Question about HP Color LaserJet 2600n Printer
HP 2600 Cartridge Jam on Right Side
I have an HP Color Laserjet 2600. All 4 toner cartridges are locked in on right side. Any solutions?
    Novelist:
  • 217 Answers
If they are locked in on the right side, the cartridge drive(s) are not being retracted when the front door is opened. There will be a broken part, which is difficut to obtain, and requires a major stripdown of the printer to find and repalace.
It can be easier and MUCH quicker to replace the whole gear assembly on the right hand side of the printer. These ARE available, and can also be removed from another printer with other faults/damage which renders that one BER.
Posted on Sep 11, 2009
Why i can not remove toner cartrigde in hp 2600
There is a cartridge lock that is linked to the transfer belt and front door. If that link breaks the locks may not disengage. Usually the jam so that you cannot insert a cartridge. Look for the white or black hooks on the left and right side of the printer cavity. You may be able to shift them up with a small screwdriver.
Sep 03, 2014 | HP Color LaserJet 2600n Printer
The printer, HP 2600, is leaving black shadow at left side of the page
Replace the black toner cartridge (Q6000A) for other and try again.
Jul 12, 2011 | HP Color LaserJet 2600n Printer
Right hand printer cartridge light is flashing - have taken it out and reinserted it, no luck, so put a new one in, still no luck. Only way I can get it to work is to take the right hand cartridge out and...
A Non-HP Toner Cartridge installed error message occurs in the following situations:
  • Non-HP cartridge is installed
  • HP cartridge is not installed correctly
  • False error
  • Sensor issue (hardware)
SOLUTION: The Non-HP Toner Cartridge installed error message could be cleared completing the following steps: All HP toner cartridges carry the Hewlett-Packard logo, and meet HP's high quality standards. 1. Verify that you are using a legitimate HP toner cartridge by going to the HP LaserJet and Color LaserJet Printers - Counterfeit Print Cartridges webpage. Click here to go to the HP LaserJet and Color LaserJet Printers - Counterfeit Print Cartridges webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl01270) . 2. Remove the toner cartridges, clean the metallic contacts by a dry linen cloth, and then reseat the toner cartridge, and check if the error occurs. To reseat the toner cartridge, see the instructions at the HP Color LaserJet 2600n Printer - Changing Print Cartridges webpage. Click here to view the HP Color LaserJet 2600n Printer - Changing Print Cartridges webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314345) . 3. If the issue persists, perform a firmware upgrade from the Download drivers and software page at www.hp.com. 4. Restore the factory defaults in order to restore the default settings: a. Use the left arrow or the right arrow button to select Service , and then press SELECT . b. Use the left arrow or the right arrow button to select Restore defaults , and then press SELECT . If the issue still persists, even after completing the troubleshooting steps provided, then use one of the following support options so that HP can work with you to resolve the issue, because it may be related to printer hardware where it needs a live interaction
Oct 26, 2010 | HP Deskjet 460c InkJet Printer
The red (magneta) color is nearly non-existent. I use an EMac. I have tried the ColorSync option when printing. I have set the utility 'density' to it's max setting. This has been a very good printer. ...
First, make sure that the toner cartridges have enough toner. The toners may be exhausted. In case the toners are ok, the printer requires servicing/ cleaning of lenses and mirrors inside the printer.
Please refer here to my earlier solution to this problem, which was very helpful for the users of Color LaserJet 2600 Series Printer.
GoodLuck!
Dont forget to appreciate the solutions if I could have been of any help!
CreativeTECH
Oct 02, 2010 | HP LaserJet 2605dn Printer
Hp 2600
It migh be that there is not toner in your cartridges. Try to print test page from windows.
Sep 23, 2009 | HP Color LaserJet 2600n Printer
Cyan is offset about 3/16"
check the locking tabs on the cartridge, sounds like they are not locking down the cartridge.
Jul 31, 2009 | HP LaserJet 3600n Printer
Hp color laserjet 2600 n it will not let me print
There is an override sequence and it works well. Press the select button (checkmark) to indicate Main menu. Press right-arrow (RA) to select System Setup. Press Select , then RA to Print Quality, Hit select. RA to Replace supplies and hit Select. Now, RA to Override Out and Select. Confirm with Select again. Your 2600n will now run even with an empty toner cartridge.
Jul 08, 2009 | HP Color LaserJet 2600n Printer
HP Q2612A Cartiridge refilling
YouTube - Toner Refill for HP Cartridges 2600, 3600, 3800 etc
Jul 08, 2009 | HP 645A Magenta Toner Cartridge (C9733A)...
HP 2600 ghosting
It is a massive pain but a solution that worked for me is to run a 'clean' after every card stock sheet. I know it's wicked awful but it actually worked and I had to run 100 times (one for each good color card stock)
First put plain paper in tray 2
Next
Hit left arrow until you get to 'system service' and press green check
Next
then go to 'clean' and press check
Now it should print a clean image without ghosting
May 29, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
419 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
