Question about Boating
How do I remove the bendix for the starter.
How do I remove the bendix fro my Johnson 1978 starter?
    Problem Solver:
  • 7 Answers
You need to undo the nut! If you twist the pinion gear so it engages with the flywheelIt will make the job easier.Or you may have to hold the shaft with a pair of vice grips, make sure you protect the shaft if vice grips are used
Posted on Feb 19, 2012
    Problem Solver:
  • 5 Answers
Should be just a snap ring
Posted on Jul 26, 2009
Remove bendix from honda varadero xl 1000
The bendix is at the top of the starter. Pull the starter, remove the four bolt at the back of it. Pull the cap off the starter. remove the clip on the end and pull the bendix out.. Just a note.. they quit selling bendix and solenoids years ago.. Starter only, all or none.
Oct 11, 2016 | Honda Cars & Trucks
Need to replace starter bendix on 1994 750 kawasaki xir
It is fairly easy to change your starter bendix. Just start by disconnecting the battery cables. Then you will remove the bolts on the flywheel cover, which also hold the starter in place, and then just change the old part out with the new one.
Sep 25, 2016 | kawasaki 2010 Jet Ski Ultra 260X
Engine start Bendix still engaged put into any gear Bendix disengages can go back to park there will be no more problem
if your saying your starter stays engaged after starting engine till you cycle thru the gears , your starter needs serviced , most likely a worn bendix pivot bushing
two options 4 repair
1= replace starter
2= remove starter and have it professionally rebuilt then reinstall it
Sep 14, 2015 | Cars & Trucks
What causes a whirring sound and no starter engagement countax bendix
Bendix whirring . not engaging. Weak battery can cause that to happen. Bendix spring broken... Bendix gear teeth worn... Bendix spiral on shaft dirty. Remove starter from car and have a look at the Bendix . If the sliding gear on the shaft is worn ,,replace it. Make sure that the return spring is not broken and make sure that it slides easily along the spiral grooves. Check the starter ring also. You can use a torch to see that. It`s not likely that it will be too bad but it is wise to inspect it. It usually wears in three places. Now it is possible that the starter coils are going.. I would put in a reconditioned unit, I have done many times. I hope this helps you, Kindest regards. Jim Doolan..
May 21, 2014 | Briggs & Stratton Measuring Tools &...
1978 johnson 25 hp
Hi, make sure you are using a genuine pin and if so check the back of the prop where the pin sits for wear, regards Phil.
Jun 11, 2012 | Boating
Starter motor not engaging
Hi without seeing (hearing) it sounds like the clutch in the bendix is faulty, as the solenoid will engage the bendix at the same time as connecting feed to the starter motor.
New starter required or a good strip down and rebuild on the solenoid and bendix.
What condition is the ring gear in by the way (Starter Motor removed). David
Dec 25, 2017 | 1988 Mitsubishi Pajero
Starter just clicks on my 2001 polarise magnum 325
IF you can pull the hand starter it is probally the starter itself. If the hand pull strater is also hung up, then it is the bendix. the bendix is located behind the left panel with the pullstarter. Remove the pull start assyembly remove the bendix clean and lubricate it and reinstall.
Jun 01, 2012 | Polaris ATV
Starter turns but wont engage engine?
Sounds like the Bendix... You might ought to pull the starter and look at the teeth on both the bendix of the starter and the flywheel. If the teeth on both are in good shape...then its probably a weak starter not throwing the bendix out to turn the flywheel. But...if the teeth are **** up on the bendix...its cheaper tp replace it. Make sure Battery is in good condition as well. Both battery AND starter can be tested at your local AutoZone... Hope this helps...
Aug 03, 2011 | Buick Riviera Cars & Trucks
Starter is broken. makes a loud csfscscshh sound instead of starting?
Make sure to check the flywheel when you remove the starter there may be flywheel damage and that would cause the same problem.
Mar 01, 2011 | 1987 Buick LeSabre
HOW DO I CHANGE A STARTER ON A 1978 CAPRICE CLASSIC
Remove the inspection pan,undue all the nuts holding the cable,and the ignition starter wire on the solenoid.remove the two bolts that mount the starter.When you go back with the replacement starter,put the shims that came out,back between the starter and the block,if you do not do this,the starter could be damaged,and the flywheel.
Oct 28, 2009 | 1978 Chevrolet Caprice
Boating Logo
156 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
