Hayward 100,000 Btu Heater For Ag Pool And Spa H100id1
Problem for Hayward 100,000 Btu Heater For Ag Pool And Spa H100id1
Hayward model H100ID1 pool heater
By markt4 on Jun 17, 2009
I open the pool this yr and the heater makes a nocking nosie runs for about 2 min then starts nockingI have 30lb of propane left from last yr. do In need to fill the tank with new propane or dose the burner need to be cleaned?? Please help
Thanks Mark
Comments:
Jun 18, 2009
- Hi John224
i pulled the hose's off and check the diverter it seems to be atatched to a tube on the inlet side. but dose move a little bit it not welded tight.
Jun 19, 2009
- John224
Hi John the heat exchanger was new last yr. could it be the combustion blower not venting fast enough ?? it making a squeaking noise.
Jun 21, 2009
- Hi John224
I took the heater apart and had it arc welded work's great now
Thanks for your help
Solution #1
posted on Jun 18, 2009
Somewhat Helpful)
john224
Rank: Guru
Rating: 92%, 140 votes
The diverter inside your manifold is likely broken. You should stop using the heater immediately as the nocking is from water starting to boil in your heat exchanger. This can lead to a dangerous situation if a limit switch does not act in time.
Pull the inlet hose from the heater and you should see a plate just inside. If you can move it around it is broken and the fix is a new exchanger assembly.
You can fin these online and we sell them at www.arrowmotor.net
Comments:
Jun 18, 2009
- When I have spoken to my Hayward rep in the past he stated there is no repair for that and they should not move at all. When they start flopping around you get intermittent flow in the heat exchanger that leads to the problem you are describing.
The part number for the exchanger is IDXHXA1101. We sell it for $368 but you could likely find it on-line elsewhere for less. If the unit is only a year or two old, contact me through www.arrowmotor.net for instructions on how to approach Hayward about a replacement. You will need a receipt showing it is that new for relief on the part pricing.
Jun 19, 2009
- No. The combustion fan can sound like it is full or gravel and sqeaul as the bearings fail and as it does, it will cause a pressure switch to open the safety circuit, shutting off the heater. Nocking, bankging, popping; anything you would classify as a loud noise like popcorn popping is the boiling of water in the exchanger. In the 100, that often means the diverter.
I sent an email to my regional rep asking for him to confirm. I'll post his reponse. In the mean time, what is your pH level and what method do you use to check it?
Was this helpful?
Yes
No
Solution #2
posted on Jun 28, 2009
Not Rated)
E_Mig
Rank: Apprentice
Rating: 0%, 0 votes
[/quote] Jun 18, 2009- Hi John224
Jun 19, 2009- John224
Jun 21, 2009- Hi John224
I took the heater apart and had it arc welded work's great now. [/end-quote] what did you arc weld to?? or did you just keep it from moving it up down the tube?? i am wondering if can be just kept from moving by other means (instead of welding). anyway; i have the same nonsense going on and really dont see why i should have to pay $350+ if its not under warranty. Seems like Hayward has designed a defective part. And i dont see how it could be dangerous it is if the limit switch shuts it off anyway.......
Was this helpful?
Yes
No
Popular Solutions for Hayward 100,000 Btu Heater For
Questions and Unsolved Problems for Hayward 100,000 Btu Heater For
Do you recommend Hayward 100,000 Btu Heater For Ag Pool And Spa H100id1?
Answer
Answer
I have a sta rite max e 400 btu gas pool heater. When I turn it on, the read out vaciliates between... (More)
Answer
Sunbeam SLP3310-UM shuts off after 2 minutes. I unplug it and hear a relay clicking after a couple... (More)
Answer
I have a Hayward H30 series heater bthat will fire up the units gets hot but will not heat the... (More)
Answer
I have the exact same problem, no spark at all. Hayward tech support no that much help. Just got it... (More)
Answer
Brand New H100ID1 runs and exhaust gas is blowing and is nice and hot but the water does not warm... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hayward 100,000 Btu Heater For...:
Top Pool and Spa Heater Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Pool and Spa Heater Experts
Top Garden & Power Tool Repair
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
