Question about Nintendo Super NES Console
Just bought a super nintendo but doesnt have tv cable. used 1 from my nes as is the same but doesnt work. tried my nes with cable and now that doesnt work!! what could the problem be?
    Problem Solver:
  • 6 Answers
U R AN IDIOT!!!! GO BUY THE CABLE ON EBAY!!!! ITS PROBABLY LIKE $4
Posted on Jun 19, 2009
TV flickers when playing a Super NES
either the optics cable that you are using or the optics port on the NES is faulty.. try finding a new cabkle on ebay
Dec 05, 2012 | Nintendo Super NES Console
Snes red horizontal lines
When hooking a super Nintendo or an NES system or a sega genesis system to a digital tv you need av cables for it to work then instead of using an rf switch
Sep 30, 2012 | Nintendo Super NES Console
I have two super nintendos and they did work but now there is no power when i turn it on.. ow do i resolve this problem, or do i have to find another one ? Thank you, Joseph
If you have two super nintendos and you use the same cable for power, its possibly the cable's fault. Try getting another cable first. And if that doesnt work i think you'll have to find another SNES
May 03, 2011 | Nintendo Super NES Console
I bought a ac adaptor to my super nintendo, because the adaptor that I'd is a fuckin' fail, so when I bought a new super nintendo adaptor, but I can't see anything on my tv. The conexion is ok. What's up!?
Note: pictured above is the redesigned Super NES. The original Super NES uses the same hookup steps listed below.
Installation Steps:
Locate the Audio/Video inputs on the back of the TV.
Place the yellow end of the Stereo AV cable into the Video "in" on the back of the TV. Connect the red end of the cable to Audio "in" Right. Connect the white end of the cable to the Audio "in" Left. Use a slight twisting motion when inserting each cable and ensure the cables are firmly pressed into the input.
Note: If you have a mono television with only one Audio input, click here for a diagram of how the hook-up will look. The Y-adapter pictured is optional; you can also simply leave the white cable disconnected instead.
Connect the rectangular (gray) plug of the Stereo AV cable into the "multi out" connector on the back of the Control Deck.
After the system is connected to the TV:
Insert the Game Pak firmly into the Control Deck.
Plug the Controller(s) into the front of the system. Use the far left port for player one.
Plug the AC Adapter into the back of the system . Plug the other end into a wall outlet.
Slide the Power Switch on (toward Game Pak).
Turn on the TV and locate the input select. It is often called: input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game.
The game image should now be displayed on the screen. You are ready to play!
If after following these directions you are not able to view the game, try our Troubleshooting Tips.
Oct 10, 2010 | Nintendo Super NES Console
How do i get my nintendo nes to work through a bush freeview lcd flat sreen tv i have connected it up correctly
Use the RCA AVI outlets on the side of the NES and not the RFI (cable) outlet on the rear of the unit. Tune your TV to the appropriate Video Input channel.
If still no signal, try another set of AVI cables.
Try the console on another television.
If no output from the NES, then it will require refurbishment. Click here for more information.
Please let me know how I may assist further.
Apr 21, 2010 | Nintendo Super NES Console
My Super Nintendo turns on but doesnt show anything. I think maybe its the AV Cables. The red light on the RF Modulator doesnt turn on. But when i use my PS2 it works fine. Is my SNES the problem? The AV...
It is the SNES it has the same issues that the NES had simply turn off the machine remove and put back the cartridge and turn on. some times you will have to press the restart button a half a dozen times.
Jan 22, 2010 | Nintendo Super NES Console
Super nintendo turns on but not picture or sound
if you've tried 2 other super nes' and still no picture and sound.. don't you think it's the "yellow,red,white" cables that might be an issue? doesn't sound like a power cord is the issue at all if it's getting power to the "red light".... get a new y,r,w cable (sry.. tired and forget the name)
Sep 25, 2009 | Nintendo Video Game Consoles & Games
Hi i just bought a super nes system it came with RF switch power unit which i have connected to the appropriate connections, i have an LG TV with an golden eye and don't seem to be able to tune the...
Make sure everything's connected in the correct sockets. Turn the SNES on, change to one of the Analogue channels (one of the channels which you control with the TV remote) and start scanning for a signal. The RF cable has to be connected to the analogue port (where a TV aerial would plug in to get analogue channels) and the SNES needs to be switched on.
The alternative is to get a SCART-compatible cable that works with a Gamecube or an N64 and use it with the SNES, as Nintendo had the foresight to add an EXT port which'll let you play the SNES on an AV channel.
Jul 09, 2009 | Nintendo Super NES Console
Snes screen jumps on certain tv
Okay, what I would try is hooking up the snes using the n64 cable. right next to the rf slot in the back of the super nintendo is a slot thats the same video output as the n64 you can plug in the rca cables from it and see if they work
Feb 27, 2009 | Nintendo Super NES Console
Super Nintendo
I'll just tell you how to set it up with an RF cable.
1: Plug the power adapter in an outlet and plug the other side in the designated spot where it fits. Simple.
2: On the back of the SNES, there should be a switch that says channel 3 or 4. Whatever one the switch is at, it will be the channel to play it at.
3: From where it says "NES CONTROL DECK" on the RF switch, plug that into the SNES.
4: From where it says "TV" on the RF switch, screw it into the supplied ports on the TV. Note that newer TV's don't have this port.
You probably don't need to bother with the antenna port.
Enjoy the SNES! :)
Nov 10, 2007 | Nintendo Super NES Console
Nintendo Super NES Console Logo
200 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
