Wow, great device kudos on it still working. As for the eject - look for a pinhole which you can insert a paperclip into if it is a tray loader.
Testimonial: "thanks for the kudos--it is a nice machine. yes it is a tray loader. can't find a pinhole on the front of the machine. is it somewhere else?"
Not sure - we're talking 30 years old. You may have to take it apart in the end. Don't worry too much though, 30 years ago things were built tough.Not sure - we're talking 30 years old. You may have to take it apart in the end. Don't worry too much though, 30 years ago things were built tough.
You could try contacting Magnavox direct - they might get a kick out of it -http://www.magnavox.com/support/contact_...You could try contacting Magnavox direct - they might get a kick out of it - http://www.magnavox.com/support/contact_form.php
You can't post conmments that contain an email address.
Hi
I assume you are saying there is a disc stuck inside your machine?
• Have you tried: using the eject button located upper right on your keyboard? Hold it down for 4-5 seconds.
• dragged the Disc-image to the trash?
• if this fails you can try using the Disc tool located in your Applications folder.
• If all else fails, try restarting the machine while holding down the mouse button. This will eject discs. After the disc is ejected let go of the mouse button and the machine starts normally.
• If even this fails you will have to try manually - the "straighten paper-clip method" There is a mechanical lever at the very side of the hole where you insert the disc that can be used to push the disc out. I would reccomend to check your manual for further instructions on this.
Unplug pc, open cabinet and look for dust and debris , clean with compressed air. If it's still dirty use 50/50 distilled water and alcohol with a swab. Allow 30 minutes before plugging back in.
First try the normal methods to remove the disc. Drag its icon to the Trash can in the Dock or select 'Eject' from the File menu.
If you are running a virtual machine, e.g. VMFusion, ensure that the CD is disconnected from the virtual machine. This will sometimes allow the CD to now show up in Mac OS X.
Shut down the computer and start up whilst holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared.
If you have Toast Titanium installed on your computer, choose EJECT DISC from the menubar.
Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder
Open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button.
Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism.
Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray.
Restart the computer while holding down Command-Option-O-F, to enter the Open Firmware prompt. Type "eject cd" without the quotes, and press return. The disk ought to eject. To start into OS X, type "mac-boot" without the quotes. Press return, and the computer will continue with the startup. (This will not work on an Intel Mac. There is no Open Firmware on Intel Macs. )
If your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button.
It sounds like the read head assembly is not resetting back to the starting point so it can start off reading the "A" side of the next disc. Probably turning it off and then on resets it back to the start of the "A" side. You might try flipping the disc manually to the "B" side, let it go and then try another disc to see if it works.
Sound like it either has one or two problems, the door is stuck and or the door eject motor has failed. Look in the front to the player for a small paperclip like hole, and use a paper clip to manual eject the and engage the loading mechanism usually located under the door for most cases. Check you manuals troubleshooting section for manually ejecting a CD..
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
Figure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work. DONT FORGET TO VOTE
