Question about Intex Easy Set 2500 Gph Filter Swimming Pool Pump
Leaky pump Water leaks out the bottom of the pump, even when it's turned off!
  • 121 Answers
There are rubber gaskets inside that get old and need to be replaced. Thats probably why it's leaking........Thank You For Using FixYa.Com! : )
Posted on Jun 17, 2009
I just installed a us pool pump motor eb841 1hp 3450rpm 208volt 56y and it is leaking water behind the square bell housing actually leaking bottom side of motor
There is a leaky water seal on the pump shaft housing between the pump and the motor.
The drain hole prevents water from going into the motor and this seal needs to be replaced before the motor is damaged.
Aug 19, 2012 | A O Smith Motors A O Smith 1hp 115/230v Ur...
How can i tell if i have a bad waterpump on 96 dodge dakota
Turn the engine off, and climb underneath. Examine the bottom side of the water pump, looking for a green or white deposit that might show where coolant has been leaking. Sometimes it's difficult to get access to the bottom of the water pump, but if you see a streak that looks like dried coolant, and it goes under the pulley, you have a faulty/leaky water pump.
Feb 19, 2011 | 1996 Dodge Dakota
Water leaking under machine
More than likely you have a cracked water pump.
Apr 08, 2010 | Whirlpool LSN1000LW Top Load Washer
No water comes out of dishwasher when I turn it on. It is a Kitchenaid and about 4 years old. I hear something trying to turn on, but no water in the washer itself.
The anti flood system could be activated (shuts water off and puts the washer in pump out mode only). This device triggers when water leaks to the bottom of the washer due to 1)Leaky pipe 2) Blocked pipe 3) Customer spillage. The device is a small polystireene plate coupled to a micro switch. The polystireene lifts when in contact with water and activates the switch.
Dry the water and rectify the leak and this should solve the problem.
Jan 19, 2010 | Dishwashers
Leaky bottom freezer on my kenmore elite refrigerator
defrost drain is clogged. defrost drain water is over flowing into bottom. take back panel off. remove ice to find drain hole. use very hot water and turkey baster to wash out till clear.
Jul 25, 2009 | Kenmore Refrigerators
Antifreeze leak
Ok, Its defiantly the seal that is between the water pump and the engine block that is leaking the coolant.
Apr 08, 2009 | 1993 Honda Accord
Leaky machine
check the pump and your hoses
Mar 31, 2008 | Washing Machines
Washer leaking water on floor
Need to check drain pump and its hose connections. If its not from the drum seal then that's usually where the leaks occur.
Mar 30, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Intex Easy Set 2500 Gph Filter Swimming Pool Pump Logo
317 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
