Question about InSTEP Quick N EZ Bike Trailer
How do you put it on your bike - InSTEP Quick N EZ Bike Trailer
On what part of the bike do you attached to
Posted on Feb 17, 2010
    Sergeant:
    Champion:
  • 236 Answers
There is an attachment you have to get that mounts on the bike
Posted on Jun 17, 2009
I start my bike up get on it and can put it in gear without clutch this don't suppose to happen my pronlem
Putting your bike in gear without the clutch is completely possible and can be dangerous as power will be applied as soon as you do. The idea of the clutch is to apply power between the engine and drive train gradually. I typically only use the clutch on my bike when pulling out and down shifting, otherwise the rest of my shifts are clutch less. Just be careful the bike doesn't take off on you, best to always use the clutch when putting the bike in gear.
Jun 05, 2016 | Motorcycles
I have a pocket bike that wont start unless u put gas where the spark plug is and then it will run&idle but once u give it throttle it dies there is no high or low screw there 1 screw &the idle screw
Hi, Anonymous more than likely it's clogged carburetor jets, obstruction in the fuel system or a faulty battery for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Common Reasons Why My Pocket Bike Wont Start
Pocket Bike Won Start Help Quick Fix
What To Do If Your Pocket Bike Won Start or any 2 stroke engine
Pocket Bike Not Starting
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 01, 2016 | Motorcycles
When I start up my bike I pull in the clutch lever put it into gear the bike shuts off and lunges forward.
Clutch problem - please help - Dirt Rider Magazine
forum.dirtrider.com/discussion/6668452/clutch-problem-please.../p1
18 posts - ‎9 authors
I start the bike in neutral with the clutch pulled in, then I shift into first and it will kill ...bike, if you put the bike in gear and try to roll it (even with the clutch lever pulled ...Started it back up, gave it enough throttle to keep it from stalling, put it in 1st, ... I continue to change the oil in my clutch but almost immediately it turns white.
Re:Always shuts off putting it in first!! - Road Star Forum ...
roadstarclinic.com > Forum List > Technical Corner > Maintenance
Jun 17, 2014 - 10 posts - ‎8 authors
My 99 Roadstar has the habit of always shutting off when I knock it into first ... pull in the clutch and put it in first gear the bike lunges forward and shuts off. ... Hold thefront brake ALWAYS when shifting a cold bike into first. ... What I do on cold starts is to select first gear with the motor off, pull the clutch in and ...
How To: Fix 5 Common Bike Issues ' RideApart
https://rideapart.com/articles/fix-5-common-bike-issues
Jul 21, 2014 - It's easy to assume the worst when your bike isn't opperating perfectly, ...Where's my ignition! ... First, ensure the battery is good and that the engine turns over.... Try starting with the kickstand up, clutch in, and bike in neutral and see if the ...goes away most the time when the bike is put into gear or revved.
Checking Your Yamaha Ultramatic Drive Belt - YouTube
? 9:35
https://www.youtube.com/watch?v=vgh4TzSgCB0
Oct 9, 2010 - Uploaded by 6speeddakota .
Jan 19, 2016 | 2006 Yamaha Stratoliner S
Clutch gl1000 honda creeps when put in gear hard to find nuatral sat 10yrs
Get car oil out - friction reducing properties ruin wet clutches - put bike oil in
Make sure cable is adjusted properly
Plates may get stuck together after time unused - see my tip for quickly releasing seized clutches
Ride Safe
Bike-Doc
Jan 07, 2012 | Motorcycles
I can start the bike but when I shift into low gear the bike stalls The bike runs perfect but will not run when put into gear.
Could it be that the bike stand is lowered there is a micro switch on these that kills the engine if you try put the bike in gear with the stand down
Aug 01, 2011 | 1997 Suzuki LS 650 Savage
I need to modify my bike like an imported bike please suggest me the ideas to put parts of imported bike in my bike,and can i put NOS in my bike?
Hi , I even had pulsar black and i did the following . And to be honest almost appreciated my effort
  1. 2 piece handle bar
  2. Put bike fairings that suits ur bike color .
  3. Replace the back wheel with a wheel that has a broad wheelbase
  4. increase the Height of the seat .It can be done by replacing the metal rod that is right above the suspension .it's height will be more compared to the normal one ..
  5. Fit a good air filter of ur choice for pick up and of course pick up .
  6. Take off the mirrors and saree guard .
  7. Stickering also change the look and feel of the bike
Aug 23, 2010 | 2007 Bajaj Pulsar 150
I put bike in reverse gear engine revs up but will not reverse
When you say you put bike in reverse gear, are you twisting the reverse gear switch? is the bike in neutral? and are you operating the engine start switch to make the bike go in reverse? This machine operates in reverse by using the starter motor.
May 19, 2010 | 2000 BMW K 1200 LT
With the bike in gear and the clutch engage, the
Clutch discs are stuck, put the bike in gear, not running, pull in the clutch and push the bike back and forth to break the clutches loose. Once they break loose start the engine put the bike in gear, hold the front brake, and slip the clutch a little to remove any built up or stuck crud on the plates.
Mar 10, 2010 | 2000 kawasaki VN 800 Vulcan Classic
InSTEP Quick N EZ Bike Trailer Logo
1,013 people viewed this question
Top InSTEP Sport & Outdoor - Others Experts
oldhess
ray gallant
Bill Boyd
Are you an InSTEP Sport and Outdoor - Other Expert? Answer questions, earn points and help others
