Question about First Alert SA302 Dual System Smoke Detector
New battery installed but still does one bleep every forty seconds
Battery was low hence the bleep started,replaced battery with new one but bleep still continued every forty seconds but its not like the sound i get when i burn the toast
Why does my Dell Inspiron laptop not trun on but after a few seconds makes a continual bleeping sound, have put new battery in but no different ?
If you get a continuous beeping sound and no display when you power up your laptop, this suggests that there may be an hardware issue with the system. The problem could be with the RAM or the Video adapter. You need to get the system checked up/repaired by a service technician.
Aug 29, 2014 | Dell Inspiron Computers & Internet
Why is my Fiat bleeping from the inside?
Its an audible warning, is your door closing properly? seatbelt connecting in the latch correctly? handbrake correctly released?, also check the boot and bonnet is secure and latched. Check the dashboard do you have any warning symbols, low oil fuel etc or a service indicator or warning light usually an engine shape or a service due message will be on your dash.If you are not sure go to a garage.
Jul 28, 2014 | 2006 Fiat Grande Punto
Were is the computer located
In regards to the 1614 code. You should/could also see code 1610.
P1610/P1614
P1610- Ignition key/engine control module (ECM) malfunction
P1614- Immobilizer control module (ATS) coding plug communication-no signal. (ATS=anti theft system)
The ECM is getting a signal form 1614 that the key/ignition is not providing a correct code. Hence, the programing is told to fail engine start. Should the engine failing to start with 1 key, try the other key.
Should the Anti Theft System go into lock mode with one key, try the second key. If that does not unlock it then do this: with either key turn the ignition to ON position for 5 seconds then BACK to OFF position for 5 seconds, the to On position for 5 seconds then back to the OFF position for 5 seconds. If the ignition key is and intergrated key (remote: unlock, lock) the batteries should be changed in both keys. Low battery or dead battery provides low or no security code signals to ECM -- hence incorrect or no signal.
When replacing the batteries: be sitting in the drivers seat with the 2 keys within 24 inches of each other. And make the battery change within 1 minute for each key and within 4 minutes of the first key.
If that does not work,Check you users manual for the ignition key sequence on/off series to relearn the on board car computer to the keys.
Mar 09, 2014 | 2000 Kia Sportage
Shoprider traveso beeps but does not move
Hi,is the bleeping continuous or is there a pause , if so how many bleeps are there before it starts again??..
Regards
Rob
www.gewizrepairs.co.uk
Jan 11, 2014 | Health & Beauty
MY toshiba satellite laptop bleeps all the time. it is a soft bleep about it bleeps about every 15 seconds laptop is running well. can any body help with this
This may be a problem with your low battery warning.
Go into control panel / power options / and turn off low battery warning.
Hope this is what it is.
If not write back and we can try something else
Sep 08, 2010 | Toshiba Satellite A100-S8111TD Notebook
No visual at boot, continues to bleep as if starting up every couple of seconds.
sounds like your ram has gave up but you can try some free fixes try resetting the bois first (you can to do this take the battery out from onboard once unpluged and leave it for an hour) i usaly fuind the bois reset on the board it conect it for a split second (there is guide on you tube to do it that way) if that failes take out your pc gfx card and use the chip set one for your screen
Mar 13, 2010 | Computers & Internet
No video output. bleeping every 7 seconds
This beeping is usually caused by a bad Memory or Ram chip. The memory is the chip that is inserted in the purple slots in your display picture. Remove them if there is more than one and replace one by one. Make sure they are firmly reseated or it could damage the motherboard. Make sure both clips on either side are fastened properly.
Try booting computer again. If it continues beeping the memory module may be bad. Replace it with a new one.
Thanks and good luck!
Lolita
Jan 18, 2010 | Chips M863G V1.5 Motherboard
Change battery everything gone dead will not take land rover disc
Firstly, pop a new battery in the fob.
Now we can enter the EKA.
Close all the doors.
Turn the key in the driver door lock to the unlock position and hold there for at least 5 seconds until the alarm sounds once. Then return to centre - always ensure you return to centre and do not delay more than 10 seconds between turns, or hold in the position for more than 5 seconds or you will reset to the start. Turn to full extent of travel.
1st Digit turn to unlock the number of times specified.
2nd Digit turn to lock the number of times specified.
3rd Digit turn to unlock the number of times specified.
4th Digit turn to lock the number of times specified.
Finally turn to unlock once more. If it is correct a double bleep will sound (single bleep is incorrect code)
You now have a 5 minute delay - don't open any doors. The anti-theft indicator will continue flashing once every 2 seconds for the five minute period. When this goes out, open the door and start within 30secs.
After 3 failed attempts, the security system invokes a delay period of 10 mins during which the system will not accept any further attempts to enter a code.
Jan 18, 2010 | 2004 Land Rover Discovery
Philips Dect 215 phone continually bleeping.
Remove all handset batteries and leave for 10 minutes.
Unplug main cradle and reconnect after 30 Seconds.
Replace all handset batteries and place handsets back on cradles.
Oct 06, 2009 | Philips Lands Phones
Ekc on land rover disco 2 v8
Well, you may not need to take it to a dealer if you have the EKA code.
Firstly, pop a new battery in the fob. Get the vehicles battery charged up or changed.
Mar 02, 2009 | 2003 Land Rover Discovery
First Alert SA302 Dual System Smoke Detector Logo
132 people viewed this question
Top First Alert Home Experts
JOHN LAPIER
Dan Apthorp
Are you a First Alert Home Expert? Answer questions, earn points and help others
