Question about Garden
Fuse keeps blowing
Inline fuse on mower keeps blowing. I replaced ignition switch, and solenoid and it keeps blowing. As soon as I turn the key it blows. HELP!!!!!!!
  • Cynthia Jun 10, 2013
    it doesn't blow as soon as I turn the mower on I will be mowing and like 20-30 minutes later when I'm mowing is when the fuse blows? Any suggestions on that?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 109 Answers
In my experience...if it blows the fuse as soon as you turn the key, under the flywheel, there is a stator that recharges the battery when the engine is running, remove the flywheel, in most cases the magnets under it are broken and are in direct contact with the stator. If that is the case, both must be replaced
Posted on Jun 29, 2009
John Deere 5103 keeps blowing fuse for fuel shut-off solenoid Sometimes it will start and run fro a few minutes and other times it will blow fuse as soon as you turn the ignition key
Check wiring and solenoid. There is an electrical fault. A fuse limits current thru wiring and device. Try inspecting wiring for chaffs or worn spots then replace solenoid. Replacing fuse is an exercise in futility.
May 27, 2018 | John Deere Garden
Fuse for igntion were its located
    Riding Lawn Mower Fuse Replacement - Craftsman Lawn ...
    ? 1:51
    https://www.youtube.com/watch?v=rjFz8l8hoGk
    Aug 22, 2014 - Uploaded by RepairClinic.com
    ... instructions for replacing the fuse on a Craftsman riding lawn mower. ... Mower Starter Solenoid Replacement - Craftsman Riding Lawn ...
    14 HP Murray Mower 42813x92B Blowing the Fuse - YouTube
    ? 4:37
    https://www.youtube.com/watch?v=J8l1Ew40G7g
    Feb 14, 2013 - Uploaded by RogerASkiVideo
    Photographic guide to troubleshooting a Murray riding mower that keeps blowing the 15 amp fuse. images for Lawn Mowers ignition fuse
Dec 19, 2015 | Garden
Why does my john deere 5075e keep blowing ignition fuse
It has to have a short either at the starter or the ign. switch just check the wires that carry power and make sure none are earthing out.
Aug 17, 2014 | Garden
Why does my mower keep blowing the 20 amp fuse
could be the safety switch for the pedal
Apr 23, 2012 | Husqvarna Garden
The in line fuse between the solenoid and the ignition key blows as soon as I turn the key on. The mower is less than a year old and wiring seems fine.
Solenoid is probably shorted to ground...if you can obtain an ohmmeter..measure the resistance from the small trigger lead on the solenoid to ground(usually the mounting tab)..the reading should be around 50-200 ohms...if it is lower then the solenoid is junk
Apr 25, 2011 | Garden
98 Ford F150 4.2 Liter Engine will not crank keeps blowing fuse #21 (15amp) as soon as I turn the ignition key. Was running fine just stopped to gas up and it wouldn't crank. Jumped the posts on the...
Sounds like there's a grounded wire somewhere between the ignition switch and the solenoid. When you bypass the switch with the screwdriver you don't ground out the line, but with the switch the ground shorts the circuit, blows the fuse, and then won't start the engine.
Apr 18, 2010 | 1998 Ford F150 Regular Cab
Cub cadet 2160 when turning ignition switch in second position, starter motor starts spinning. blows 20A fuse
You have either a short in the solenoid trigger circuit, and a faulty solenoid. To check, disconnect the small trigger wire on the solenoid. Turn key to 'START'. If fuse blows, there is a fault in the wiring. If not, the solenoid is faulty.
Oct 31, 2009 | Garden
My riding mower blows fuses once you turn the key.
Sounds like you are on the right path, maybe some wires on the ignition were replaced backward, and you are sending +12v directly to ground? Does it blow right away?
Jun 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
2,147 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
