Question about E-Machines M5310 PC Notebook
I have a emachine and i turn the machine on it powers up but the monitor wont go on, i have no clue whether the motherboard is gone i am hoping not and this happened exacctly 1day after the warrenty ran out,
  • 42 Answers
Go to the computer right on computer, click on properties, go to hardware, go to device manager, go to display, click on display, and delete, close out of all then reboot your computer, it should automatically see this problem and prompt for the correct driver(s), it may ask you for your OS disk.
If you cannot get it right. go to someone else's machine and go to www.driversguide.com, sign up and get the correct dirvers. then go back to the computer, it will prompt you for a driver. If you put the driver on a usb stick select the drive (say for example G) then click on the driver in the usb stick, this should work.
Posted on Jun 17, 2009
My laptop will turn on but the screen wont lite up
The display fiber is lose or the leds brew, or a failed motherboard.
Oct 05, 2014 | eMachines E Machines E627 Laptop Computers
Monitor wont turn on
Power supply failure. Inside the monitor Power section. Simple work for a technician
Dec 12, 2012 | eMachines Emachine T6212 Power Supply...
Emachines 5210 wont start up - monitor goes to power saving mode - no beeps but all fans & mobo powere active
Sounds like you have some type of hardware failure. If you are comfortable taking apart the system, start by removing the memory. If this system beeps then you know that your motherboard is still OK. But right now I am thinking that you may have a faulty motherboard.
Jul 06, 2011 | E-Machines eMachines Desktop PC
Power suply the computer wont turn on
the smos of the comp might have gone bad
Feb 07, 2010 | E-Machines eMachines Desktop PC
Emachines monitor model le1987 screen goes blank after monitor is turned on
Need to verify whether its a monitor issue or a computer issue. Get a known working monitor and hook it up to the computer. If you get video then you know for sure the original monitor is bad.
If you still don't get video then you know its going to be either a problem with the video card or the computer.
Nov 30, 2009 | E-Machines eMachines Monitor E15T4
I have a Emachines w4682 and the monitor was showing no signal when I turned computer on. I hooked up a different monitor and that one worked so I re connected the original monitor and it worked I then got...
Possible reasons are bad power switch, bad power supply, bad motherboard, bad memory , device card is not seated properly. Suggest replace power cord to see if still no power, also you may want to remove cover and make sure all your memory and device cards are seated corrrectly. If you get a amber light at the power button, bad motherboard is likely cause
Mar 24, 2009 | E-Machines eMachines Desktop PC
Pc powers up but nothing on the monitor
I have run into this a few times and it has turned out to be a bad motherboard.Also the power supply they put in the emachine is not very good.The power supply in them has caused the motherboard to blow.Im not saying it is your motherboard, that is just a good possibility.Goodluck
Sep 22, 2008 | E-Machines eMachines Desktop PC
Emachines t2865
Most Monitors. Have A Seperate Power Cord.
They vary in shape and size. 2 pin 3pin et,c.
Have a good look at the back, and check. you should have a power connector socket inlet. And a cable out socket, to connect Monitor To Sound Card On The Back of the Desktop.
These can be located on the back underside of the monitor.
if in doubt search for your monitor make and model on the net, and try to get some instructions.
hope this helps Mike.
Feb 17, 2008 | E-Machines eMachines Desktop PC
Emachines wont boot
Bad capacitor(s) on the motherboard can cause this problem, corrupted BIOS maybe... try flashing BIOS.
Probably the CPU if your not getting any error code beeps on startup.. NO Processor for the BIOS instructions thus no Beeps !
Nov 27, 2007 | E-Machines eMachines Desktop PC
Emachines 1900+ gets power to the monitor and computer but wont boot
Buy a dianostics card, and find out if its the RAM, CPU, OR Motherboard. (sounds like a ram or CPU problem though) if you have more than one stick of ram in the system, take one out, and power it up, if still not response, to the other stick out, and put the stick you took out the first time, and put it back in.
Aug 03, 2006 | E-Machines eMachines Refurbished EMA...
E-Machines M5310 PC Notebook Logo
148 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
