Question about 2wire (1000-400108-001) Router
The router won't work there's no signal and everything else is ok?
Your post is rather general but is the middle light orange? If it is, go to your system summary page in the router (by typing and run the system set up wizard to reestablish a connection. Go through the whole wizard entering you password and log on information as needed.
Posted on Nov 01, 2007
Connected but cant get online
If you connect the computer to the router ,does it work ? If yes
That means the wired connection is OK.
Open the set up page of the router check the wireless settings of the router.
I think your network is secured and you are not typing the correct network key.
just open the router set up and check the wireless settings .
Click Here for step by step solution
Jan 15, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Cannot connect to the router
Right click the network icon in the system tray. Click "repair."
If that doesn't work.Power off netbook, router, modem...
Turn on router. Then Modem. Then netbook in that order waiting 1 minute interval between each.
Everything should be functioning ok.
Dec 21, 2009 | Linksys WRT54G2 Wireless Router
Sometimes cannot connect, sometimes losing internet connection.
Are you using a wireless router/access point or is this a wire connection?
If it is wireless, you might just need to relocate where your wireless router is located, many times building construction materials can create RFI and cause the signal to be weak and drop connections more often.
The other problem might be the fault of your ISP. If they are having equipment problems, they might actually have a router that is failing. If you are unsure of the connection to your network, simply contact your ISP and ask that they perform a signal check or to PING your router from their side and measure the signal strength and return rate on the signal.
The last possibility is that your network adapter in your computer might be having problems. There is one check that you can perform on your network adapter to verify that it is working properly. With out being connected to the Internet, open a DOS window (Command.exe). At the prompt enter the following command:
The computer will perform an internal loopback test. If it comes back OK, then most likely your network adapter is working fine.
If everything checks out, you might just have a bad router and will need to get it replaced. Hope this helps you out.
Sep 19, 2009 | D-Link 4-Port Ethernet Broadband Router...
Losing connection from the router
You may have an IP address conflict with another machine. why don't you just plug the router into the computer to see if that solves your problem first. If it doesn't. you should contact your internet carrier. You can also try this: turn everything off, and unplug EVERYTHING for a few minutes. Plug the AC adapters back into the devices FIRST, then into the wall. this will often drain power and solve IP issues.
Jan 02, 2009 | Linksys Wireless-G Broadband Router
Slow link to internet on new Vista Lap top
speed of getting connected is depending on how you have secured the signal.
When connected is everything OK. If Yes try onother channel
If No then I need more information about your settings.
Good Luck,
Jan 17, 2008 | Belkin (F5D8231-4) Wireless Router...
Laptop not seeing my wireless router
ask a neighbor if they pick up our router signal if not start from scrach if it still dont work hope our router on warranty. cheers
Jan 13, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Wireless connection keeps falling
It may be just a problem of the signal bouncing around and your laptop is struggling at times to find the signal. Some earlier laptops don't have a wireless booster built in the screen. Go to your laptops' web site and see if there are any updated drivers for your wireless card. If still unhappy with results purchase a USB wireless dongle and dissable wireless card, it may have a better reception area, or purchase a signal booster that works in conjunction with your wireless router.
Dec 18, 2006 | Edimax BR-6114Wg Router (BR6114WG)
2wire (1000-400108-001) Router Logo
161 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
