Question about Yamaha HTR-5440 Receiver
No sound from left fronts (A+B) in TV mode.
Last evening I noticed the left fronts (A+B) were not playing when I had the TV mode on. I initially moved the speaker to the other side and it worked fine. Placed it back in its original location and no sound. I played my IPOD through the AUX mode and both lefts sounded great. I did the same with the CD, Tuner and the DVD and the left fronts worked perfectly. I'll be pulling the entertainment center (huge) away from the wall this evening - other than ensuring my audio cable (TV-AVR) is not half pulled out. Is there anything else that I can check?
  • wnewman447 Jun 18, 2009
    MNfisherman!
    Sincerely appreciate your feedback.
    I'll be troubleshooting with your input this evening. Really appreciate the additional input regarding the resistor.
    Thanks again!
  • 11,896 Answers
Just check the rca cables. Try wiggling the cables as well. If they are the plastic rca cables, they do to wear out quick.
If it is not the cables, than it is a shorted resistor in the channel sound output
Posted on Jun 17, 2009
Tv does not turn on
If green light flashes more than 8 times, it could be as simple as repairing or replacing the power supply. Unplug the TV ,remove the back. Look for bulged or leaking capacitors on the power supply. Do it yourselfer? only if you have soldering skills, or purchase replacement board. remember, used boards are just as old as your failed board, buy new or rebuilt, Good Luck
Feb 17, 2014 | LG Televison & Video
Lost sound through tv/sat mode
Try unplugging all of the equipment for 30 minute to an hour, and see if this fixes it, otherwise, it sounds like the flickering power may have caused a surge in the circuitry of the equipment, causing it to short circuit the digital tuner in the TV.
Feb 23, 2008 | Pioneer VSX-D498 Receiver
Bought a LG Blu ray DVD Home theater system last weekend and set up with LG lcd tv and has been working fine till today. We had the radio on and I turned the TV on and the two rear speakers do not work...
In a surround sound system, the correct way to listen to music is in stereo mode which will play out of your left and right channels and your subwoofer. When viewing a movie with surround sound, then you should use your rear speakers. The key element to remember is that rear speakers are only intended to play your sound effects, and will not play full range audio. Thats what your fronts and center are for. If you simply want to override this, than you will need to select the direct sound field on your receiver and than it will send full range audio to all speakers connected. Most likely, its not going to sound that good. If you dont know what each sound field does, here is a list and function of the most commonly used ones.
Stereo-Front Left and Right speakers including subwoofer
Dolby Digital or PLII Movie-these are the bost options for your surround sound
Direct-All speakers connected get full range signal
Good Luck
Jan 07, 2011 | LG Audio Players & Recorders
Reciever only allows 2 channels(speakers) at a time.
If the amplifier is not receiving a surround sound signal, you will get nothing from the rear speakers and probably nothing from the front centre. Play a dvd in dolby surround and it will work.
Apr 14, 2017 | Pioneer VSX-918V Receiver
I had this problem too. Finally, after using the MCACC setup and making sure all the speakers worked, I found I had to set the source to FM, TV or whatever from the remote control and set the mode to advanced surround sound using the front panal button on the upper right. Had to fool with them a lot. Good luck.
Jan 03, 2009 | Pioneer VSX-818V-K Receiver
HTR-6130
Read your instructions book again, when you press 7 that mean you are enter in select speakers you must use 7 then narrow UP DOWN and LEFT RIGHT when you finish you must save by press SET
The easy way to set it up is connect your receiver to TV then you can see the complete MENU on your TV screen
Or you initializer the unit to go back to the default mode, which will set to 5 speakers if you wish to do this look on same model I was post earlier how to initializer the receiver
Nov 28, 2008 | Yamaha HTR-6130 Receiver
How to hook up additional speakers to the TV
If you have a surround sound system, (amplifier and speakers), run the DVD speakers out wires to the amplifier IN. Thi way, you don't even need the TV speakers.
Jul 26, 2008 | Sansui HDLCD3200 TV
Surround sound
Hope this helps,
you need to press system menu on the remote..
on the front panel display acually on the DAV unit "DEC. MODE" appears..
Press enter..
Press the up and down buttons to cycle through the options, what your looking for is "PRO LOGIC", "PLII MOVIE" and "PLII MUSIC" ..
Select one of these and this should work.
All the best
Jun 25, 2008 | Audio Players & Recorders
Yamaha HTR-5440 Receiver Logo
151 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
