Question about Refrigerators
Whirlpool Good Fridge stop cooling
2005 Gold edition.. Started smelling like a electrical wire burned out and stop cooling.
  • Robbie Daniels May 11, 2010
    Might be a condenser fan motor that has shorted out. Does the compressor run and then shut off?
  • 111 Answers
Check the relay on the compressor
Posted on Jun 18, 2009
Smelled something electrical burning, fridge stopped cooling, both fans are working
start relais on the compressor working ? compressor self is working ? an electronic print that can have parts that gan give the smell problem. the compressor self is mosttimes full closed
If theres no cooling anymore and the compressor is working there is no coolant anymore in the circuit bygone.
Feb 20, 2016 | Whirlpool Refrigerators
When dryer running there is a burning smell
Clean the lint trap and make sure you have good fan operation. Check your outside vent for good air flow. Could your burning smell be electrical wiring? Does it smell like plastic burning or lint burning?
These are things one needs to know in order to locate the trouble.
Feb 03, 2016 | Whirlpool GEW9250 Electric Dryer
Whirlpool SXS.....1. compressor cooling fan quit so fridge and freezer stopped working. 2. replaced cooling fan and fridge and freezer working again. 3. Now the fridge and freezer works but runs nonst
Check to see if the sensor in the freezer compartment is encased in ice. If so, do a complete defrost and restart the unit. Another possibility is a bad thermostat and/or sensor.
Jul 25, 2012 | Whirlpool Refrigerators
Whirlpool washer stopped spinning...then started back, but it smells bad like burning rubber?
An overheating motor can switch itself off. When it cools it will restart. And overheat again.....If the motor is hot to touch (unplugged, of course) That would verify the problem. Good luck......Nomess
Apr 19, 2010 | Whirlpool Washing Machines
Whirpool GS6SHAXLB03 Refrigerator or freezer do not cool.
This sounds like it's out of freon. Not just low but out. That clicking noise is a thermal overload shutting down the compressor. If you continue let it just click away it will burn this overload out and the compressor will have to be replaced. If the refrigerator just started doing this suddenly it could be that the compressor is locked up. If it has external capacitors either the start or run capacitor could be bad. If the capacitors are good then you could try a hard start kit to try to unlock the compressor.
Jun 30, 2009 | Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side...
Whirlpool 24" built-in GU1200XTLBO dishwasher electrical smell
This may be the smell of Varnish used in motor winding. When we turn on the machine it gets heated a little bit resulting in a burning electrical smell.
Mar 11, 2009 | Whirlpool GU1200XTLS Stainless Steel...
Fridge freezer over heating and is not cooling fridge section
It is normal for the middle strip to be hot. Did you check the temp setting in the fridge section?
Also - you might check for blockage in the bottom. Excessive dirt/dog hair can block the air flow.
Good luck
Jan 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Smells like burned
Since power outages aren't always polite and absolute, your fridge may have been subjected to low line voltages for an extended time and gee, Whirlpool still hasn't figured out how to protect their product from this kind of damage. We lost one the same way years ago in CA; we came home after being gone for hours, smelled the fridge, checked the line voltage which was wandering around 25 volts +- ~2 volts. Enough to burn the compressor windings but not enough to start it.
In that case, the electric company paid for the compressor replacement on our two-year-old Whirlpool. If you can dig up anyone who was noting the line voltage, maybe you can file a claim with your utility.
Sep 23, 2008 | Whirlpool GS6NBEXR Side by Side...
Kenmore model 525321 overheat problem
hi thanks for the question after your husband replaced relay & overload if the compressor started & kept on running but no cooling you have a bad compressor
Sep 13, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Whirlpool GC5SHEXN Side by Side Refrigerator burning smell
How long had it been plugged in when you started to smell the burn. What kind of burn do you smell, is it an electrical burning smell or a smoldering dust burning smell.
supertechks
Nov 21, 2007 | Whirlpool GC5SHEXN Side by Side...
Refrigerators Logo
63 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
