Question about Dell 926 All-In-One InkJet Printer
Dell 926 won't recognize new color cartridge
Dell 926 won't recognize the new (Dell) color cartridge... error message says "insert new color cartridge." Won't print color. New black cartridge prints fine, no problem. Already cleaned the heads. This is the THIRD new color cartridge we've tried in as many weeks.
  • 42 Answers
Try this...shut down the printer. Insert new cartridge, let the printer cycle out with new cartridge. then reboot the computer. This should solve the problem. The cache in the printer will not cycle out. It wants to see the printer as a new entity
Posted on Jun 17, 2009
THINKS IT NEEDS An ink CARTRIDGE
probably needs to be an OEM dell cartridge . they have put chips in them now so we consumers have to spend more for them
Oct 10, 2017 | Dell 926 All-In-One InkJet Printer
Dell 926 printer only prints in black and white. I recieved a message a week ago stating that my Color cartridge was empty and I needed to replace it in order to work. SINCE WHEN? never had that problem...
Make sure the cartridge is fully seated and the lock is engaged, then go to printer tools, maintenance run the head cleaner 10 times see if that resolves
Aug 20, 2011 | Dell 926 All-In-One InkJet Printer
My Dad bought new ink cartridges ( black and color) and installed them in the printer and it is not registering that they are installed. What are some things I should check for and how can I fix this????
After installing new ink cartridges in your Dell all-in-one 926 printer, you may receive an error message telling you the print does not recognize the new cartridges. Refilled or third-party cartridges, which Dell does not recommend using with the 926, often trigger the error message. You may also receive this error after you have been using the same ink cartridges for some time. Whether the cartridges are new or not, the error can be caused by a number of sources. Following the steps below should clear up print cartridge problem.
  • 1
    Open the Dell 926's front cover with the power on and wait for the cartridge carriage to come to a stop. Remove the ink cartridges by pressing on the tabs at the top of each cartridge. Check the cartridges to make sure you have removed all of the blue protective plastic film. Look for the "Dell" logo stamped into the cartridges' lids to ensure they are genuine cartridges.
  • 2
    Clean the shiny metal portions of the ink cartridges with a damp microfiber cloth. Allow each cartridge to dry completely.
  • 3
    Clean out any paper, staples or other debris that you may be able to see, then reinsert the cartridges into their appropriate slots. Put the black ink cartridge into the left slot and the color cartridge into the right slot. Make sure both click back into place.
  • 4
    Close the Dell 926's front cover and turn off the printer. Unplug the power cord and USB cable from the printer for five seconds, then reconnect them.
  • If your Dell 926 fails to recognize the print cartridges after following the above instructions,
    take it to a repair shop for servicing.
    Good Luck and Happy Printing
    Jan 26, 2011 | Dell 926 All-In-One InkJet Printer
    DELL PHOTO 926- ALL IN ONE- ERROR CODE- "UNSUPPORTED INK CARTRIDGE" HOW TO FIX THIS?
    Follow the below instructions
    1. Lift the printer unit up. Position the scanner support beam between the tabs to hold the printer unit lid open. The ink cartridge carrier moves to the loading position in the center of the printer.
    2. Press down on the lever in front of the right and left ink cartridges lid. The lid opens and raises up.
    3. Remove the color and black ink cartridges from the carrier. Inspect the cartridges to ensure that it is compatible with the Dell 926 printer. The proper cartridge is called Dell 926 Standard Capacity Color Ink and Dell Standard Capacity Black Ink.
    4. Examine the cartridges for any tape over the ink nozzle. New cartridges have a strip of tape covering the bottom of the cartridge that must be removed before installing into the printer.
    5. Insert the cartridges into the carrier so the label is on top with the color logo side going in first. Press the lid down to snap it into place.
    6. Push the scanner support bar back to release it. Lower the printer unit until it is closed.
    7. Turn the printer off. Restart the computer. Turn the printer on. If the error message appears again, the cartridges may be defective and needs to be replaced.
    I hope this clears up your problem.
    Good Luck and Have a Nice Day!!
    Jan 25, 2011 | Dell 926 All-In-One InkJet Printer
    Error 1203 for Dell Printer AIO 926
    Ok Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
    1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
    or
    2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
    Jan 17, 2010 | Dell 926 All-In-One InkJet Printer
    All in one 926 cartridge problem
    maybe you need to make sure it is set for color, click start then control panel then printers ,right click on dell photo ,click printing preferences, unclick printing in black and white , i hope this helps
    Jul 22, 2009 | Dell 926 All-In-One InkJet Printer
    Dell Printer 926 cartridge error
    I had the same prob..... I fixed it I took a clean soft rag sprayed Windex on it wiped off the ic type board on the front of the cartridge and also the board on the inside that the cartridge rest up against,,, turned it off and on put a copy under the scanner and kaabam it printed a month of pulling my hair out it works
    Aug 31, 2008 | Dell 962 Photo All-In-One InkJet Printer
    Dell 926 All-In-One InkJet Printer Logo
    669 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
