SOURCE: My I Mac doesn't recognize the WD 500GB external drive anymore
it must be initialised /mounted 1st for osx
SOURCE: Computer will not locate external hard drive
Right click on your "my computer" icon in XP, or the word "Computer" on Vista/7, go to manage. On the window that opens up go to storage>disk management. Is it showing up in that list?
If you are using a Mac, go to your utilities folder and run system profiler. Does your drive show up under the usb devices tree?
If its linux, which distro are you using?
Does the drive work on any other computer? If not, I would suspect a bad drive, or a bad enclosure, or just an un-initialized drive, which can be fixed in windows by right clicking on the drive in that list and clicking intialize. In mac run the Disk Utility from the utilities folder and click the drive and select format.
In the future, pls specify your OS. thanks!
SOURCE: need to find the pin setting for a wd 1200bevs
If you are talking about the jumpers on the back, here is a picture of the settings...
SOURCE: Sony Vaio laptop could not access 1TB external hard drive
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this data recovery program to recover your files.
http://www.asoftech.com/adr/
