Question about E-Machines T2893 PC Desktop
Same problem - green "power" LED on the MB but no activity
I'm having the exact same issue. Just to make certain the power supply was replaced. The front panel jumpers have been removed so I am trying to locate a diagram for the MB to show the jumper locations (PWR SW, HDD LED, PWR LED) next to the BIOS chip. Tested the RTC batt - 3v good.
Any other suggestions or ideas other than dump the MB and put in one that works?
  • babboo_65 Aug 28, 2009
    Problem solved by replacing the mother board. eMachines is doing a horrible job of supporting their products IMO.
    After trying the power supply route I suggested a replacement MB. Even though that did not resolve the problem with the mother board he had it got his computer up and running again - and now much faster.
    Thanks for the responses and suggestions.
  • 1,684 Answers
This series of machines is known for this issue. You can get a replacement motherboard for your pc from a website at www.barebonekit.com they boards run from $35 to about $65 plus shipping. This is much cheaper than you can get them most other places. We order from them on a regular basis and have had no problems. I hope this helps, if so please rate the solution.
Thanks,
Buddy
Posted on Jun 17, 2009
Not turn on and lights a green light on motherboard
Posted on Mar 01, 2011
  • 42 Answers
Go to the E-machine site with you type and model number, go to the motherboard specifications and query for the wiring specs.
Green led power light comes on then power goes off and comes back on repeatedly. It never posts.
Your motherboard was manufactured in late 2009. The green LED on the MB supplies DC power to the BIOS. This is known as standby. This is a relay is built into the MB maintaining the required 3 volt. When you power up the MB the power supply maintains the
3 volt DC to the BIOS. So the relay is not working. Suggest you contact Asus. All Asus MB's carry a three year warranty. Your board will need to be replaced by Asus. Call Asus at; 1-812-282-2787. (Asus Tech IL EST) M-F 8:00 to 5:00PM) There is a sticker on the LPT printer port. Write down the serial number, you'll need this when you make the call.
Mike
Jul 27, 2010 | ASUS P7P55D PRO Motherboard
MB green light on but won't start
your power supply must be exact and both power connections to the motherboard must be connected. the green light will come on if voltage is supplied but will turn on a low voltage alarm which is a buzzing sound. or it just wont do anything
Jan 25, 2010 | E-Machines T3624 PC Desktop
Optiplex gx 260 steady amber light - done all things on dell website - still doesnt turn on. got a new PSU and it still has the same problem. theres a whirring sound which is the fan and the power supply...
Steady Amber Power LED generally indicative of a failed MB. Remove all Memory, Expansion Cards, peripheral items, if still same, replace the motherboard. If you get a Green LED with jusr RAM in system, then an expansion card or peripheral might be the issue. 95% sure it is mothebroard
Sep 15, 2009 | Dell OptiPlex GX260 PC Desktop
I have connected Lantronix UDS1100 Device with Siemens AZL Meters. But not able to get complete data on front end.
The UDS has the following LEDs, which help you diagnose problems.
Power LED (green)
Ethernet 10/100 Link (yellow = 10 Mb/green = 100 Mb)
Ethernet Half/Full Duplex Activity (yellow = Half Duplex/green = Full Duplex)
Diagnostic (red)
Status (green)
Simultaneously lit Diagnostic (red) and Status (green) LEDs mean something is
wrong. If the Diagnostic LED is lit or blinking, count the number of times the Status
LED blinks between its pauses. The following table explains the LED functions:
Aug 27, 2009 | Lantronix UDS1100 (UD110000201)
No power to motherboard Shuttle AN35n ultra
Hi there
Try One of the following steps:
  1. Flash Youre MB BIOS.
  2. make sure that CPU Fan is working OK.
  3. Is the CPU attached to the MB correctlly.
  4. Is the CPU Fan base and scrowse faremly scrowd and positioned on the MB.
  5. Chec MB in/pot power pins connections.
Hope That will Help.
May 16, 2009 | Shuttle AN35N Motherboard
Emachine T2890 won't power up. After reading some posts on this issue I went ahead and replaced the power supply, but the unit still won't power up. I am fairly certain that the old ps was fried since...
If you remove all the RAM fro the system and power it on, you should hear "Memory Error Beeps" if not, then it is usually Motherboard or CPU, for around $30.00 you can purchase a PCI POST code reader to try to pin the problem down further.
I am assuming from the post that all PCI cards (dial up modem especially) have been removed. Sounds like a bad MB or CPU, but if the video is integrated,( built on the motherboard, and not a seperate card, the memory is responsible for video also, and it maybe defective.
Feb 19, 2009 | Intel D845GVSR Motherboard
Emachine T2890 won't power up. New power supply.
move its bios jumpur on cofig mod and after some time post it its orignal post .it will ok ok Insha Allah
Internal led of ML350 server is glowing.......how do i resolve it?
Hi Franceso, plz specify
Is it powering ON ?
Which LED is glowing?
These leds are there on the front panel :
1 Power On/Standby button
2 System power LED
Green = Power on
Amber = System shut down, but power still applied
Off = No power
3 Internal health LED (Wave sign in BOX)
Green = Normal
Amber = System degraded. To identify the component in a degraded state, refer to system board LEDs.
Red = System critical. To identify the component in a critical state, refer to system board LEDs.
Off = Normal (when in standby mode)
4 External health LED (power supply)
Green = Normal
Amber = Power redundancy failure
Red = Critical power supply failure
5 NIC 1 activity LED Green = Network link
Flashing = Network link and activity
Off = No link to network.
6 UID LED Blue = Activated
Flashing = System remotely managed
Off = Deactivated
7 UID button
If it is Internal health led then any internal h/w issue is suspected.
If it is external health led then any power supply or power source related issue is suspected.
Also check the status of the server & its IML (Integrated Management Logs) in ilo (Integrated Lights Out ) if it is configured. (2nd RJ45 port in rear)
Also make sure the cabinet is properly closed.
Nov 18, 2008 | HP Compaq ProLiant ML350 G3 Server
Dead MB?
Most of the time the issue seems to be a bad power supply. I would test with a different one if possible. In rare cases I have seen the capacitors bulge and leak leading to a dead motherboard.
Sep 04, 2008 | Intel D945GTP Motherboard
E-Machines T2893 PC Desktop Logo
328 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
