Question about Teledyne Laars Laars Lx Pool Heater / 400,000 Btu / Propane Gas
Laars 400k won't stay lit
Laars 400k nat/gas lites for 30 sec than flashes service lite on
  • 139 Answers
Sounds like dirty flame sensor,clean with fine emory cloth
Posted on Jun 21, 2009
Laars lite 2 pilot
make sure gas pressure is correct if ok see if the silver tube has a cobweb also make sure all connections are good
Sep 04, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
I have a teledyne laars lite 2, it fires up fine but the flames are excessive and go outwards towards the wires, any ideas
It would seem that this unit has had a conversion done from Nat to LPG or visa versa..the main gas valve and burners need to be adjusted
http://www.laarsman.co.uk
Miles
May 03, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Pool heater will not stay lit
Problem with the thermocoupler its not producing a minivolt of 250 plus that is needed to open the main gas valve
Miles
Apr 05, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars Lite 2 LG - pilot light will not stay lit. As long as you hold down the pilot light once it is lit it stays lit but when I turn the nob to the "on" position (release the pilot light button) the flame...
It sounds like a thermocouple has gone bad. this is a very common problem with gas powered things ie; water heaters, furnaces, hot tubs. The telltale sign is when you release the pilot light button it won't stay lit. This is a safety feature and is relatively inexpensive and easy to repair.
Aug 08, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Will not ignite
First check thermostat is calling for heat or if gas valve fault get unit serviced
Dec 10, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Pilot stays lit, but burners underneathe do not light up or burn.
Check pump is working, if so could be stuck flow switch or gas valve fault get unit serviced
Aug 31, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Laars Lite 2 Spa Heater
it might be the hot surface ignitor. a common problem with gas furnaces also. also, check if there is an code on your screen. it will be called an FL code. call the manufacturer.
Aug 05, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Laars Lite heater not working
1st time this happened to me the filter wasn't clean. 2nd time it was the pressure switch and for the third time they say I have to bleed the gas line, not enough gas to lite. And I also need the on/off switch gone bad.
Jun 08, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Teledyne Laars Laars Lx Pool Heater / 400,000 Btu / Propane Gas Logo
435 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
