Car Audio & Video Logo
J
JohnRThomas Posted on Apr 11, 2014
Jeep infiniti wiring diagram 56038407AD
The amp cost me only $10. SUCH A DEAL. Red/White is 12 volts? How does it connect?
3 Related Answers
Anonymous
  • Posted on May 16, 2009
SOURCE: need wiring diagram 94 jeep with infinity sys and amp
http://www.jeepforum.com/forum/showthread.php?t=507916
has the wire harness information for the amp. very hard to find great photos. the radio should have the sticker on the back telling you what the wires are designated for.
xxxxxx xxx
  • 5110 Answers
  • Posted on Mar 19, 2011
SOURCE: Ok I have 12 volts
Too much current (amps) being drawn ..and is dropping the voltage.
Usually due to a failing battery.
Does it maintain the 12v or more with the engine running?
Ironfist109
Iron
  • 3018 Answers
  • Posted on Aug 15, 2011
SOURCE: I have a 1994 grand
  • Hi, I can help.
  • This will be the wiring diagram for the Infinity Gold that came in your Jeep Grand Cherokee.
  • And this is the wiring diagram for the KDC - 515S
  • If you have any comments please feel free to leave them here and I will respond to you.
  • Hope this helps and thank you for using FixYa.'
Regards, Tony
1helpful
NEED WIRING DIAGRAM FOR SONY CDX-GT520U
red - ignition switched 12 volt
yellow - constant power 12 volts
black - ground wire
orange - dimmer wire don't use
speaker wires
drive side front
white +
white/black strip -
passanger front
gray +
gray/black strip -
drivers rear
green +
green/black strip -
passanger rear
purple +
purple/black strip -
blue - remote amp turn on wire
blue/white strip - either power antenna or remote amp turn on also
[email protected]
1helpful
2answers
How to disarm or reset an alarm system for a 1996 Jeep Cherokee?
Hope this helps:- Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm.
Cavity/Fuse Diagram (1996 Grand Cherokee, passenger side kick plate to find, Owner's Manual pgs 205-206): 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
Row 1: 1-6 (left to right) Row 2: 7-12 Row 3: 13-18 Row 4: 19-22
1996 Jeep Grand Cherokee Fuse Panel (Passenger Side kick panel) Reply
CAVITY FUSE DESCRIPTION 1 -10 amp (RED) Radio 2 -15 amp (Lt Blue) Cigarette Lighter 3 -10 amp (RED) Rear Washer Switch, Body Controller 4 -10 amp (RED) Airbag 5 -10 amp (RED) Lamp Out Module, Overdrive Switch, OBD II 6 -15 amp (Lt Blue) Vehicle Information Center/Graphic Display Module Park & Side Lamps, Overhead Console Lighted Visor, Automatic Dimming Mirror 7 -20 amp (Yellow) Body Amp, Cluster, Body Controller 8 -20 amp (Yellow) Rear Wiper Motor, Flipper Glass Solenoid, Cargo Lamp, Trailer Tow 9 -15 amp (Lt Blue) Brake Switch 10- 10 amp (RED) Rear Window Defroster 11 -10 amp (RED) ABS Module 12 -10 amp (RED) Heater-Ventilation-A/C Control & Recirculation Motor 13 -15 amp (Lt Blue) Hazard Switch, Turn Signal Switch 14 -15 amp (Lt Blue) Spare 15 -15 amp (Lt Blue) Spare 16 -10 amp (RED) Right & Left Courtesy Lamp, Glove Box Lamp, Halo Lamp Cargo Lamp, Underhood Lamp, Dome/Read Lamp Right & Left Visor, Automatic Dimming Mirror 17 -15 amp (Lt Blue) Radio Illumination, Tail Lamp, Graphic Display Module, Park & Side Lamps, Headlamp Switch, Body Controller 18 -20 amp (Yellow) Spare 19 -15 amp (Lt Blue) Passing Light 20 -15 amp (Lt Blue) Radio, Heater-Ventilation-A/C, Vehicle Information Center 21 -15 amp (Lt Blue) Power Outlet 22 -10 amp (Blue) Airbag Module -------------------------------------------------------------------------------------
1996 Jeep Grand Cherokee Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness Tach Gray/White Coil Brake Switch White/Tan Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights Blue/Red (+) Left of Steering Column or Light Switch Head Lamp Tan/Black Light Switch Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm. Door Trigger Yellow (-) Driver's Kick Panel see notes Door Lock 5/Wire in Driver's Inside Driver's Door Orange/Purple Lock Pink/Black Unlock Door Unlock and Passenger's Doors Inside Passenger's Door Black/White L Pink/Black Unlock Horn Wire Gray/Orange (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Doors Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
• Cruise Control Information • Stereo Information • View all Jeep Vehicles
3helpful
2answers
I have a 1996 Jeep Cherokee and the heater vents dont work.I have tried to find a picture of the fuse panel i can read but i cant..When you swith it to vents it only comes out of the defrost.Where can i...
Hope this helps:
1996 Jeep Grand Cherokee Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness Tach Gray/White Coil Brake Switch White/Tan Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights Blue/Red (+) Left of Steering Column or Light Switch Head Lamp Tan/Black Light Switch Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM Door Trigger Yellow (-) Driver's Kick Panel see notes Door Lock 5/Wire in Driver's Inside Driver's Door Orange/Purple Lock Pink/Black Unlock Door Unlock and Passenger's Doors Inside Passenger's Door Black/White L Pink/Black Unlock Horn Wire Gray/Orange (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Doors Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
• Cruise Control Information • Stereo Information • View all Jeep Vehiclesairconman.jpg
8helpful
Wiring diagrams for clarion dxz535 car stereo
Here's how it goes:
Speaker wires:
grey=right front pos.
grey/black=right front neg.
white=left front pos.
white/black=left front neg.
violet=right rear pos.
violet/black=right rear neg.
green=left rear pos.
green/black=left rear neg.
red=12 volt switched power source
yellow=12 volt constant power source (direct to battery)
black=chassis ground
orange/white=illumination (switched source,not to head light switch)
blue/white=amp turn on lead (to remote turn on lead of amp)
blue=auto antenna (switched power source)
brown=phone mute lead (to cell phone mute lead)
RCA connector leads:
grey lead:
red=right front
white=left front
black lead:
red=right rear/right rear subwoofer
white=left rear/left rear subwoofer
(connect to external amp)
red lead:
red=right aux input
white=left aux input
(connect to external unit)
green lead:
red=right dual zone output
white=left dual zone output
(connect to wireless head phones)
That should be all there is. on the yellow that goes direct to the battery you need to use an inline fuse holder with 30 amp fuse.
I need to know,when adding a ampliffier to the factory deck to a 2008,nissan altima.what wire do you connect the remote wire from the amp to?
Here is the diagram but make sure because this car has an amp. installed. To check the right wire you have to use a volt meter and check if you have 12 volts. at this wires (Blk/Pnk or Blk/Grn) as soon you turn the stereo On
2008 Nissan Altima Car Audio Wiring Diagram
Battery Constant 12v+ Wire: Yellow/Red
Accessory Switched 12v+ Wire: Violet/Yellow
Ground Wire: Chassis
Illumination Wire: Red/Blue
Dimmer Wire: Red/Yellow
Antenna Trigger Wire: Black
**Amp Trigger Wire: Black/Pink or Black/Green**
Amplifier Location: Under the Rear Deck
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White
Left Fron Speaker Negative Wire (-): Black
Right Front Speaker Positive Wire (+): Green/White
Right Front Speaker Negative Wire (-): Brown
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Orange/Black
Left Rear Speaker Negative Wire (-): White/Red
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Black/White
2answers
Have no spark. Changed coil & CDI box so far. still no spark. Is it the internal coil? 1989 enticer 400T/R
Hi and welcome to FixYa,
Initially, suggested checks on the wires:
  • black of igniter unit tied to ground;
  • orange wire from igniter to ignition coil with pulsating voltage when starting;
  • gray wire from igniter to ignition coil with pulsating voltage when starting;
  • IGN + 12 on red/white wire to igniter and ignition coils from engine stop switch;
  • IGN + 12 on red/white wire to engine stop switch coming from 10Amp ignition fuse;
  • pulsating low voltage from pickup coil between the wires black/white, white/green & yellow/red.
Postback results of above voltage tests.
Good luck and thank you for asking FixYa. Happy Holidays.
2answers
Red,black,green and white wires. what does what?
In a 12 volt system, generally, red is 12 volt +, black is 12 volt - or ground, green is ground, and white could be anything.
However, there are literally dozens/hundreds of colors/schemes used in an automobile's electrical system, and the above can't be expected to hold. Best way to get info on the wires is with a circuit diagram or just by tracing/testing with a multi-meter.
Charlie
6helpful
2answers
I need a wiring diagram for this stereo
FOR 16-PIN HARNESS
Pin Number Wire Color Function 1 White Left Front (+) 2 Green Left Rear (+) 3 Violet Right Rear (+) 4 Grey Right Front (+) 5 Blue/White Amplifier Remote 6 Blue Antenna Remote 7 Red Accessory 12 Volts 8 Black Ground 9 White/Black Left Front (-) 10 Green/Black Left Rear (-) 11 Violet/Black Right Rear (-) 12 Grey/Black Right Front (-) 13 Sky Blue Telephone Mute 14 Orange/White Illumination 15 Not Used Not Used 16 Yellow Constant 12 Volts
FOR 9-PIN HARNESS
Pin Number Wire Color Function 1 Not Used Not Used 2 Black Ground 3 Grey Right Positive 4 Grey/Black Right Negative 5 Blue/White Amplifier Remote 6 Red 12 Volt Switched 7 Yellow 12 Volt Constant 8 White Left Positive 9 White/Black Left Negative
MAY THIS HELP YOU
Can I use a Chrysler/Infinity amp with aftermarker JVC radio?
it wouldn't be advised unless there are rca connections into the amp. these are the same as the inputs in the back of the jvc. It is possible to connect into an amplifier using speaker cable but i wouldn;t advise doing this unless you know what your doing.
4helpful
Pioneer deh-2000r wiring
Pioneer usually use:
red - 12 volt batt. ignition/acc
yellow - 12 volt batt. memory
black - ground
blue - power ant.
blue/white - amp turn on
orange - illumination ( 12 volt light ) ( not all deck )
orange/white - dimmer ( not all deck )
gray - right front +
gray/black - right front -
white - left front +
white/black - left front -
violet - right rear +
violet/black - right rear -
green - left rear +
green/black - left rear -
Is this what your looking for?
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
