Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
No suction from upholstery attachment
I have attached the upolstery hose to the tank and I can get the solution out, but I am not getting any suction to take the solution off the couch.
  • 25 Answers
Http://www.hoover.com/pdfs/manuals/F5914900.pdf
Problem: Low suction
Problem: Clean solution won’t
dispense
Problem: Brushes/brush indicator
won’t rotate during floor cleaning
Possible cause
Possible solution
• Not firmly plugged in
• Plug unit in firmly
• No voltage In wall plug
• Check fuse or breaker
• Blown fuse/tripped breaker
• Replace fuse/reset breaker
Possible cause
Possible solution
• Recovery tank full/automatic
shut off engaged
• Remove and empty recovery tank
• Blockage In tool on end of hose
• Remove tool and clear blockage
• Recovery tank lid not on
correctly
• Make sure lid is on securely
• Recovery tank front panel not
replaced after stair or upholstery
cleaning
• Replace recovery tank front panel
(page 14)
Before using tool
It may be necessary to remove air from
the system (“prime the pump”) so the
clean solution will flow to the tool. Follow
these steps:
1. Attach tool to hose and turn the carpet
cleaner ON.
2. Put the tool on a hard surface or
against your hand to block off the suction.
3. Wait a few seconds (can take up to
15 seconds). Then squeeze the trigger
and begin cleaning.
GOODLUCK!!!!
Posted on Jun 21, 2009
It will not pick up the water. Help !!!!!
Problem #1 - My Steamvac is not Sucking!
If your Hoover Steamvac was working properly and suddenly it is not sucking any water, nine times out of ten, the culprit is the lid on the lower recovery tank. The lid on the lower tank (or dirty water tank) needs to hinge at the front and snap down at the back in order to creat a proper seal. If the lid snaps on but is not locked on at the front, you will not get any suction. Simply take the lid off, and ensure that when you put it back on, it must hinge on the front tabs of the tank.
Problem #2 - My Steamvac is still not Sucking!
Right now you are thinking that you shouldn't have let your brother borrow your Steamvac. And you are right, because he used the hose attachment and returned it with the hose still attached to the front of the tank (some models only). Now when you try to use it there isn't any suction. In this case, you are missing your tank duct. On models where the stair/upholstery hose attaches to the front of the recovery tank, one must remove a square plastic piece in order to attach the hose. This square plastic tank duct must be replaced before the Steamvac will operate properly in the upright position. hope this helps ive copied it
Oct 09, 2016 | Vacuums
Why will my hoover spin scrub steam vac upholstery attachment not suction?
With this model, check all hose connections and recovery tank lid. if you have good suction before you put on the tool it may be the tool that needs service. inspect the tube under the recovery tank for the round gasket and the filter inside the tank.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Aug 26, 2014 | Hoover SteamVac F5914-900 SpinScrub...
How do you attach upholstery hose
The upholstery hose attaches to the front of the recovery (lower) tank. There is a square plastic duct which must be removed, or folded forward on recent models; and the end of the hose slides into the front of the tank. Be sure to replace the lid on the dirty water tank correctly. The connector on the soap tube attaches to the valve under the trap door on top of the nozzle.
Jan 22, 2011 | Hoover SteamVac F5914-900 SpinScrub...
My bissell pro heat 2x does not **** up the water from either the upholstery cleaner or carpet cleaner. Any thoughts as to why? The water and heat functions work it just does not pick up
First check the motor duct gasket. The motor duct gasket is visible once the tank is removed. It is located underneath the handle on the top of the base of the machine. It has a black rubber coating around it. If there is no suction there please let us know. If your machine does have suction at the duct, continue to check the following:
- Ensure the Ready Tools Dial is set to the appropriate setting (Floor Cleaning or Hose Attachments).
- Remove the tank from the machine and ensure the tank lid is attached properly. The front window must first hook onto the lip of the bottom of the tank and then drape over the tank. Latch the bottom tank to the top tank lid. THIS LID CANNOT BE ATTACHED PROPERLY IF THE TANK IS NOT REMOVED FROM THE MACHINE.
- Make sure the Water Tank is not full on the outside of the bladder. If it is, empty the tank.
- Ensure the hose is firmly attached to the back of the machine. If not, re-insert as necessary by twisting into place.
- The machine must be in an upright, locked position and set to the Hose Attachment setting. If the handle is slightly tilted back while using, it will create a small gap at the suction inlet (where handle meets gasket, above the Bottom Tank) which will cause little or no suction.
- Check the red Tank Lint Screen for debris. If the Lint Screen is dirty, the unit will have poor suction. Clean the Lint Screen if necessary.
- If the float flap door in the tank lid is activating prematurely when you turn the machine on, this flap door should be replaced. This tank may need to be emptied.
- Check the Tank Lid and Tank for damage.
Aug 13, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have used my Steam Vac for carpeting, but until today, had never tried cleaning upholstery with the spin-scrub brush. I spent a miserable afternoon trying to control the spray, which seemed to go...
I can sympathize. My vac came with two handheld attachments. I have better luck with the handheld attachment that doesn't have the spin-scrub pads. To keep the water from going all over the place, you need to keep the part the you hold only about 1 inch from the surface of the upholstery; if you hold it higher it gets everywhere; if you hold it lower the spray doesn't spread out wide enough and it just makes big water droplets that roll down the upholstry.
If the vac isn't sucking up the water, it is likely you have it set up wrong. Take off the attachment; if you put your hand over the open end of the tube, do you feel suction? When you are using the handheld attachments there is a rectangular piece you remove (attached to the dirty water tank) and you stick the rectangular part from the hose in there. If you are getting suction but it's just not sucking up any water try these 1) maybe you aren't laying down enough water, spray it more heavily OR 2) you need to **** up the water right after you lay it down. Don't let it soak in for more than a few seconds.
good luck!
Aug 17, 2009 | Hoover SteamVac F5914-900 SpinScrub...
How do i attach the upolstery attachment?
Go to www.Hoover.com Click on carpet cleaners. Click on steam vac all terrain. Click on Learn more. Click on Download Instruction manual in pdf. It explains all. The hose is attached on the front of the recovery tank. under the hoover symbol.
Jan 30, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Eureka Atlantis 2591A Extractor - Won't spray
Hard to say without seeing it, is there a function type knob that you would switch from carpet to hose? Did the hose attachment lid close ok? Other then take, if this is new, it has a years warranty on it, just take it to a waranty shop for repair.
Apr 20, 2008 | Eureka Atlantis 2591A Upright Steam Vacuum
How do I attach the upholstery attachment to the Hoover Steam Vac F5910-900?
I assume you have a Hoover there. The hose only goes into the top of the tank. The opening of the hose is supposed to connect with the tank lid to deliver suction to the hose. I'm assuming that you think the hose is supposed to connect to the duct on the hood. The hose does not go down that far. I hope this is what you need to know. I am assuming alot here.
Feb 18, 2008 | Vacuums
Upholstery conversion
Take out the duct in front of the tank (#3), the hose end will have a duct on it that you insert in its place. This provides the suction for the hose. Don't forget to put that duct you took out back in place, or you won't have suction when you use the steam cleaner.
Nov 21, 2007 | Hoover F5888-900 SteamVac Upright Wet/Dry...
Hoover Upright SteamVac Deluxe with stair and upholstery cleaner
Don't listen to Solution #1, it is simply NOT correct. This is the correct answer:
As you stated, you already know where the water hose connection is. It is under the easily visible port cover on the top of the base.
What is NOT easily visible is the connection for the vacuum hose. That's because the machine needs to be "reconfigured" before the hose can be attached. To "reconfigure" the machine:
1) Remove the cover off the waste water tank and notice how things appear--it will soon be important.
2) Find and remove the "panel" on the front of the waste water tank by sliding it straight up and out.
3) Replace the panel with the connector by sliding it straight down. When finished the top should look something like it did in step 1). This assures that the dirty water will be vacuumed into the waste water tank.
Done!
Oct 23, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
694 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
