Question about Frigidaire Dishwashers
I am told the pump is defective and I was wanting to do the repair job myself. I need a manuel to take apart the machine to replace the pump assembly or clean it to see if that will do the trick. Is there a manuel so that I can do this maintance?
    Problem Solver:
  • 7 Answers
Usualy if pumps are difective are not worth repairing.
log on to the manufacturar web site they should have a on line manual that might help you.
good luck
Posted on Jun 17, 2009
Can I remove the pump filter on the WMD960
What was the washer doing that made you attempt this repair? I would say you will need to replace the pump assembly now.
Oct 13, 2016 | Hotpoint Washing Machines
Spin problem
HI,
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Sep 03, 2008 | LG WFT1071TP Top Load Washer
Expensive Repairs
There are multiple models that are listed as Odea Go series. Unfortunately the espresso community does not speak highly of these machines because of the low quality parts and assembly processes. The manufacturer for this unit has changed several times.
Oct 29, 2017 | Saeco Odea Go
Need to replace water pump in 2005 Kia Sedona!
I think you mean they pressure tested the cooling system and found the pump to be leaking.
You can check with the auto parts stores online for repair info. They also sell the repair manuals.
If the pump is driven by the timing belt it can be a major job to get everything back in place.
Jul 03, 2012 | 2005 Kia Sedona
Kitchenaid dishwasher KUDP01FL stopped working. Appliance store rep visited and performed diagnostics. Told me I need a new sump motor assembly. Checked sites and found two possible parts: circulation...
go here
https://www.repairclinic.com/Shop-For-Parts/New/c36-x6b7564703031666c/Kudp01fl-Pump-Par
as there is a sump cover and filter that covers the drain pump got to be it.
repair clinic is very good at assistance if you live chat or call the 800 #.
hope this helps you.
they have a video too on replacement.
Jan 08, 2018 | KitchenAid 24 in. KUDP01FL Built-in...
Spin cycle does not work
Hello usmile... Before I get into repairs for this problem let me say this. IF your machine if no longer under warranty and it is over 5 years old, I do not recommend a repair for spin cycle problems. Generally, when this happens the transmission has gone bad. That part is expensive and the labor to replace it is even more expensive. That said, if you are still considering a repair, read on.
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. It pumps, but doesn't spin - If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The clutch may be worn. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician. Joe Thanks for choosing Fixya!
Dec 05, 2010 | Maytag Neptune Washer
I have a het3 elite front load washing machine. I was getting SUD and F02 errors. I took hoses and pump apart and saw debri and removed it. I noticed that the"fins" attatched to the motor of the pump were...
You will need to run the machine with straight water or use bleach and run a few cycles to remove any suds.
If the pump is loose, plugged, or has any missing fins on it, it will need to be replaced. If you leave it unplugged for some time before switching parts, there should be no problem getting it started again.
Jul 27, 2010 | Kenmore Elite 45986 Front Load Washer
Washing machine will not spin. No special noise leading up to this problem. Local repair is several days out. They guessed it was a failed sensor based on the model and systems. Looking for any help on...
It doesn't spin If your washer won't spin, check these: It doesn't pump or spin It pumps, but doesn't spin It spins only with the lid closed It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician. need parts? try Repairclinic.com
Feb 06, 2010 | Washing Machines
Neptune MAH6500aww won't spin
there are several reasons why your machine won't spin. review this list and discover the specific reason you are seeing
Jun 08, 2009 | Maytag MAH6500 Neptune Front Loading...
GE WJSR4160GOWW washing machine not working right
hi there,
* If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt.
* If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin
* The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside
* The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small,
* A belt may be broken. Many washing machines have one or two belts. If a belt is broken or
* The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper
repair technician.
* The drive motor may be defective. Many washer brands use a reversing motor. For agitation
the entire motor.
* The transmission may not be shifting properly. Older washers produced by Whirlpool® have a
* The spin bearing or basket drive may be worn or seized. These components allow the inner tub
* Is there hot water coming through the proper hose? If not, check to see if the screen inside the
water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the
fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so,
completely replace it.
Nov 09, 2008 | GE WBSR3140DW Top Load Washer
Dishwashers Logo
69 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
