get my Canon Pixma ip7220 printer to stop printing blurred lines?
Hello, my name is Steve.
This is an early sign of print head failure.
Soon it will give you an error code on display or ill be observed on your computer. The print head nozzles are not firing correctly. The only way to remedy this is to:
1. Have the printer serviced and cleaned ( the cost of the new print head and a cleaning and servicing of the printer
2. Order the print head online and install it yourself. The wonders of the internet can find an give you a video of how to do this.
The part number is: Canon QY6-0082-000 Printhead (Canon QY60082000 Printhead) I hope this helps, Steve
Jul 29, 2015 | Canon PIXMA iP7220 Premium Wireless Inkjet...
Epson Stylus CX4800 prints blurred pictures
ok..first you will need to print the nozzle check and see if all the color are printed out fine.. this feature is under the printer properties , under the utility tab.... assuming all your colors nozzle are printed fine..then the next thing for you to do is do the Print Head Alignment.. it's under the same place where you print the nozzle check.. when you press the Print Head Alignment, it will print a page out with many lines.. choose the one with the best alignment.. once u done that..try printing the image again..
oh..if your nozzle check print out is not good.. then you will need to perform head cleaning to clear the clogged head..
May 24, 2010 | Epson STYLUS CX3900 All-In-One InkJet...
Not printing clearly some lines are blurred
You should run a nozzle check to verify if the heads are printing all the inks correctly. If the pattern is incomplete you need to run head cleanings.
Apr 29, 2010 | Epson CX3810 Stylus Color All-In-One...
Theres something wrong in printing .. the printed paper have lines
Hi, printed lines? the waste is probably full. therefore causing ink to spill on the printed document.
Jan 26, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Printer output has shadows, blurring, streaks, lines, poor color
Seem like blocked hole(s) on the color print head...
Most likely if there is a deep clean option then do it (may need a few times to unblock a hole or never).
Also get the printer physically cleaned up if you can see dusts inside (vrtical lines on color bars).
Mar 20, 2009 | HP DeskJet 9800 InkJet Printer
Double Blurry Print
Usually hairs sticking to the underside of the print head causes this.
I gave a solution to an Epson CX6400 user who needed to physically clean his print head. Look this up in the solutions. It involves using folded kitchen roll under the print head with the printer switched off and the head unlocked and free floating.
It would take me ages to type this again so please look this up.
The user had jammed paper and cleared the jam but had paper stuch to the underside of his print head.
I hope this helps.
Nigel
The INK Store
http://www.the-inkstore.co.uk
Jan 17, 2009 | HP PSC 1210 All-In-One InkJet Printer
Printin Problem
Call Kodak for a new printhead. The printheads go bad.
Dec 20, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Blurred printing printer i255
Hi, check the nozzle and test , if the result not in solid color there are spaces within the color means need head cleaning after head cleaning twice test print .
Jan 23, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Print result at 1st line ok..2nd line become blur..its alternate till end of printing
Replace the ink cartridge.
The cartridge is so wide that it can print 2 lines at a time, and the upper part of it is probably partially clogged. That's why every 2'nd line is blurred, and the rest is ok.
Jan 17, 2008 | Office Equipment & Supplies
Epson Stylus C88 InkJet Photo Printer Logo
375 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
