Question about Samsung Televison & Video
Lamp comes on then shuts right off last week now lamp wont light at all, color wheel isnt turning on
    Problem Solver:
  • 15 Answers
Your bulb is "burned out". The first sign of a failing bulb is the periodic extinguishing during use. Next comes complete failure.
Posted on Jun 17, 2009
DLP Lamp starts to turn on...and then shuts off
Probably not the color wheel, usually when color wheel is bad lamp would not light at all. Could be a ballast but the most likely would be the lamp itself.
Mar 14, 2014 | Televison & Video
Unit will not power up
the lamp may be faulty needs replacement, another culprit is the color wheel when worn out they tend to get stuck and cant spin hence the clicks as tries to spin needs replacement most color wheels come inbuilt in the light engine u will need a tech to replace it and u are good to go remeber the lamp cant turn on if the color wheel is stuck cos its the one that syncrinizes with dmd board which in turn activates the ballast board to fire or light the lamp
Jul 15, 2013 | Sony BRAVIA KDL-V40XBR1 Television
HLR 5067W 6yrs old. I replaced the lamp and color wheel about 3 years ago. Last week the TV would not turn on. Fans run hard, no light from the lamp. Tries for 3 cycles, then shuts down and front...
Tv is on every day and watches 4 to 5 hours every day?Yes,3 years now the projection lamp require replacement again and the board that call the Ballast board might require replacement too,this Ballast board only job is it to ignite the projection lamp only..
Jun 04, 2011 | Samsung HLR5067WX 50" Rear Projection HDTV
Install new lamp, nothing comes on ,change back to old lamp still nothing
Hi,If the lamp didn't do the work it could be that the problem is with something else.If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Do you hear buzzing or high pitch sounds? If you do it could be a problem with the color wheel.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Make sure the door cover is properly shut other wise it wont lamp light up.
Apr 05, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
We own a Samsung DLP-TV. Last night it started shutting itself off. WE changed the lamp, but it is still shutting itself off after a minute. First, the picture goes off black, then the entire TV shuts off....
Do you still have your old lamp? try to see if it still works.. i think the problem could be something with your Ballast or maybe the color wheel.
Does your TV makes a strange sound? if it does maybe one of those 2 ballast or color wheel.
LETS TRY THIS....... MAYBE IT WILL WORK.
the Door lamp switch could be faulty, you've got to check it need to close fine with out the switch to go down
here is a picture that i found it looks like this!
and if not.. you can probably call this number the will give you free service.. i have tried it before =] (800) 281-8860
Mar 09, 2010 | Samsung HL-T5675S Television
TV won't turn on after lamp was replaced
Check the switch on the lamp door. Listen for the color wheel to spin. if the door switch is bad the lamp wont come on, samething if the color wheel is bad.
Jun 16, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Whining noise on start up, lamp and TV shutting down
The TV tech isnt too familliar with RCA TVs. The color wheel is the most likely problem no where near 1000. Depending on the model number of your set you can get replacement color wheels at the following link.
http://servicemanuals.vstore.ca/
Jun 13, 2009 | RCA HD52W59 HDTV Projection Television
6 months ago, the colors started messing up and it made this screaming banshee sound. The TV would turn itself off after a minute or so. I read about it and figured it was the color wheel. I bought a...
You need to put in the values for x,y, of red,blue,green & white.
when you get the color wheel, sticker(printed values) was in the same box.
If you have, let me know and I''ll let you know how to put in.
Jan 13, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Lamp light turns red
Yes this is the signal for a bad lamp. Other things can cause this. 1. Look at the new lamp. make sure it still looks good. not broken with little glass pieaces in it. 2. When you turn on the tv, put your ear to the lower back part of the tv near the middle. Listen for the start up of the color wheel (a low high pitch sound only at the start up of the motor). If this is good you will here a ticking sound only if the lamp dose not light.
Now with all this info. If the lamp lights (as seen from the back of the set) and goes out after a few seconds and you did not here the color wheel spin up, the color wheel is bad.
If you here the color wheel spin up and no ticking sound, the Ballast is bad.
The ballast part no. 939P978010
The color wheel is not avialable from Mits. You will have to replaced the light engine. It cost to much. Just buy a new tv.
Sep 03, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
