Hi Bobby i had a 2004 caviler did the same thing the code that came up was idle air control valve but after replaceing it i got the same code with check engine light on. And idle going up and down with high idle! turns out the brake power booster had holes in it on the back side of it the side that faces the firewall. The best way to check is to pull off the vacume line that goes to the brake booster and put your thumb over it and see if the idle goes down! If it does that,s your problem. also check all vacum lines! Hope this helps you out... Ed
