Question about NetGear WGR614 Wireless Router
How do i open nat ports on a netgear WGR614 - NetGear WGR614 Wireless Router
  • 499 Answers
U should open on ur bowser
http://192.168.0.1/
then configure ur router ports
Posted on Jun 17, 2009
My NAT type is strict and i wanna make it open how for xbox live
Check out this website. It has set by set instructions on how to set change the NAT type to open. You have to open certain ports for xbox live which are also listed.
http://portforward.com/english/routers/port_forwarding/Netgear/WGR614/Xbox_Live_360.htm
Sep 15, 2010 | NetGear WGR614 Wireless Router
How do I change the NAT type on my Netgear WGR614 v6 router from strict to open?
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Then click on NAT and then port forwarding then open port tcp and udp which you want then save settings and restart router.
Let me know if you need further assistance.
Thanks for using FixYa.
Apr 19, 2010 | NetGear WGR614 Wireless Router
Nat ports
Go to the port range forwarding page on your router's setup.
It will ask you for the specific port. (88,3074) Enter them in in their own seperate sections. Then select either UDP of TCP for each. Then save the settings and you should be good to go.
Apr 06, 2008 | NetGear WGR614 Router
How do i get NAT OPEN
To get the NAT open, you have to forward specific ports. If you are doing this for xbox live, then call microsoft and ask for an "agent." Tell them that when you test your xbox live connection, your NAT is strict or moderate. They will give you a specific port to open. With that information, You go to your router's setup, and look for port fange forwarding. Enter the information given and save it. For further assistance, call netgear's help line and they will help you.
Mar 31, 2008 | NetGear WGR614 Wireless Router
Nat
reserve the ip for ur xbox in ur router settings
do port forwarding
and open the ports numbers of ur xbox for the reserved ip
Feb 08, 2008 | NetGear WGR614 Wireless Router
NAT set to strict
upgrade your router to the latest firmware that can be found here:
http://kbserver.netgear.com/products/WGR614.asp
after upgrading the firmware, press the reset button for 30 seconds, then reconfigure the router. you will need to re-enable upnp if it is disabled, and open up ports UDP 88 UDP 3074 TCP 3074. i would also reserve the ip for the xbox and if all else fails set the xbox as the dmz host.
hope this helps,
trin
Nov 16, 2007 | NetGear WGR614 Wireless Router
Xbox 360 live and netgear WGR614
Down load the new firmware and install it in your router.
Use UPnP. If your router supports this. Turn it on. The router will work out the ports it needs to open for Xbox live. If your router does not have this feature, check the manufacturers website for the latest firmware. (also make sure portforwarding and/or DMZ is turned off as they interfere with UPnP)
Oct 16, 2007 | NetGear WGR614 Wireless Router
Nat settings on netgear wgr614 wireless router
Hello --
Most NAT settings can be found, on modern routers, under the WAN setup of the router interface. Normally, it is set to Secured with the option of setting it to Open. Click Open and apply changes, giving the router a moment to reset the software and re-broadcast transmissions.
This comes secured for public consumption because the normal consumer would not create a WAN (wide access network) at home. However, gaming consoles (PS3 and Xbox 360) require this because of the P2P hosting that most online multiple-player games require. Setting it to Open full-duplexes the transmissions without restriction (since gaming console connections are "supposed" to be secure anyway).
After you've set the NAT settings, restart the gaming console, test the 'net connection and confirm it is reading your now Open NAT settings.
Oct 15, 2007 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
372 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
