Question about Iomega 33089 250 GB Hard Drive
MDHD320-U Power supply
I have the same problem but the model above requires 12v 2.0A will the 1.5Amps be ok?
  • 72 Answers
No. You need to supply the same or higher amps than the device uses. Otherwise, the powersupply can burn and cause fire.
Posted on Jun 17, 2009
I have a TV that shows power on (red light on front of TV), but nothing on scree. TV model is LG 42LN5300-UB
Check the various voltages coming from the power supply board and see if they are all ok, there is a legend on the power supply board to show what voltages are at what pins on the connectors,the 5 volt standby we know is good as long as the set has sound, but check the others
Nov 08, 2017 | LG Televison & Video
How to test the electrical system of the generator for free
Ez test to determine if stator wiring is ok. This test works on generators that have two sets of 115v plugs and 220v plug. Use a 12v, 1amp ac power supply ( smaller ac power supply should work ok ). With generator not running, apply 12v to one of the 115v outlet plugs. Now verify 12v output voltage with meter at another 115v outlet on generator. Also verify that there is about twice the voltage at the 220 v outlet plug (should be about 20v - 24v) . If the adjoining 115 v outlet plug has no output or very little voltage or if the 220 volt plug has no output, most likely stator is damaged or breaker is off. If the stator is shorted voltage reading will be very low and power supply will heat up. If stator is open, there will be no voltage at second 115v plug or 220 v plug. If voltage is ok at the other outlet plugs as per test above then most likely problem is with voltage regulator, or brushes not making contact or armature winding open or just needs to be energized. Unplug the 12v power supply after test to prevent it from overheating. Most generators have two 115v windings that together power the 220v plug. When you energize one of the windings with the 12v power supply, the second 115v winding will be energized also and give you a voltage reading about equal to 12v. You will not damage the generator with this small voltage being input thru the plug. Good luck
Oct 14, 2014 | Electrical Supplies
Need a power supply for a linksys WRT546 What are the voltage requirements for this model?
The Linksys WRT54G requires a DC power supply of 12V.
You can purchase this power supply from any electronics store or online vendor.
Mar 07, 2011 | Linksys Wireless-G WRT54G Router
Can you please provide me the power adapter specs? I need to buy a new one.
I found This power supply
It is listed as suitable for the Porsch drives, but the model number on your current unit should tell if it's the right one.
At 12V 3A it is rated higher than the common 12V 2A which is a common rating for hard drive power adapters, and also supplies 5V. These may be required for your drive.
The site has other LaCie power adapters if the model number does not match.
Feb 09, 2011 | LaCie Design by F. A. Porsche 160 GB Hard...
Blower motor will not work
Do further tests at the relay to ascertain whether the fault lies before or after the relay.
Check power availability at the supply side of the relay contacts - should have 12v from a supply fuse on one side of the normally open contact (note -this supply may only be available when Ign or Acc sw is on).
If power supply is ok at the relay contact, check control input to relay operate coil.
If a ground (or 12v) operates the relay, operate the relay with a local ground (or 12v) and check blower motor runs.
If all above OK, check control signal from fan switch is arriving at the relay control coil.- if not trace wiring back to the switch.
Jul 03, 2009 | Dodge Pickup Cars & Trucks
Pin Name Color Description
Yes this is a good list of the voltages to be expected from a newer power supply on just the main header
Apr 01, 2009 | HP Compaq dc7100 PC Desktop
I have an Iomega external hard drive. P/N is 31641400. model is MDHD320-U. I have been unable to locate any DC12V adapter to work on my external hard drive. Could you please assist me in finding one that...
please check the power rating and the amperage rating
you will get it as 500ma or 1amp or 1.5amp.
and as 12 volts.
so a adapter with specifications of 12v DC. 1.5 AMPS WILL WORK.
IF 1.5 AMPS IS NOT AVAILABLE USE 1 AMP THIS SHOULD ALSO WORK
IF YOU FAIL SEND THE DRIVE TO ME....
NUMBER +0-9-3-2-1-1-0-1-7-1-7
Apr 18, 2008 | Iomega 33089 250 GB Hard Drive
Iomega 33089 250 GB Hard Drive Logo
1,074 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Marvin
Marvin
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
