Question about Whirlpool Calypso GVW9959K Top Load Washer
Grease on clothing, AGAIN. Have had the wash plate replaced, but the problem returned within a year.
Try changing your detergent. I believe it was Tide that caused dark grease type marks on my clothing. It hasn't been a problem since I changed detergents.
Posted on Jun 21, 2009
HI IS IT POSSIBLE THAT GREASE OIL CLOTHES CAN BE THE CAUSE OF GREASE SPOTS ON OTHER CLOTHES I THOUGHT IT THE SEALS THATS BROKEN I HAVE A SPEED QUEEN FOR 13 YEARS NOW
Sure, the launderette I used to use had a separate machine for washing dirty overalls etc. for this exact reason, transfer of grease to the next wash.
Jan 05, 2018 | Speed Queen Washing Machines
A407 maytag washer getting grease on clothes occassionaly what would the replacement part
Maytag washing machine gets grease on clothes ... - Fixya
www.fixya.com/.../t14582529-maytag_washing_machine_gets_grease
Oct 8, 2012 - Maytag washing machine gets grease on clothes occasionally. ... some of their clothes ruined by grease stains from their front loader Kenmore. .... remove the agitator from a Maytag washing machine Model A407 series 02?
Aug 24, 2015 | Maytag Washing Machines
My 4 year old roper washer leaves grease on clothes. On spin cycle the machine makes a screaching noise, and the clothes don't spin dry.
Possible that the belt is slipping and also there is some issue with the agitator as the gaps within seems to bring up the dirt or grease mix to the clothes.
So it is important to remove the panel and check the play on the belt, replace if the play is high and check if the agitator bearings are worn out. If so the agitator assembly must be taken out and checked.
Dec 09, 2011 | Washing Machines
The clothes are being pulled under the agitator, getting tangled and grease/oil marks on the clothes. What can be done to correct this?
If the clothes are being pulled under the rotating plate, you need to replace the plate because the plastic-sealing-edge strip is not pressing tightly against the inside of the washtub. I did this and all has been good for a year. The grease COULD be from the rotating parts under the plate, but there is also a post on this Fixya site that has to do with replacing a transmission seal. I have not had the dirty-streaks problem, so I cannont comment on a fix for that. BUT, replacing the rotating plate WILL fix the issue with pulling clothes under it.
Mar 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Faulty bearing in the drum
If sealed bearing, drill small hole after removing rear plate and inject grease with syringe,seal hole with stopper or self-tapping screw.
Run for about 20 mins. to allow grease to penetrate.
Jan 04, 2010 | Washing Machines
Kenmore 417.80042990 (10 year old) dryer makes a squeak as it tumbles the clothes dry. Seems to be worse as the clothes get dryer. FYI-the felt was replaced about 4 years ago, not sure it's that. But...
this is a frigidaire made dryer with kenmores name on it. The drum bearing needs more grease. You really need to know what your doing before you take that job on yourself. Its easy for me...but I have been doing it for 20 years and thats the way I role
Nov 11, 2009 | Kenmore 98702 Stacked Washer/Dryer
Grease on clothes?
This is a 50 year old problem on washers.  All brands.  You just got lucky on this one.
If you buy a new one, consider a unit built by Whirlpool.  They also make Kenmore and others.
Nov 12, 2008 | GE WSXH208A Front Load Washer
Whirlpool Calypso GVW9959KL1 ruins clothes
I can assure you this IS a common problem. I can't tell you how many customers I have had in the past that complained about their Calypso's leaving the same marks on their clothing. The problem occurs because of the suction on the clothes as the washer extracts water from them during the final nunator cycle. The nunator is the wash plate that the clothes get caught in. The manufacturer's cure for this problem was to come up with a modified control board that reduces the final nunator time and minimizes the suction action on your clothing. The replacement control board part number is 8571359. I have ordered and installed this board on a few Calypso's. I'm surprised that nobody advised you of this in the past. If you call Whirpool back and they deny this, I got this information from them. It may be worth your while to contact them again to see if there is a recall on this and if they would cover the cost of the repairs.
Aug 22, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
HELP GREASE RUINING CLOTHES IN WASHER
over 5 years or cost over 250?
 throw it away, and get a Whirlpool
Oct 21, 2007 | GE Profile Prodigy WPSE4200A
Grease-like Stains on Clothing
Archit, the problem is located underneath the agitator. If you can imagine the plastic agitator not being there, you'd see a metal shaft sticking up through the bottom of the tub. This shaft comes out of the transmission and pokes through a couple of bearings and seals. These bearings are permanently (supposedly) sealed. When they fail, the lubrication (grease) inside them will show up on your laundry. After a while the black smudges will disappear altogether! This is not good. This means there is no more lube in the bearing and it will begin to wear at an extremely fast rate. It will rust through, it will leak and it will start "howling" loudly when the unit is in "spin". If the unit is less than 5 years old it will be a warranty issue through GE. The drive train has a 5 year warranty. Call 1-800-GE-CARES for their customer service line (have model and serial number ready) You haven't lost your mind, this is not uncommon.
Aug 16, 2007 | GE WSM2420T Top Load Stacked Washer /...
Whirlpool Calypso GVW9959K Top Load Washer Logo
146 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
