Question about Carrier Heating & Cooling
My central air pooched last night.... I am hot and miserable... LOL but anyways... the outside unit makes a noise when I turn it on but the FAN does not spin at all.... any idea what it might be?
  • 334 Answers
Depending where the noise is coming from. If you can be next to the unit as it starts see if the noise is coming from the fan or control panel (where the electric is going into) and how loud is it. I would venture to say that it is probably the fan motor, you will hear it if you are there.
Posted on Jun 17, 2009
Central air conditioning unit
you must do the maintenance . Call to the tech for to make the maintenance required. to due the activity of work.
God bless you
Jul 19, 2013 | Vehicle Parts & Accessories
Lennox central air for home not kicking on. Fan on the outside not spinning but motor is making a humming noise. No cold air coming in home. We have circuit breakers they are turn to the on position. ...
Is the indoor fan working? The problem with the outdoor fan sounds like it could be your capacitor. Turn off the power to the outdoor unit and make sure the fan turns freely using a screwdriver or something that will reach the blades. If it turns freely then it is probably the capacitor. Let me know what you find.
Aug 25, 2010 | Goodman CLT36AER36 Air Conditioner
I have a whirlpool quiet miser, ACE082XSO that is cooling fine, but makes quite a lot of tinnie rattling noise when I listen to it run on the outside of our bedroom. is there a fix for this noise problem...
Normally a sound like this is vibration or the fan making contact with the casing. If you pick up on the unit a press on it in different places and the sound goes away it i vibration. If its the fan there will be evidence on the edges of the fan blade. You can also turn off the power and slowly turn the fan and see if it hits. Just remember sometimes just moving the unit around will make a nois start or stop. good luck
Aug 09, 2010 | Whirlpool Heating & Cooling
I have a Frigidaire cooling and heating unit. Last night we had freezing rain and ice. I heard a weird noise coming from the unit then smelled a burning smell. I turned the unit off. The top vent...
Sounds like the motor burned up when the ice blocked the air which it was not able to cool the motor it will need to be replaced. (the motor)
Jan 29, 2010 | Heating & Cooling
Oustide unit fan won't work
It sure sounds like the out side condenser fan has gone out.If you need to Fix a water hose to run on it like a spray fanning out over the out side coils(condenser)and try and see if it will cool.It will do the trick,until you get it fixed on week days.If I can help,let me know.>>>roniecon@gmail.com
Aug 16, 2009 | Goodman CLQ36AR49 Air Conditioner
My a/c system is blowing hot air; outside fan is not engaging
First check for line voltage 240v...if thats good .check for burnt wiring at fan capacitor.if you hear the compressor humming but still no fan you may need a fan motor.. when buying your new motor make sure to match horsepower and r.p.m
Jun 22, 2009 | Weather King 10AJA3601AH Air Conditioner
Central a/c
check to make sure that the kids didn't change any other settings. Is the themostat still set for cold not hot? Also check the temp setting. Hope this helps.
Sep 11, 2008 | Heating & Cooling
Our central air conditioning unit is out. The outside unit makes a straining noise but the fan does not turn. I can manually turn the fan blades.
Sounds like a start run capacitor. The motor may be bad too. The capacitor will look bloated if it is bad. There may be other reasons for these parts to fail. So please call a licensed technician for professional help.
Jun 17, 2008 | Heating & Cooling
Central ac blowing hot air outside fan not moving but making a noise
This is nothing but an either or -or ! First, make the thermostat calls for cool, there are suppose to be 2- noise outside, the fan motor and the compressor (and if a old system,a humming noise which is the contactor coil which picks up the main 240-volts).. hurry up and take a stick or something and turn the fan blades, if it picks up speed and run, then its the capicator. If not then the fan motor is bad.! (BOTTOM LINE)!
Jun 09, 2008 | Heating & Cooling
Heating & Cooling Logo
94 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
