Question about Samsung DCS 12 Corded Phone
Turn off ringer iDCS 18D
All phones ring for incoming. Constant ringing at my desk is a pain. Is there at least a way to lower the volume? The other phones ring so loudly that I'll still be able to hear calls as they come in.
I'm thinking of punching a hole or two in the speaker. Please help.
SASSYBEAR
  • 148 Answers
SOURCE: Samsung iDCS 18D
http://www.telephonesystemsdirect.com/pdfs/iDCS_Keyset_User_Guide_10_2005.pdf
here is the user manual .. usually you would dial 9 to get an outside line .. or just push one of the open line buttons. No batteries are needed it gets its power from the phone line.
Posted on Mar 11, 2008
SOURCE: samsung idcs 18d
Wow thank you sooooo much! We were trying to figure this out at work, and Ramoth's suggestion worked perfect. Thanks again!
Posted on Nov 04, 2008
SOURCE: recording main message
trying to recorded a different main message to phone, how do you do it?
Posted on Jul 02, 2009
  • 279 Answers
SOURCE: iDCS 18D VM setup and template for lines
Here's a link to download the manual. Sorry, I couldn't find a template.
http://www.samsungidcsphonesystems.com/pdf%20files/user%20guides/iDCS_Keyset_User_Guide_10_2005.pdf
Posted on Sep 21, 2009
  • 5 Answers
SOURCE: I have a Samsung iDCS system. We have a phone
You have to change the group in order to add lines or remove lines from the incoming ringing
Posted on Nov 11, 2009
Our office has a two line system on a idcs 18d our first line will ring throughout the office but the second line is silent and only lights up. How do we make it to where it rings as well?
Assuming you have the programming manual, you need to program trunk 702 to ring to the operator group 500 in MMC 406 in the software programming manual.
Feb 29, 2016 | Samsung Falcon iDCS 18D Display Phone with...
My Samsung iDCS 18D phone will not ring. The Line light flashes, and I can asnwer calls, but it won't ring. I have tried adjusting volume levels, etc- but it seems like the ringer is turned off.
First prove it is not a faulty handset. Find someone elses phone that is the same model as yours and rings then plug it into your line. If that phone rings your handset is faulty. If the borrowed phone will not ring but flashes then it is programming
Jul 06, 2015 | Samsung Falcon iDCS 18D Display Phone with...
How do I turn the ringer off on my samsung iDCS18D at my desk.
HAVE YOU PHYSICALLY PICKED UP THE PHONE AND LOOK ON THE BOTTOM ?? MOST HAVE A LOW, MEDIUM OR OFF SWITCH FOR THE RINGER ON THE BOTTOM OF THE UNIT.
Jan 06, 2015 | Samsung Falcon iDCS 18D Display Phone with...
When in night mode, how do I make the samsung idcs 18d ring on every extension
if you know your password for your phone system do this. enter programming mode by pressing transfer key, type 800 enter your password then volume up key then speaker key. go to program 601 station groups find unused station group ie 510. make this group unconditional and under members add all thr extensions you want to ring then press speaker key. then go to program 406. enter line number of line and under night mode tell it the station group number you programmed above
May 07, 2014 | Samsung Falcon iDCS 18D Display Phone with...
Phones do not ring with incoming calls
Check make sure ringer is turned up,push speaker button then push volume button a volume thing should show up on the screen,keep pushing volume button and it will. Increase the volume.ty.
Feb 15, 2014 | Panasonic KX-TG2632 Twin Cordless Phone
Somehow the ringer got turned off. Can't figure
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
Sep 12, 2011 | Uniden Lands Phones
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
I use the handset lifter for the phone I have (Polycom SE-225). When am sitting at my desk neat the phone, I speak anything above a low normal into the bluetooth headset, like when I am laughing or people...
Unfortunately no. The phone ringer has to be a certain volume for the lifter microphone to pick up the ringing vibrations. If you put it to low, you will not be alerted to the incoming calls. When you're at your desk and can see the incoming calls, maybe then you can lower the telephone ringer volume for some relief.
Good luck from Headsets Direct!
Jan 03, 2011 | Plantronics Voyager 500A Deskphone Adapter...
My lucent Merlin ETR 18D is not ringing at all on incoming calles. The lights are flashing, but the phone does not ring.
hello,
i want you to go your phone setting, press the menu,scroll to profile, select the profile you are using and personalize it.
however, when personalizing scroll down to ringing type and select the ringing type you want.
if this does not work, open the phone, remove the ringer [the ringer is a small metal touching the panel of the phone, read it with meter, if it does not read, change it and replace it with a good one.
Jun 05, 2010 | Lucent Merlin Legend MLX-20L Phone
Ringer settings on 8825 base unit
You can adjust the volume and pitch of the ringing by pushing Menu, scroll forward to Desk Station Settings, push Select, scroll to Ringer Volume and you can adjust the ringer volume, and in that same area adjust the pitch. So you might want to make line 2 ring lower, and with a different pitch so it is not distracting, but still notifies you of an incoming call that is not line 1. The same goes for the handset.
Apr 18, 2008 | Siemens Gigaset 8825 Cordless Phone
Samsung DCS 12 Corded Phone Logo
1,809 people viewed this question
Top Samsung Lands Phones Experts
Don Hart
Jose Ma DM.
Jose Ma DM.
Brett Duxbury
Brett Duxbury
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
