Question about Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw
My chainsaw starts without muffler but not with it on, what's the fix
  • 67 Answers
If the muffler is clogged or damaged there will be too much back pressure for the engin to run. Check for free flow. Also, check the intake air filter to make sure it is clean so there is amaple air flow. Lastly, is there a safety shutoff related to the muffler that is being activated impropperly?
Posted on Jun 17, 2009
How to remove chainsaw muffler
If this is the Husqvarna 440, there are two allen headed screws sunken down inside the holes in the front of the muffler, its either a 5mm or 6mm long arm allen key required.
Jun 16, 2013 | Husqvarna Chainsaw 440E-18
Poulan 38cc wont start
quick check would be to pull muffler from engine check the screen if the screen is ok start engine if it starts without the muffler the muffler needs to be replaced.if it still dont start do pressure and vaccum checks on carb.
Jan 28, 2013 | Poulan Garden
Husqvara 345 chainsaw hard to start
try running it with out the muffler if ok without the muffler open it and clean the internal screen
Sep 15, 2012 | Husqvarna Garden
Poulan Pro PP3816AV does not start
try and run it without the muffler there is a screen inside that plugs up if ok with the muffler off open it up and clean the screen off
Jul 06, 2012 | Poulan Pro PP3816AV 38 Cc 16" Anti - Vib...
Saw runs without muffler but will not start with muffler installed
muffler probably needs cleaned could be gummed up blocking exhaust flow
Jun 12, 2012 | Garden
CHAIN SAW QUITS RUNING AFTER WARM UP
remove the muffler and run it if it runs good without it open the muffler and clean of the screen inside
Jun 06, 2012 | Craftsman 18 Inch 2.6 Ci Chainsaw Tank...
I have A husgvarna 350 chainsaw that got real hot the muffler screw came off causing the muffler to wiggle to a slant and melt my plastic right above the bar. What should I do that is very unusual.
There was an issue with the muffler bolts comeing loose, to that end a muffler with a third fixing hole was introduced, if the oil tank below the muffler is melted to the point that the chain oil is leaking out, then it will need a new crankcase.
Mar 13, 2012 | Husqvarna Garden
Craftsman chainsaw has no power
I would first check your muffler and screen in muffler to make sure it's not partially plugged. Personally I think it sounds like a fuel delivery problem,I would make sure you change your Fuel filter and check your lines for being cracked and or collapsing from ethonal in gas these days. then I would put fresh gas in it and see if it helps.you also need to clean carb and then readjusr carb after cleaning carb
Jan 02, 2012 | Garden
Echo cs-370 chainsaw wont start. running fine the day before. good spark. fuel wet at muffler. plug always wet.
Check air filter- is it clean?
Some plugs are without cilinder ok but if in place dont work. cahange the spark plug.
Mar 17, 2011 | Echo Garden
Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw Logo
187 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
