Toshiba Portege M200-S838 Tablet PC Logo
Leona Perez Posted on Apr 11, 2014
Charging battery I bought this zeepad just a couple of months ago. It was working fine. Saturday I used it to read a ebook and when the battery was dead I put it on the charger. It has been on the charger for 6 days and is only at 80 percent. It keeps going up each day but it is taking forever. What can I do to speed up the charging?
How do I turn on zeepad
Press and hold the power button until the display lights up with a symbol of some kind. If that does not work it probably needs charging or a replacement battery or servicing.
I bought 4 ZEEPAD 7DRK Rock tablets for my grand kids for Christmas and 2 of them will not even turn on. The 3rd one worked for 3 days and it also will no longer turn on. I've tried charging them...
Hi, Zeepads have an issue with powering on....when charging it is best to use the mains charging as it is more powerful....if you are sure they have been fully charged then try this:
Hold the power button down for about 2-3 minutes.
Listen for a small click.
Take finger off of power button and wait for about 30 seconds.
Hit the power button again.
Hopefully you should see the start up screen, post back with the results!
MY ZEE PAD WILL NOT CHARGE
both of my charging ports are bad , thats your problem also, we need to find a supplier for the parts so they can be fixed..
I would like to download a user manual for my ZeePad 7.0 tablet
Hello there!
just try to download from this website! good luck!
http://www.dannon.biz/ebooks-operating/operating-instructions-for-zeepad-7.0/
3helpful
3answers
How can I reboot my Zeepad?
Here are the some simple steps to hard reset your ZeePad 7.0:- 1.)First of all,Go to Settings -> Storage -> Factory Data Reset. 2.)Otherwise,Power of the device completely. 3.) Now,Hold down both volumes and power button simultaneously. 4.)After doing this,you should get an android on its back opened up or something. 5.)Now,Press both volumes at same time to open up a small blue text menu. 6.)Then use Vol - and Vol + to navigate the Recovery mode. 7.)Select "Factory Data Reset", press power, choose "yes" from the menu then press power again.
Why wont my zeepad turn on
Check the battery is charged - it may be duff and nee replaced if it is not charging or your power adaptor may not be charging it - check it with a multimeter - the power socket on laptops andf tablets are very susceptible to damage - if that fails then plug it into a pc using the usb port - it will charge very slowly as usb only has a very low charge current but be patient and if it charges up after 12 hours using the usb method you will know one way or another whether its the battery or the power socket or charger.
I have had my zeepad on the charger for a few days now and it is not fully charged. What do I need to do for it to recharge?
Probably, the ac charger unit isn't good anymore. Output charge voltage& current isn't sufficient to drive your battery charge beyond 80% threshold.
Change or replace this with a new one (same ac charger specs please) and charge your tab again.
2helpful
3answers
How to remove battery from zeepad 7.0 tablet
Hi open a zeepad is very easy, you need apply some pressure over the case and the screen. I recently open my sons tablets. regards.
Top Toshiba Tablets & eReaders Experts
k24674
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
