Question about IOGear USB gcs1734 4-port KVM Switch
Can't switch ports using PC keyboard
I have a 4 port IOGEAR's MiniView™ SE GCS84B. I can't seem to switch between the connected ports using my keyboard.
  • 30 Answers
The GCS84B uses a tricky hot key command sequence. It use Alt + Ctrl+ Shift + the port number + Enter. Do not hold these keys down like you would for a Ctrl + Alt + Delete command. Quickly tap these keys using the keys on the same side of the keyboard. Meaning if you start with the left Alt key the also use the left Ctrl and left Shift. When selecting a port number use the number keys above the letters and not the number pad. Also this key sequence must be completed rather quickly.
Posted on Sep 02, 2009
  • 57 Answers
Make sure that your keyboard is connected to the keyboard port of the switch. The USB ports on the switch has pictures that indicates where the keyboard and mouse should be connected.
The hotkey combination is CTRL + ALT + SHIFT + Port no.(1,2,3 or 4) + ENTER
Note: "tap the keys one at a time and not at the same time"
Posted on Jun 24, 2009
With GC S62 2 port KVM switch, can I transfer data from one computer to another. If so, how can I do it?
A KVM switch just allows multiple computers to share one keyboard, mouse and monitor. It doesn't allow the connected computers to communicate with each other. So no, it won't allow you to transfer data. If you want to do that, you'll need to connect the computers via a network (through a 4-port router, for example), or use the old-fashioned method of transferring files manually using a flash drive.
Dec 26, 2010 | IOGear MiniView GCS62 2-port KVM Switch
I have iogear miniview kvm (gcs62) keyboard works but mouse conn does not. Mluse is usb mouse with ps/2 adapter. Direct connection via usb works. used to also work with adapter but having tried it with kvm...
USB mouse with PS/2 adapter is not guaranteed to wok with GCS62. This KVM switch is designed to work with PS/2 keyboards and mice only.
When the USB mouse with PS/2 adapter is used in a computer directly, it will surely work, because the USB port can give enough power for the mouse to work. And it can easily convert the signal.
Unlike in KVM switch, the switch serves as a bridge between the mouse and the computer. And the computer does not easily recognize the mouse.
I would suggest to use a regular PS/2 mouse. Or if you want to use USB keyboard and mouse, you need to have a USB KVM switch. Model GCS632U.
Thank you and good luck!
Jan 21, 2010 | IOGear MiniView GCS62 2-port KVM Switch
Repeated IOGear KVM switch failures
As a wild guess, it sounds like a static discharge MIGHT be affecting the switcher causing it to crash.
Try increasing your humidity to 40% and grounding yourself before touching the keyboard... This is the season for these static electricity problems... get nipped all the time and you MAY not even feel it to be enough to zap the switch.
Jan 11, 2010 | IOGear MiniView GCS62 2-port KVM Switch
Hooked up a iogear cgs62 wont allow me to log onto
II had one of those with no problem at all other than many KVM's dont allow you to use some of the many extra keys you get on some of the better keyboards. If thats what you mean by connect to internet then its a common drawback of cheaper end KVM's even some of the better ones dont support fancy keyboard buttons.
Aug 09, 2009 | IOGear MiniView GCS62 2-port KVM Switch
GCS62 - both computers must be on for this thing to work?
It seems that you KVM switch is not working properly. computers connected to a KVM switch are not dependent to each other. you should be able to work on any of your computers while the others were turned off.
Jun 06, 2009 | IOGear MiniView GCS62 2-port KVM Switch
Laptop will not connect properly
If possible directly connect the KVM cables to the laptop computer. Try to avoid connecting the KVM cables to a docking station. Also if your KVM has manual port selection buttons on the front of the KVM try holding that button for about five seconds when switching ports.
Jun 02, 2009 | IOGear MiniView III GCS1712 2-port KVM...
IOGEAR KVM SWITCH WILL NOT TOGGLE BETWEEN COMPUTERS
On my KVM switch it works pressing
Scroll lock key twice then
press up or down arrow
to toggle
Apr 11, 2009 | IOGear MiniView GCS612A 2-port KVM Switch
Howto switch between computers with iogear gcs612a
A probably solution is to press the "Scroll Lock" button (usually at the top-right of the keyboard) twice in quick succession. Give it a try!
Mar 30, 2009 | IOGear MiniView GCS612A 2-port KVM Switch
Wobbly screen on mac laptop
are you using a Mac Mini-DVI to DVI adapter or any adapters? This is a VGA video output type of KVM switch so probably the problem is with the adapters involved to it.
Nov 19, 2008 | IOGear MiniView GCS62 2-port KVM Switch
IOGear GCS62 2-port switching problem
I have a similar IOGear KVM switch. I use the Scroll Lock button twice to switch between PCs.
Hit the Scroll Lock button twice see if that does it for you.
Feb 09, 2008 | IOGear MiniView GCS62 2-port KVM Switch
IOGear USB gcs1734 4-port KVM Switch Logo
908 people viewed this question
Top IOGear Computers & Internet Experts
Jose Velazquez
Jose Velazquez
Victorman
Victorman
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
