Question about Bissell 1425 Little Green ProHeat Handheld Steam Vacuum
WILL NOT SPRAY. i CHECKED THE LINES AND THEY ARE
WILL NOT SPRAY. i CHECKED THE LINES AND THEY ARE CLEAN.
I had the same problem, then I read somewhere that you have to prime it before you turn it on, to help it regain suction...before you turn it on hold down spray button for about 1minute, then turn it on and use it. Solved my problem...good luck!
Posted on Aug 01, 2009
Detergent doesn't dispense.
Water will clean carpets but not very well. For the best results don't put any cleanser in your machine. Soap can clogged up the lines in your machine. When you have soap dispensed or or in the water in your machine you are squirting it onto the carpet and sucking it back up at the same time...the soap and water isn't on the carpet long enough to clean well unless you keep going over the same area many times. To clean better it's really important to vacuum thoroughly going slowly in multiple directions to get as much dry, gritty soil and hair and dust out as possible, it's easy to get these soils out when the carpet is dry if your vacuum is working properly. Vacuum, vacuum, vacuum.
Get a spray bottle or sprayer and put hot tap water in it, add the cleaning solution to the hot water and spray enough on the carpets to get the face fibers damp...let the hot water solution sit on the carpets 5 or 10 minutes and then use your machine to clean and rinse the soap, water and loosened soils from the carpet fibers. Repeat if necessary. Your carpets will be cleaner because you allowed adequate dwell time for the soap and water to work on the sticky greasy soils attached to the carpet fibers and stay clean longer because the soap is rinsed out of the carpets. Your carpet cleaning machine will last longer too because the water lines, pumps, spray jets, heaters, etc can't get clogged with soap gunk if you don't put soap in it. The method I'm describing is how the best professional carpet cleaners clean carpets. Hiring a quality carpet cleaner cost more up front but the carpets may stay clean two or three times longer, saving a lot of money in the long run. If you clean your carpets using this dual process method you may do a better job with a small portable home or rented cleaner than hiring the average carpet cleaning professional who is trying to give you the lowest price.
Mar 06, 2017 | Vacuums
No water from spray on base
I had same problem. Remove all fluid from machine, I used a wet dry vac. As someone else said unscrew the 2 screws that hold the filter basket. Take out the filter basket and clean thoroughly. Find plastic hose that is now visible under basket and pull up and remove that (noticing where the slot is to put it back when finished) and pull the screen off top of hose and clean that as well. I then vacuumed out that hose with my wet dry vac. Reassembled everything and now works perfectly.
Oct 15, 2014 | Rug Doctor Mighty Pro X3 Value Pack - Blue
My max extract 77 hoover wont spray
Make sure all water lines are not clogged with anything 1st. Then check to see if the switch/lever or button that actuates the spray is functioning/working. If it's a mechanical switch/lever etc, see if you can take it off and clean it thoroughly and check to make sure there are no broken parts. If it's an electrical switch/button or lever, you need to check and make sure it's clean, and all the contacts to wires are NOT broken or damaged. You may have to replace parts if they don't function.
Oct 15, 2013 | Hoover F6055-900 SteamVac Maxextract LS...
Biseell little green machine wont squirt water out
The Pumps on these go bad after a couple of months. They rust and will sometimes spray and other times not then eventually not work at all. If your a handy man pull the top off it and remove the pump motor and replace it yourself. The part number is 603-5029 you can put this number in google shipping and get it to your door for about $15 and replace it yourself or have a friend do it. Ebay has tons of them once again just put in the part number and a list of them will come up.
Thanks and have a good one
Sincerely, CRTN
May 22, 2010 | Bissell THE BISSELL LITTLE GREEN MACHINE...
My bissell proheat 12amp is not spraying water
Pumps are a very common problem on these units. check pump belt first and make sure spray jets above the brushroll are not clogged. Most likely have to replace the pump. If you need me to walk you through this or need parts let me know.
Apr 08, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
My bissell won't spray. I've checked the hose and belt, those look fine. Any other ideas?
It could be blocked within the machine, there is a pump located in side - they get bunged up or clean the spray bar where it comes out at the front
Sep 18, 2009 | Vacuums
Will not spray
The heater is probally clogged. Remove the upper housing and locate a rectagular shaped object in the middle of machine. Remove six bottom screws and clean with stiff brush, clear all lines then run 3 tanks of hot water trhought he system to clear it.
Apr 10, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
No Spray from Bissell 7920 ProHeat Pro-Tech s/n 01222111
When you put the cover back on, was the piston on the bottom of the smart mix knob? If it was, did you have the smart mix knob in the water only setting? Sometimes the flow indicator cap may be on too tight, loosen it while it is running until fluid starts to leak out, then tighten it until it starts spinning. On the bottom of the tanks, are the seals on the tank and not sitting the the hole. You may have pinched a line when you put the top cover back on. May still have junk in the lines somewhere, try running a mix of vineager and water (not on the carpet), that mix may clean it out.
Sep 08, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Intermittent water spray or no spray at all with my Bissell proheat 9400
you may have a partial clog, try running a mix of water and vinegar thru it to see if it will clean out the lines and spray tips.
Apr 28, 2008 | Bissell 9400 ProHeat Upright Wet/Dry...
Steamvac
You might try running a solution of vinegar and water thru it to clean out the lines and spray nozzles. Also are the brushes turning when you are using it, that could also be the problem.
Mar 18, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Bissell 1425 Little Green ProHeat Handheld Steam Vacuum Logo
448 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
