Reset BIOS Password
SOURCE: Dell Optiplex GX 270 pc desktop problem
I've heard that Dell will still honor the warranty if you mention the capacitors to them. They haven't recalled them, but they know it is a known problem.
SOURCE: i have many problems in my dell gx 270 desk pc
1.go into the control panel under sound and make sure the volume is at least half way in the middle of the slide selector. also check the volume nob on your speakers, and there is also a volume control in media player. If all that does work, download and reinstall the driver from dell site again.
2. in system tools go to clean disc, a box opens, put a check mark in everything there (you don't need any of them) run it. then go back into system tools and this time select disc defraggmenter and click on defragment and go have a snack, when that is done reboot.
3. if you didn't put a password in when you reinstalled XP you won't need one. just click ok. and if you don't want to see it at all, in the control panel under Users turn off the Guest user ...
now down to the important stuff...that is not my picture you are seeing.
so I hope this info helps you. please leave a rating..thank you kindly
SOURCE: I would like to replace the front USB ports on a
ok you need to unscrew first then press the botton on side then full presto you now open the cover.
SOURCE: Dell Optiplex GX 270 crashing on the Internet
Hi
Download a "stress" testing programme called Prime95 and read instructions / run it through. I assume that ALL the ram matches perfectly. If this tester crashes PC alot, remove one ram stick at a time, may actually narrow the offender down. Also bear in mind that a programme could also be crashing PC so try using control Alt Del and go into "processes" and shut down ONE at a time / retest. This will take time but will narrow down the offender. You actually only need to run Prime 95 for a short time.....till it crashes PC. Eventually once you have stability the PC should run with no probs overnight!!
SOURCE: DEll GX 260 Bios Currupt due to abnormat shutdown
Please download BIOS and install from following site
http://support.dell.com/support/downloads/driverslist.aspx?os=WW1&catid=1&dateid=-1&impid=-1&osl=EN&typeid=-1&formatid=-1&servicetag=&SystemID=PLX_PNT_P4_GX260&hidos=WW1&hidlang=en&TabIndex=
Regards
Ashley
