Question about Sharp Actius AL27 Notebook
Sharp Actius AL27 strange DVD burning problem - The drive will burn a DVD+RW at 4x. A cheap (Imation) DVD+R burns OK, but a good 16X DVD+R (Verbatim) tries to burn at 2x and fails a few minutes in. This happens in Nero and all other burning software.: Here is the Nero log: Windows XP 5.1 IA32 WinAspi: - ahead WinASPI: File 'C:Program FilesAheadNeroWnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 12/16/2003 8:18:06 PM Nero API version: 6.3.1.10 Using interface version: 6.3.1.4 Installed in: C:Program FilesAheadNero Application: aheadNero - Burning Rom Recorder: Version: 1.00 - HA 1 TA 0 - 6.3.1.10 Adapter driver: HA 1 Drive buffer : 2048kB Bus Type : via Inquiry data (1) -> ATAPI, detected: ATAPI Connected to MMC as unknown drive with class-nr : 1 Drive is autodetected - recorder class: Std. MMC recorder === Scsi-Device-Map === DiskPeripheral : FUJITSU MHT2060AT SP atapi Port 0 ID 0 DMA: On CdRomPeripheral : MATSHITA UJ-830D atapi Port 1 ID 0 DMA: On === CDRom-Device-Map === MATSHITA UJ-830D E: CDRom0 ======================= AutoRun : 1 Excluded drive IDs: CmdQueuing : 1 CmdNotification: 2 WriteBufferSize: 66060288 (0) Byte ShowDrvBufStat : 0 EraseSpeed : 0 BUFE : 0 Physical memory : 447MB (458224kB) Free physical memory: 154MB (157956kB) Memory in use : 65 % Uncached PFiles: 0x0 Use Static Write Speed Table: 0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 2.3.2009 NeroAPI 6:40:15 PM #1 Phase 112 File APIProgress.cpp, Line 269 DVD-Video files reallocation started 6:40:15 PM #2 Phase 114 File APIProgress.cpp, Line 269 DVD-Video files reallocation completed (no file modified) 6:40:15 PM #3 Phase 111 File APIProgress.cpp, Line 269 DVD-Video files sorted 6:40:16 PM #4 Text 0 File Reader.cpp, Line 118 Reader running 6:40:16 PM #5 Text 0 File Writer.cpp, Line 124 Writer MATSHITA UJ-830D running 6:40:16 PM #6 Text 0 File AudioCompilationImpl.cpp, Line 817 DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1) DRM: Beginning burn process. 6:40:16 PM #7 ISO9660GEN -11 File geniso.cpp, Line 3899 First writeable address = 0 (0x00000000) 6:40:16 PM #8 ISO9660GEN -11 File geniso.cpp, Line 3899 First writeable address = 0 (0x00000000) 6:40:16 PM #9 Text 0 File Burncd.cpp, Line 3200 Turn on Disc-At-Once, using DVD media 6:40:58 PM #10 Text 0 File DlgWaitCD.cpp, Line 244 Last possible write address on media: 2295103 (510:01.28, 4482MB) Last address to be written: 2239983 (497:46.33, 4374MB) 6:40:58 PM #11 Text 0 File DlgWaitCD.cpp, Line 249 Write in overburning mode: FALSE 6:40:58 PM #12 Text 0 File DlgWaitCD.cpp, Line 2107 Recorder: MATSHITA UJ-830D, Media type: DVD+R Disc Manufacturer ID: MCC, Media Type ID: 004, Product revision number: 0 Disc Application Code: 0, Extended Information Indicators: 7 6:40:58 PM #13 Text 0 File DlgWaitCD.cpp, Line 410 >>> Protocol of DlgWaitCD activities: <<< ========================================= Insert empty disc to write to. (Medium in drive: unknown. Medium required by compilation: DVD+R/RW, DVD-R/RW.) 6:40:58 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 813 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 (CTransferItem) 2 indices, index0 (150) not provided original disc pos #0 + 2239984 (2239984) = #2239984/497:46.34 relocatable, disc pos for caching/writing not required/required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2239984 blocks [MATSHITA UJ-830D ] -------------------------------------------------------------- 6:40:58 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 982 Prepare recorder [MATSHITA UJ-830D ] for write in CUE-sheet-DAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4587487232, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_ 0 | lead-in | 0 | 0x00 | 0x41 0 | 1 | 0 | 0x00 | 0x41 0 | 1 | 1 | 0x00 | 0x41 2239984 | lead-out | 1 | 0x00 | 0x41 6:40:58 PM #16 Phase 24 File APIProgress.cpp, Line 269 Caching of files started 6:40:58 PM #17 Text 0 File Burncd.cpp, Line 4210 Cache writing successful. 6:40:58 PM #18 Phase 25 File APIProgress.cpp, Line 269 Caching of files completed 6:40:58 PM #19 Phase 36 File APIProgress.cpp, Line 269 Burn process started at 2.4x (3,324 KB/s) 6:40:58 PM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2345 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 6:40:58 PM #21 Text 0 File Cdrdrv.cpp, Line 8024 ---- DVD Structure: Physical Format Information (00h) ---- Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050 Book Type: DVD+R (10), Part Version: 1 Disc Size: 120 mm, Maximum Rate: (F h) Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable Linear Density: 0,267 um/bit, Track Density: 0,74 um/track Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW) End Physical Sector Number of Data Area: 26053F h End Sector Number in Layer 0: 0 h Data in Burst Cutting Area (BCA) does not exist Disc Application Code: 0 / 0 h Extended Information indicators: 7 h Disc Manufacturer ID: MCC..... Media type ID: 004 Product revision number: 0 Number of Physical format information bytes in use in ADIP up to byte 63: 56 Media Specific [16..63]: 00 00 07 4D 43 43 00 00 - 00 00 00 30 30 34 00 38 ...MCC.....004.8 23 54 37 12 02 54 6C 02 - 92 5F 15 15 0B 0B 08 08 #T7..Tl.._...... 01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00 ................ 6:40:58 PM #22 Text 0 File DVDPlusRW.cpp, Line 618 Start write address at LBA 0 DVD high compatibility mode: Yes 6:42:06 PM #23 SCSI -400 File Cdrdrv.cpp, Line 1439 SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x015C0000 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x04 (KEY_HARDWARE_ERROR) Sense Code: 0x03 Sense Qual: 0x01 CDB Data: 0x2A 0x00 0x00 0x00 0xDC 0x80 0x00 0x00 0x20 0x00 0x00 0x00 Sense Data: 0xF1 0x00 0x04 0x00 0x00 0xD9 0x80 0x0A 0x00 0x32 0x00 0x00 0x03 0x01 6:42:06 PM #24 CDR -400 File Writer.cpp, Line 304 Unspecified target error 6:42:06 PM #25 Text 0 File ThreadedTransfer.cpp, Line 229 all writers idle, stopping conversion 6:42:06 PM #26 Text 0 File ThreadedTransfer.cpp, Line 223 conversion idle, stopping reader 6:42:08 PM #27 Phase 127 File APIProgress.cpp, Line 269 Generating DVD high compatibility borders 6:42:11 PM #28 SCSI -400 File Cdrdrv.cpp, Line 1185 SCSI Exec, HA 1, TA 0, LUN 0 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x04 (KEY_HARDWARE_ERROR) Sense Code: 0x03 Sense Qual: 0x00 CDB Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 Sense Data: 0x71 0x00 0x04 0x00 0x00 0x00 0x00 0x0A 0x00 0x2A 0x00 0x00 0x03 0x00 6:42:11 PM #29 Phase 129 File APIProgress.cpp, Line 269 Generating DVD borders completed successfully 6:42:11 PM #30 Phase 38 File APIProgress.cpp, Line 269 Burn process failed at 2.4x (3,324 KB/s) 6:42:11 PM #31 Text 0 File AudioCompilationImpl.cpp, Line 828 DRM: DRM burn session terminated. 6:42:11 PM #32 Text 0 File AudioCompilationImpl.cpp, Line 857 DRM: Closing entire DRM handling. Bye. Existing drivers: File 'DriversPXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 7/17/2006 7:24:44 PM (Prassi/Veritas driver for win 2K) Registry Keys: HKLMSoftwareMicrosoftWindows NTCurrentVersionWinLogonAllocateCDROMs : 0 (Security Option)
  • 1 more comment
  • danebennet Jun 17, 2009
    Neither Sharp nor Matshita has ever posted any update on firmware or drivers for this ultra-cheap OEM DVD drive. (This and the worthless battery are my only complaints with the machine)
    And I have tried every possible speed and the Verbatim disk fails on all speeds. The idea that "slower is better" for DVD burning may sound logical, but isn't really true anyway.
    And before anyone else suggests it, I've dealt with the upper and lower filters issue already.
    It is obvious the person writing the second (garbled) "solution" didn't even read the problem description or he would have seen that I was not trying to burn at 16X (and this drive doesn't support that anyway).
    I was trying to burn at 4x (which worked for the previous disk) and it appears to fail because it is trying to burn TOO SLOW, not too fast.
    In my opinion this "solution" is worse than useless because not only does it not relate to my problem, but it also perpetuates the MYTH that burning at the slowest possible speed is always the best bet.
    Thanks RescueTechLA for the suggestion, but I've already scoured rpc1 and looked at CDfreaks. RPC1 discussions had many people asking about this, but no solutions given, and the focus there seemed to be on region codes, which don't concern me at all.
    One thing that I don't understand is why Nero referred to the device as "MCC" which is the disk code. Any idea if that is the issue?
    Maybe I can find some castoff cheap 8x disks somewhere, but it is so strange that Verbatim 16x is the one that fails (and disks from the same spindle burn fine on other machines)
  • 499 Answers
Man it's not a condition that if the DVD Bulck writeen on it 16X that ur DVD writer will burn on this speed.
always don't try to burn ur DVD on maximum, always use the previous speed or the last previous one
ok good luck
Posted on Jun 17, 2009
    President:
  • 2,653 Answers
Most of the time you can fix this problem by updating the drive's firmware. Check Sharp's support page for the download and instructions.
Let me know what happens.
  • RescueTechLA
    RescueTechLA Jun 17, 2009
    Errr.......well I'd try the rpc1.org forums for this problem or cdfreaks.
    I had a similar issue with one my drives, I never found a solution to the problem other than using different recording media.
    Best of luck!
  • RescueTechLA
    Hmmm....not sure. Sometimes it has to do with DMA being enabled...you might want to check those settings.
    Check out this program.
    It's very similar to Everest but it's free. It's handy tool for troubleshooting.
    Best of luck!
(CRX230ED) CD-RW Burner will it burn dvds?
Read/Write Speed CD-R Write:
4X, 8X, 12X, 16X CLV
24X ~ 40X P-CAV
52X CAV (turbo mode) max.
CD-RW Write:
4X, 8X, 10X, 12X CLV
16X ~ 24X CAV max.
CD Read:
52X max.
Buffer Memory
2 MB
Random Access Time
100 ms.
Interface
ATAPI/EIDE
Sustained Transfer Rate (CD-R/RW Discs)
600 kB/s (4X CD-R/RW read/write)
1,200 kB/s (8X CD-R/RW read/write)
1,800 kB/s (12X CD-R/RW read/write)
7,800 kB/s (52X CD-R/RW read/write)
Media and Modes Supported
CD-R, CD-RW,
CD-ROM (Mode 1 & Mode 2),
CD-ROM XA (form 1 & form 2),
CD Audio,
Video CD,
CD Extra,
Multi-Session,
Packet Writing
Burst Transfer Rate
PIO Mode 4: 16.7 MB/s,
Ultra DMA Mode 2: 33.3 MB/s.
no you will need dvd rw to burn dvd's
hope it helps
Dec 03, 2011 | Sony (CRX230ED) CD-RW Burner
I have a LG GE20 DVD Rewriter Is a DVD+RW disc a format that is editable and suitable for this unit?
The LG G20 DVD Rewriter is an advanced external burner that supports 'editable' Rewritable DVD+RW disk.
As a generic comment, not all writable/rewritable media are made equal and problem with branded & unbranded disks are not uncommon, so stick to brands that work for you for your specific unit!
The following is the advertised support for your unit, hope it helps:
Reading Rate DVD-R/-RW/-ROM 16x/13x/16x/16xSL/12xDL max. DVD-RAM 2x, 3x-5x, 6x-12x DVD-Video (CSS) 4,8x max. (Single/Dual Layer) DVD+R/+RW 16x/13x max./ 12xDL max. CD-R/RW/ROM 48x/40x/48x max. CD-DA (DAE) 40x max. Burning Speed DVD-R 2x, 4x CLV, 8xZCLV, 16x PCAV, 20X CAV DVD-RW 1x, 2x, 4x, 6x CLV DVD-RAM 2x, 3x ZCLV, 3x - 5x PCAV, 12x PCAV DVD+R 2.4x, 4x, 8x, 12x, 16x PCAV, 20X CAV DVD+R Double Layer 2.4x, 4x, 10x, 12x ZCLV DVD-R Dual Layer 2x, 4x, 6x CLV, 10x, 12x ZCLV DVD+RW 2.4x, 4x, 6x, 8x ZCLV CD-R 4x, 8x CLV, 16x, 24x, 32x, 40x, 48x ZCLV CD-RW 4x, 8x, 10x CLV, 16x CLV, 24x, 32x ZCLV
Dec 28, 2009 | Computers & Internet
Hello my samsung sh-s182 dvd -+rw doual very slow burn nor456@yahoo.com
First look and see the write speed of the drive. 1x to 4x is slow but recommended by all programs and this is initially the default settings for most programs. You must goto the settings of your dvd burning program and set the burn rate to 16x or higher.
Sep 25, 2009 | Samsung SH-S182 DVD±RW Dual Layer Burner
I only can write with 4x maximum while dvd could
DVD burners will only write to the maximum stated.
Also if you are using 4x DVDs then that is all they will burn at without often giving errors when used.
Trying to burn a 4x DVD at lets say 16x can cause burn failure or data corruption.
Cd's on the other hand can burn at lower speeds than they are stated.
To burn DVDs at higher speeds your burner needs to be capable of that speed
Sep 06, 2009 | NEC ND-2500A DVD±RW Burner
I need to find out what type of disc to use with our dvd burner
The specification of the DVD drive for the Aspire 5930 is
  • Type DVD±RW (±R DL) / DVD-RAM / HD DVD-ROM - Integrated
  • CD / DVD read speed 24x (CD) / 8x (DVD) / 1x (HD DVD)
  • CD / DVD write speed 16x (CD) / 4x (DVD±R) / 2x (DVD-R DL) / 2.4x (DVD+R DL)
  • CD / DVD rewrite speed 10x (CD) / 4x (DVD±RW) / 3x (DVD-RAM)
This means you can burn CDs -R and +R type disc (incl R/W)
Burn single layer and dual layer DVD -R and +R disc (incl R/W)
Jun 27, 2009 | Acer Aspire 5920-6727 Notebook
Hl-dt-st dvdram gsa-t20n ata burn speed for cdr changes to 10x minimum automatic soon as i put a blank cdr in. i need to do slower burn Speed (4x) and i tried with different software and its always the...
Your drive doesn't support slower burning speeds unfortuately, here are the specifications for it:
Write Speed DVD+R 2.4x CLV, 4x ZCLV, 8x CAV DVD-R 2x CLV, 4x ZCLV, 8x CAV DVD+RW 2.4x, 3.3x CLV, 4x ZCLV, 8x ZCLV
(8x Speed disc: 3.3x CLV, 8x ZCLV)
DVD-RW 1x, 2x CLV, 4x, 6x ZCLV DVD-RAM 2x, 3x ZCLV, 5x PCAV(Ver.2.2) (16x Media: Not support) CD-R 10x CLV, 16x, 24x ZCLV CD-RW 4x, 10x CLV, 16x ZCLV
(High Speed: 10x CLV, Ultra Speed: 16x ZCLV, Ultra Speed plus: 16x ZCLV)
DVD+R DL 2.4x CLV, 4x ZCLV, 6x ZCLV DVD-R DL 2x CLV, 4x ZCLV, 6x ZCLV Read Speed DVD-R/RW/ROM 8x/8x/8x max. DVD-R DL 6x max. DVD-RAM (Ver.1.0/2.2) (Ver.1.0) 2x
(Ver.2.2) 2x, 3x, 5x
DVD-Video(CSS Compliant Disc) 4x max. (Single/Dual layer) DVD+R/+RW 8x/8x max. DVD+R DL 6x max. CD-R/RW/ROM 24x/24x/24x max. CD-DA (DAE) 24x max. Sustained Transfer Rate DVD-ROM 11.08 Mbytes/s (8x) max. CD-ROM 3,600 kB/s (24x) max.
Jan 28, 2009 | Computers & Internet
My dvd burner doesn't burn good dvds
Have your dvd burner burning lens cleaned. This should help you!
Jan 24, 2009 | Pioneer DVR-212DBK 18X SATA DOUBLE LAYER...
HR 720 does not burn to DVR -R media
Hallo everybody,
this guy "mysus" is a genius! I have had above problem on a Samsung HR-725 (160 Gb Version of the HR-720) now for approx. 1 year. I´ve called the Samsung Hotline and tried other dealers - nothing worked. Today I came accross this help and tried it out immediately - and it works perfectly. However, you do need to know a little about PCBs and electronics.
I used a variety of different -R DVDs and they all seem to work now. Many thanks once again for this fantastic link.
May 01, 2008 | Samsung DVD-HR720 DVD Recorder
Problems recording DVD-R 16X
Try this download page to update your firmware from 25/10/05, so if you bought your writer before this date maybe this will work, otherwise buy 8x discs. http://sony.storagesupport.com/dvdrw/firmware.htm#710 The faster the discs are burned the more chance of errors there are, you should write at slower speeds for better quality.
Oct 27, 2006 | Sony DRU-710A DVD±RW Dual Layer...
Sharp Actius AL27 Notebook Logo
730 people viewed this question
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Mark Dewar
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
