Question about Compaq Computers & Internet
There is no output of sound
I can hear only system sound... when i play music it shows some error, it asks to download sound card
    Problem Solver:
  • 17 Answers
U prolly need 2 download the drivers 4 it
Posted on Jun 17, 2009
I cant play music it showing null soft sound output v2 6 d error
my dear
i think having a problem in your sound hardware
and 2nd problem i think in your software so 1st u must re stall the the drive of sound
OK
Apr 08, 2011 | Computers & Internet
Creative sound card! no sound!
Check whether you plugged in the speaker wire into the correct jack at the back of the computer (it should go into the green colored jack on the sound card).
Did you try playing a sound file? Does media player show the file as playing, but you can't hear anything? Or do you get any error? if there's any error, please mention the error.
If the sound plays but you can't hear anything, again, check the speakers are connected to the correct sound jack. Next, try connecting a pair of headphones or earphones (lower the volume before playing any sound  or music file).
If you still can't hear anything, click Start and type the command "dxdiag" in the Run box and then press the Enter key. In the dxdiag window, click the Sound tab. Check the Notes box, if it gives any error info. If your card is working, it should say 'No problems found." You can also test the sound using the "Test Directsound" button.
If you still can't hear any sound, you should check and reinstall your sound card driver manually after removing it first.
There may be other problems. For more information, check this nice blog post about sound problems.
Hope that helps.
Regards,
Raspal
Jun 14, 2010 | Creative Labs SB0400 Audigy 2 Value Var...
Low volume. doesnt seem to come out when playing music in a chatroom?
ok are your drivers for your sound card updated ? does the derict x show any error when you run the analytical scanning of your system? have you ran any chatt web page sound and cam testing at the chatt site your seeking to play music at?( Yahoo and MSN both have thier own sound and cam tests for thier chatters Hope this Helps Steve
Sep 30, 2009 | Microsoft Windows XP Home Edition
Error code 1b63:161b and 1b63:061b
Request to try the steps below;
1. Restart the computer and tap the f12 key as soon as it starts to boot up .
2. Select 'Diagnostic' from the boot menu. The computer will run its pre-boot assessment tests (PSA) before Dell Diagnostics starts. During the PSA you will hear some tones through the system speaker but this does not adequately test the audio hardware. Dell Diagnostics plays an instrumental piece of music complete with drums, so if you only hear some tones then you have only run the PSA.
3. Dell Diagnostics should open after the PSA tests, or you should see an option to open it. If you have ever reformatted your entire hard drive then Dell Diagnostics will no longer be there as an option. In that case run it from the Drivers and Utilities (Resource) CD if you have one.
4. Select 'Custom', then the audio tests. (At this point - after you have opened Dell Diagnostic custom - if you can't find the option to select the audio tests that is a symptom of a failed audio chip.)
5. The tests will run. Alternate between using headphones and listening to speakers in case only one signal path is working.
The tests will play some audio and ask you whether you heard it.
6. If you don't hear the music during the test it definitely means there is a hardware failure somewhere in the system. In this case Dell will repair the computer if it is still under warranty.
7.If you do hear the audio during the test but not when you boot back into Windows, that almost always means the hardware is okay but there is a problem with the audio driver or with Windows.
8. Error codes: If you answer 'no' to any question that the test asks you, the test generates an error code that can tell a Dell technician that you answered 'no' to that question. The test does not know the exact component that has gone bad. Before answering 'no' to a question, make note of the circumstances at that point so you will know in general what the error code means.
Regards,
Anirban Mazumdar
http://www.ikarmatech.com
Sep 09, 2009 | Dell (8H390) Sound Card
Sound program
is it movie or music?
if it is movie use g-spot to find out which codec is missing
http://www.free-codecs.com/download/GSpot.htm
if it is music check your soundcard and the options in windows media player
Jan 22, 2009 | Intel Premier Resources 4-Channel 32-Bit...
Download music sound scratchy
Updated audio codec is required for your system. Go to this link:
http://www.free-codecs.com/XP_Codec_Pack_download.htm
Download it. When a box appears, Click Run button to automatically install it on your system.
Best regards
Jan 13, 2009 | Acer (54.AA806.001) Sound Card
Bad direct drivers.
Dear sir,
I ahve problem like My laptop is C700 series of compaq(C772TU) I ahve changed it OS from vista to XP and now there is no audio output whenever I try to play a song it gives msg like " Please installproper device or select another device in configuration Error code: 88780078"
please suggest me proper solution
Mar 22, 2008 | Computers & Internet
FAILING TO PLAY MUSIC
You have deleted your sound card drivers when you reinstalled windows. You'll need to visit the manufacturers website, go to the support & downloads section, find your model and download the drivers. Try going to Start - Control Panel - System - Hardware - Device Manager - then right click any yellow question marks and choose Update Drivers from the list. When asked, let windows search online for suitable drivers and click next. If Windows fails then you must get the drivers from the manufacturer's website. If you can't find it then post all the details of your sound card (from device manager) here and someone will help you. Best of luck!
Feb 20, 2008 | Computers & Internet
Love the system...
The e-mu sure can do it. You just run whatever output you want into the input on the sound board. The setup is exactly the same as if you just wanted to play winamp music on the system.
It's your computer that can't handle it. Computer only has one sound output, so you can't play two separate things in two separate instances of winamp, because the sound only comes out of one place on your laptop.
You can buy a second external sound card, like the SB Live External USB Sound card, and maybe run both at the same time, having one winamp output to the external device, and the other winamp output to the laptop's internal sound card device, then one line runs to your e-mu system and the other to a pair of headphones.
Or you can bring another laptop in ;)
Jan 21, 2008 | E-Mu 1616M Sound Card
Computers & Internet Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
