Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
I have a samsung hc-p4752w and I'd like to find out where I can get an inexpensive blue picture tube.
  • 4 Answers
The blue tube will cost $150-$200 from a Samsung parts distributor. Keep watching Ebay. Did you change the coolant by any chance? The coolant fogs really bad on the blue tube on this model and it looks like a bad CRT.
Posted on Jun 18, 2009
I have a Samsung HC-P4752W and see yellow and bllue halos.
Have you tried to use the convergence function on the TV? If that has not fixed this issue then you have bad convergence IC chips. These chips are microprocessors that align the blue and red tubes with the green (which is stationary). This converges the three tubes to create the image that you see. Failure of these chips (usually from heat over time) is a common problem with projection  TVs. The chips are not very expensive; from $35-60 for the pair. Replacing them involves some tedious desoldering of the old ones and soldering in the new ones. If you have some experience with electronics and soldering it is not hard. Shops will charge $300 and up for this repair. If you want to do it your self post a comment bnack here and I can assist you further.
Dec 05, 2009 | Samsung HC-P4752W 47" Rear Projection...
When turning TV on it would click a few time, then you would hear a hissing sound, but no picture. Would have to unplug TV, as it would not power down. Unplugging and plugging in would eventually get...
The hissing sound could be high voltage leaking from a tripler. Observe in a dark room for blue arcing. Look at tripler and connections to the projection tubes. If the tripler is leaking replace the tripler.
Oct 13, 2009 | Samsung HC-P4752W 47" Rear Projection...
I'VE HAD THIS TV FOR 4 1/2 YEARS-THINK IT'S THE BULB-REPLACE?
The HC-P4752W doesnt have a lamp. Thats a rear projection it has three picture tubes.
Oct 10, 2009 | Samsung HC-P4752W 47" Rear Projection...
Picture is compacted vertically in center of screen redgreenblue
your vertical hold is out on the tube. new tube is needed. cheaper to get a new flat panel tv.
Jul 19, 2009 | Samsung HC-P4752W 47" Rear Projection...
I have a samsung hc-p4752w rear projection
Not simple at all it require a Technician yes it very common problem in the high voltage output you can replace the whole printer circuit board but it require to adjust a few thing after replace the new PCB such high voltage for 3 picture tube and convergence
Part No. is BP94-01249G or L
Nov 18, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W 47" projection TV distortion & yellow?
I think you have a fault on the chroma board and on the picture frame board. If you can trace it yourself try these two locations otherwise call out a competant technician. hope this helps.
Sep 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
TV problem
It sounds like there is a fault on the chroma panel of some kind.
Jul 23, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung hc-p4752w
Sounds like convergence amp ic's
i dont have any part number for that model.
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Mar 14, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
182 people viewed this question
Jerry Greenberg
Jerry Greenberg
