Question about Canon PIXMA MP830 All-In-One InkJet Printer
5110 ERROR ON PIXMA PRO 9000 - Canon PIXMA MP830 All-In-One InkJet Printer
  • 33 Answers
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Solution: Removing paper jams MP800R / MP830 / MP530
Removing Obstructions or Jammed Paper If [Paper output slot - The paper is jammed. Clear the paper and press OK] appears on the LCD, follow this procedure to clear the paper jam Clearing paper jams from the auto sheet feeder (ASF) or paper output slot
Clearing paper jams inside the printer
Clearing credit card-sized or 4" x 6" paper jammed inside the printer
ASF / Paper Output Slot
  1. Turn off the printer.
  2. Remove paper from the ASF.
  3. Gently pull the jammed paper out.
  1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
  2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
  1. If the paper tears and a piece of that remains inside the printer, open the scanning unit (printer cover) and remove the paper from inside the printer.
    Note: Be careful not to touch the components inside the printer.
  2. Turn on the printer and confirm that the Alarm light is off.
    (If the jammed paper remains in the printer, the paper may be automatically ejected.)
  3. Load paper back into the ASF.
  4. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Paper jams inside the printer
  1. Turn off the printer and disconnect the power cord and USB cable.
  2. Remove the jammed paper slowly using the following procedure.
  3. Open the rear cover to check if the paper is jammed.
  4. Pull out the cassette and check if the paper is jammed inside the cassette area.
  5. Stand the printer with the rear side down, holding the document cover.
  6. Press the tabs together and pull the green cover toward you.
  7. Check if the paper is jammed.
    (If you were not doing Duplex printing, you do not have to follow this procedure.)
  8. Close the green cover and place the printer back to a normal position.
  9. Reconnect the power cord and power on the printer. Confirm the Alarm light is off.
  10. Load paper back into the ASF or cassette.
  11. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Clearing credit card-sized paper jammed inside the printer
Credit card-sized and 4" x 6" sized paper must be loaded properly. If this media is not loaded properly, it will feed into the printer and will not exit. Credit card-sized paper should only be loaded in the ASF and in portrait orientation. 4" x 6" sized paper can be loaded in the ASF or cassette. But must be loaded portrait orientation.
If credit card-sized paper was loaded in landscape orientation in the ASF and did not eject (exit), please follow this procedure.
  2. Load the same paper type that is jammed inside the printer in portrait orientation.
  3. Power on the printer.
    The paper stock in the ASF will automatically feed the jammed paper from the printer.
  4. To resume printing, load the paper in portrait orientation.
If 4" x 6" sized paper was loaded in landscape orientation in the cassette and did not eject (exit), please follow this procedure.
  2. Open the rear cover.
  3. Fold in four a piece of letter-sized plain paper.
  4. Push in the folded paper until it hits the jammed paper.
  5. If the jammed paper is visible from inside the printer area, pull it out and proceed to step 7.
  6. If the jammed paper cannot be pulled out, push in the folder paper from the rear so the jammed paper is in between the feed rollers.
  7. Pull out the folded paper and close the rear cover.
  8. Power on the printer and confirm that the Alarm light is off.
    The jammed paper should automatically eject.
  9. To resume printing, load the paper in portrait orientation.
Thanks
Thiru
Posted on Jun 17, 2009
Error code 5110
5110 Carriage lift mechanism error
Feb 02, 2014 | Canon Pixma iP6600D InkJet Photo Printer
Canon pixma MarkII pro 9000 has an error 5C00 or purge error?
That is probably some paper or a foreign object inside the machine. Check around the waste station and at the far end of the printhead travel in both directions. Remove any found foreign objects and restart the printer. If there is nothing there to find - it is probable that the is a mis-alignment of the gear train that selects the various functions of cleaning, paper feed, and waste purging. In that case, there is not a lot you can do short of a complete strip down and rebuild with no guarantee of succes.
Jan 30, 2014 | Canon Pixma Pro 9000 MARK II InkJet Photo...
No paper jam but error 5110 won't go away
Have you tried unplugging the machine, this might reset it.
Mar 14, 2013 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma 9000 pro flash 14 times
Hello, this is what your error means: Ink tank not recognized [1684]
A non-supported ink tank is installed (the ink tank LED is turned off). Install the supported ink tanks, check that the chips on the cartridges are clean.
Oct 07, 2012 | Canon Uv Ink Refillable Cartridges For...
What is error code 5110 mean?
According to the manual, error 5110 means "Carriage lift mechanism error".
It's usually related to cartridges, particularly if they not inserted correctly, but can also be caused by other mechanical failures.
Apr 05, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Canon Pixma MP810 Error messages 6A00, 5110, 5C20, 5100
Pixma pro 9000
service error 5110 after paper jam.
BEST QUICKEST WAY TO FIX THE PROBLEM!!!!
DUST BLOWER ALL OVER THE AREA INSIDE
AND TURN IT BACK ON U SHOULD HAVE SOLID
GREEN LIGHT FOR SURE!!!!!!!!
DAMN I CAN'T BELIEVE I BROUGHT THIS SAME PROBLEM
TO SERVICE CENTER THE FIRST TIME!!!
NO MORE WORRIES!!!
Oct 25, 2008 | Canon PIXMA iP5300 InkJet Photo Printer
Error code 5110 Canon Pixma MP500
Error 5110 = Kann den Schlitten nicht anheben. (mechanischer Fehler)
Sep 28, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma MP600r - error code 5110
5110 ERREOR is carraige cant life. this can be down to a few things, carriage is stuck on the purge unit or the logic board is at fault. best to take it to a Canon dealer for repair or contact a supporter dealer who can do a chargeable call for you. in the uk i have few contacts . hope this helps
Dec 23, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
510 people viewed this question
old marine
old marine
