If the release valve referred to is the pressure release valve, then a water leak out the attached vent pipe is an indication that the valve is failing. To change the valve, the water must be allowed to cool (turn off AC power or gas) and the water level inside the tank must be lowered (drained) to below the level of the pressure relief valve. Once this is accomplished the vent pipe is unscrewed from the relief valve and the pressure relief valve is unscrewed from the water tank. A new pressure relief valve with a sealant on the threads, is then screwed and tightened into place with the outlet port facing downward. The vent pipe is attached to the new valve and the tank refilled with water. A hot water facet must be opened to allow air to exit while filling. Upon becoming full (water will begin to flow from facet), turn off the facet and restore AC power or gas, therefore allowing the water heater to heat up. When the first hot water is utilized there may be some air expelled from the facet.
If this is a new hook up some one has got the two water pipes hooked up on the wrong sides If it works that way might be as simple to use a black marker then remark each side. Save a lot of work as well someone won't make a mistake some day and get into trouble.
your boiler needs a minimum gas pressure of 16 mb to light successfully. if your gas pipe has been extended it has to be able to flow enough gas. it may need upgrading to 28mm for even as little as a metre from the gas meter. if your central heating works ok when the fire is off then this is your problem
first check for loose pipes the you might want to add a damper on the pipe to absorb the hammering just t in a piece of pipe and make it go higher than the pipe with the noise and put a cap on topp of that
That is normal, the heat just rises from the hot water, the pipe on the right should be cold and if you were to run hot water anywhere in the house it will immediately cool of the cold inlet pipe and you can feel it
Check the heat exchanger. Often they and gummed up.& you will have to try & flush it out or replace. If this model has the cylindrical type, they are pigs to do. If this machine is 10 yrs old or more, you might find it better in the long run to have a new boiler Just a thought, but I assume that the valves on the 3/4 " central heating pipes are turned on Parts to look forward to later - fan £80 - pump £65 - heat exchanger £110 - diverter valve £65 - pressure relief valve £45
back boiler run from a gas fire? check the instructions to operate the gas heat to the back boiler not just the fire I presume that this a fully pumped system - air lock doubtful There maybe on/off valves on the pipes to and from the back boiler [situate close to cylinder] make sure they are on - anticlockwise turn or there could be a blockage in the outlet from header tank usually in the loft. or If there is no water in it maybe the mains cold feed it is off. Note if no water in it DO NOT USE the back boiler
gas valve could be clogged it has a screen in the side of the inlet, check this first if not it could be the gas valve itself,, make sure the gas valve is turned on also, sometimes people turn them off and for get the handle should be in line with the pipe not across the pipe
some times inside the boiler on the internal pipework you will see little sensors, on the central heating piping there sometimes is a thermastic sensor on side of flow pipe with a little reset button on ? i guess with the problem you said the poiler locked out and the pipe work overheated ? this is a safety feature on some boilers not, all and easerly reset via this button ?
yes it is possible toupgrade the system to a sealed one using a system boiler as you mentioned. the thing to bear in mind is to upgrade the radiator valves to pressure rated ones 10bar.
The probable cause of the over heating is down to the system being sludged up/cold feed blocked, or possible pump circulating problem?
I would recommend the installation of a magna clean filter to help keep the new boiler clear from system debris.I would definately power flush the system, if the system is a twin two port valve system then a automatic bypass should be fitted, all of this done by a corgi registered gas engineer
