After cloning a motorola RDU2020 and keying the ptt button it works fine but if i release the ptt and key it again it does not transmit any ideas
Out of habit, after I clone a radio, I turn it off before transmitting. I think it does a reset and saves the information. So, do that, turn it back on and try again. If the problem persists, try manually or with the software programming it. If it still will not save the information, the radio is in need of repair. Please post if this worked.
SOURCE: Staying keyed up after button release
I have never seen this problem before, check if the VOX is activated, this could cause to transmit the radio, but the voice must be transmited. check if the Accesory connector is not dirty, clogged or damaged
SOURCE: One way comm only
swap batteries if does not work this unit should need repair or replace, display blinking can be produced for power failure ( battery, contacts, circuits) or can be a controller issue.
SOURCE: Audiovox FR530
follow instructions on page 13 of your manual "using monitor button" place receiving radio in monitor and key up other radio. It is better if you have someone help. have another person take the radio to another room away from you to complete test. sometimes if the radios are two close too each other they will cancel each other out.
SOURCE: Motorola Talkabout 5700, 60 second timeout?
The 60 second timeout is a feature which is necessary to keep from burning up the final amplifier in the unit. It keeps the user from ruining their radio. Most radios, including business radios have this feature. Continually holding down the PTT will also run the battery down very quickly.
It would be best to try getting a regular baby monitor.
SOURCE: TK 380 not transmiting
Its most likely was programmed with a rx but no tx. Meaning it can recieve but not transmit, you can fix this with the programing software.
