Question about RIM BlackBerry Curve 8310 Smartphone
Hi, When I connect my 8320 to my computer the device manager keeps rolling up and down as if refreshing. Is there a way to correct this
  • Matt Nolan
    Matt Nolan Jun 17, 2009
    Hi again,
    I have tested it with another pc and I am getting the same result. I am trying to connect to the pc so I can reinstall the os as due to a corrupt update all I am getting is the flashing lights. Would this make a difference????
  • Matt Nolan
    Matt Nolan Jun 18, 2009
    Hi, When I connect my 8320 to my computer the device manager keeps rolling up and down as if refreshing. When I check the USB ports I can see the Blackberry but when the screen 'refreshes' it is gone and then with the next refresh it is there again, this continues the entire time the blackberry is plugged in. Is there a way to correct this?
    President:
  • 828 Answers
If the device manager keep rolling ups and down maybe your own 8320 are recognizing some hardware in your phone, maybe you know that there is an CD or installer of that, so use it... and read the manuals...
Posted on Jun 18, 2009
    Genius:
  • 1,341 Answers
I believe there must be something to do with the driver somewhere..If I was you I would back up the phone and and remove the phone from the o/s and restart it and re-install the whole thing from scratch and you might be lucky there.I would also advise to test this phone on another pc in case you waste too much time and found it is doing the same thing on a different machine.
Posted on Jun 17, 2009
  • heeman mohun Jun 17, 2009
    If you mean you want to re-install the o/s then go got it but make sure you know what you are doing especially with window product key and etc..Before you do that try to use a registry repairer,something like registry mechanic..That could help..
Fingerprint device keeps reinstalling its drivers
Try a system restore, bring computer back in time before this became a problem.
Apr 05, 2012 | HP Compaq 6910p Notebook PC PC Notebook
Blackberry 8320 keeps resetting - get "your handheld has been registered... message"
HI,
In your initial sync window in Desktop Manager, UNcheck the box that states something like "Update time and date on sync"
Sep 12, 2008 | AT&T Blackberry Curve 8300 Smartphone
Jvm errore 517 in bb 8320 how can i solve
To correct this, follow the steps outlined below from RIM:
1. If not already installed, download BlackBerry Device Software and BlackBerry Desktop Manager from the wireless service provider web site.
2. Install BlackBerry Desktop Manager and then install the BlackBerry Device Software.
3. Use Application Loader to reload the software on the BlackBerry device.
But, if it is on warranty, it is better you go for a replacement.
Good luck
Sep 21, 2011 | RIM Blackberry 8310 8320 8330 Curve 8100...
Hi. i am tryinmg to charge my nieces mp3 that she has got. she lost the original chatger (lead) so i am using a spare one that i have found.. its coming up on the screen connected but its not showing the...
Hi, why it's not charging yet ,i think its not yet recognizing the mp3 player yet. You will need to follow the below step and solve the problem.,Then after trying out this steps and still does not work,That means you will need to replace the USB cable...
Hi, when an m3player does not detect on your PC, usually when Drivers that corrupted..
How to rectify the problem:
Connect the mp3 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are mp3 player Connect and mp3 player Express which only use MTP mode. MTP mode is the recommended and default method for mp3 Players when used with Windows OS.
The mp3 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Good luck......
Mar 12, 2011 | Audio Players & Recorders
My transcend Ipod is not getting detected in the computer
Hi, when an pm3player does not detect on your PC, usually when Drivers that corrupted..
Refresh the drivers
Hope it helped.
Good luck to you.
Feb 25, 2011 | Transcend T-Sonic 840 MP3 Player
My archos vision 1 is not recognised by computer
Hi, archos vision 1 player not recognized by the computer
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see archos vision 1 player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the archos vision 1 player to the PC
STEP 2 - Check under Device Manager
NOTE: archos vision 1 Players can connect to your computer in MSC or MTP mode. Exceptions are archos vision 1 Connect and archos vision 1 Express which only use MTP mode. MTP mode is the recommended and default method for archos vision 1 Players when used with Windows OS.
The archos vision 1 player will show up on Device Manager's right pane as:
STEP 3 - Refresh the drivers
Have a nice day....
Feb 19, 2011 | Audio Players & Recorders
I'm having trouble charging my mp3 it won't stay connected how do i fix that?
Refresh the driver
Connect the player to your computer.
- If the player does not turn on try other USB ports or on another computer if one is available. Make sure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the players screen is just not working.
<<<<< BUT TRY THIS FIRST >>>>>
Check the Device Manager
1. Right-click My Computer, and select -- > Manage.
NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode.
MTP mode is the recommended and default method for Sansa Players when used with Windows OS.
*** See This Tip Posted here ****
Solve your MP3 Player Connection Problem.
The Sansa player will show up on Device Manager's right pane as:
Refresh the drivers
>>>> BUT TRY THIS <<<<<<<
Connect using MSC mode
Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC.
Verifying and changing the USB mode of the device to MSC or MTP From the Main Menu, select Settings > USB Mode.
Feb 22, 2010 | SanDisk Sansa Clip MP3 Player
When i plug my Nextar MA797 20 mp3 player into my computer my computer keeps saying that the usb device has malfunctioned or windows does not recognize it but it worked fine before.How can i fix this or...
Check and refresh the drivers in Windows, for a Portable Device.
1 - Connect your player to the PC
-> 1. Right-click My Computer, and select Manage.
NOTE: The player should show up on the Device Manager's right pane as:
1. USB Mass storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode.)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh or reinstall the drivers.
2. On the top menu, click Action then select Scan for hardware changes. The computer should pick the player and try to reinstall the drivers. *** See again step 1 and 2. See this guys tip for an explanation of MTP and MSC Solve your MP3 Player Connection Problem.
Jan 12, 2010 | Audio Players & Recorders
Hi i have just got my blackberry 8110 curve back from carphone warehouse, who told me my phone was beyond economical repair, due to some of he keys not working. my phone phone was still under warranty but...
First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
Oct 15, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
My Blackberry Curve 8320 does NOT have Blackberry Messenger
If you want to install Blackberry Messenger on handheld do the following steps :
  1. Download the latest BlackBerry Device Software from your service provider's web site.
  2. Install the BlackBerry Device Software onto a computer that has BlackBerry Desktop Manager installed on it.
  3. Connect your BlackBerry device to the computer.
  4. From BlackBerry Desktop Manager, double-click Application Loader and follow the instructions in the Application Loader Wizard to install the BlackBerry Messenger application.
May 20, 2009 | RIM BlackBerry Bold 9000 Smartphone
RIM BlackBerry Curve 8310 Smartphone Logo
Top RIM Computers & Internet Experts
ismael castillo
David
Jerry Greenberg
Jerry Greenberg
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
