Replaced toner cartridge but printing quality is very poor to almost nil. What could be the problem? The previous toner I replaced worked very well, but this time its not. I tried cleaning the drum but this did not work.
    Scholar:
  • 34 Answers
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
CF
Posted on Jun 17, 2009
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Faded printing issues with Brother MFC-9320
Try cleaning the corona wire on each toner cartridge. This may help solve your solution.
If this does not help try another thing.
Try and replace the toner cartridge. Maybe your toner cartridge needs to be replaced. Usualy when printed images are light or pale a toner cartridge replacement is recommended.
To see how to replace your toner cartridges check here
May 16, 2012 | Brother MFC-9320CW Color Laser Printer -...
New black ink but very poor quality print?
Is this an original DEll toner, or a remanufactured one?
Sometimes a remanufactured cartridge can need a few pages printed before the new toner 'works ' through the internal mechanisms. Not all remaufacturers actually test (all) of their cartridges. The better ones test 100%, to ensure a quality product.
It could be that the wrong toner has been used in the cartridge (not all toner is the same - by a long way).
It could be that the drum has NOT been replaced. These can be light damaged and result in a poor print quality. An original drum is purple in colour. Aftermarket drums are blue/green.
Nov 02, 2009 | Dell 3110cn Laser Printer
Smasung ML2510 Laser print quality poor especially on graphics
Full isn't always the answer, in order to refill a cartridge properly you need to also replace the cleaning blade inside. The blade wears out and doesn't clean the drum properly and also lets toner leak all over. Your best bet is a new OEM cartridge, or put a new cleaning and Dr. blade in yours.
Jul 29, 2009 | Samsung ML-2510 Laser Printer
Samsung CLP-300 poor print quality
black developer on drum worned out,need changing.
May 05, 2009 | Samsung CLP 300 Laser Printer
Printed pages look terrible...
I'm more familiar with HP printers, but it sounds like a fuser is bad. The fuser effects print quality as well. If you've replaced the toner, as you have.
Apr 24, 2009 | Sharp FO 5550 Plain Paper Laser Fax
Poor print quality
you need to replace the Drum otherwise known as the photoconductor I believe the part number is 75P5712 - your toner cartridge actually seats into the PC kit.
Dec 12, 2008 | IBM Infoprint 1412 Laser Printer
Toner stuck on green roller of cartridge so i'm getting poor print quality
You need to replace the cartridge. it is faulty. there is a spot on that cartridge that is not properly magnetized so it is retaining toner instead of releasing it. you can clean it off but will most likely continue to have the same problem. Clean it with a lint free cloth or paper towel DRY. Do not use any chemicals or water if the toner is salvageable then that would ruin it.
Oct 22, 2008 | Lexmark T632 Laser Printer
Poor print quality
After you have printed a page remove the toner cartridge and look at the drum underneath, is there a ghost image of what has just been printed on it?? if so the cleaning blade is faulty and you'll need to replace the toner cartridge - this is the most likely cause of your problem.
Your printer does have a fuser and it can be replaced, but i don't think it's the problem.
May 14, 2008 | HP LaserJet 2420dn Printer
Poor quality fax to fax, copy great, computor fax great.
beware of generic toner!
you may need to change out your drum unit
the drum unit may have been contaminated by the staples toner.
also clean laser window under drum cartridge.
Mar 17, 2008 | Brother IntelliFAX 2800 Laser Fax
143 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
