Question about Bose 3 2 1 GSX System
Placed dvd in to bose dvd player and it froze...wont go back to dvd mode and will not eject...any suggestions?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 71 Answers
This can sometimes happen with a newly manufactured DVD (in which case you should call for a sw update) or a copied DVD. Either way, turn the 321 off, unplug the power cable from the acoustimass module, and wait 30+ seconds. After plugging it in, don't turn it on. Just press the eject button and wait about 5-8 seconds. If the tray doesn't open this could me a mechanical failure, in which case you should call Bose for a repair. Otherwise, just call them for a sw update if the DVD comes out.
Posted on Jun 21, 2009
BOSE LIFESTYLE 38 DVD PLAYER WON'T OPEN TO EJECT THE DVD
The DVD could be stuck inside the player or the drive may have failed.
Sep 08, 2014 | Bose Lifestyle 38 System
Dvd wont eject
unplugged the DVD player from the wall for 5-10min........plug it back to wall at the same time press stop/eject (or power if needed) but press eject before the DVD player by default tries to load the dvd....
Jul 24, 2010 | Bose 3 2 1 GSX System
Bose 321 won't eject DVD
the dvd system is built around a pc style dvd rom drive. You can remove the top cover by prying the back center up and sliding the cover back then off. Remove the metal bracket that holds the drive in place and then remove the drive. the front tray cover should pop off as you remove the drive. There is a eject hole in the front that if you put a paper clip into it will release the tray. That way you can get your dvd back. I refurbish these drives and I may have one for sale. Contact me if you would like to send the unit in to me i can complete the repair for 85.00 Bose does offer a repair service if you call them at 1-800-999 2673
May 02, 2010 | Bose (321GS) System
Dvd player will not open disc, display lock
Sound like it either has one or two problems, the door is stuck and or the door eject motor has failed. Look in the front to the player for a small paperclip like hole, and use a paper clip to manual eject the and engage the loading mechanism usually located under the door for most cases. Check you manuals troubleshooting section for manually ejecting a CD..
Please leave comment.
Oct 12, 2009 | JVC XV-N312S DVD Player
Dvd won't eject and picture froze
Try un-plugging the unit from the mains electric supply, leave it for a couple of minutes & then plug it back into the electric supply. This should re-set itself & hopefully eject the disc. If the disc had a bad spot or the laser did not traverse smoothly this will cause the disc to freeeze & lock up.
Jul 27, 2009 | Bose 321GS Series II System
Door won't open
Sure, just unplug the system, wait thirty seconds, plug it back in (the display should read "BOSE 321" or similar) and press eject again. It should work.
If not, try it again, but wait longer...
Feb 22, 2009 | Bose 3·2·1 II System
Open/close tray disc stuck bose Lifestyle 48
Problem:
I also have a bose Lifestyle 48, and the same problem has happen to me where the DVD player would not open,
Solution:
Unplug the unit, Wait a few seconds, after plugging the power back in, immediately hit eject so that the player does not have time to spin up and try to read the disc again
Feb 17, 2009 | Bose Lifestyle 48 System
Dvd disc drive wont open
Unplug the power cord for ten min. then try again.............. John
Feb 01, 2009 | SDAT HTA6SD System
CD stuck in disk tray of (original) BOSE 321
NO NEED TO TEAR APART OR REPLACE THE UNIT! JUST TURN OFF THE UNIT, LEAN IT FORWARD AND A LITTLE DOWNWARD AND HIT THE LOAD BUTTON AND IT WILL OPEN. THAT'S THE TRICK!
Nov 23, 2008 | Bose 3·2·1 II System
DVD frozen
suggest unplug Bose system from the wall for 10 secs, then plug in and allow it to initialise.
if this fails take bose unit to dealer.
Aug 17, 2007 | Bose Lifestyle 48 System
Bose 3 2 1 GSX System Logo
294 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
