Question about Estate Dryers
Estate Gas Dryer Model TGDS840JQ1 It runs, but no heat. All the ducts and lint trap are clear, and there is airflow out the back- just no heat. I can't see or hear any indication of igniting. Where do I go from here?
  • 6,784 Answers
HI. Normally, the gas valve coils will be the most common problem spot in thsi situation but, i recommend inspecting the following areas as well to address this issue.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Replace any failed component.
Posted on Jun 17, 2009
My dryer says to check the lint trap
A sensor is saying ". . .airflow is blocked. . " Blockage could be the air filter or trap or ducts within the dryer or the 4" flex duct attached to the back. First, remove the 4" duct and see if there is good air flow with dryer running. If so, ream the duct all the way to the outside. If not, disassemble dryer to get to internal rigid ducting and blower. Also, make sure the blower wheel is not broken and can rotate freely.
Oct 17, 2014 | Maytag Bravos 7.0 Cu. Ft. Gas Dryer
Estate TGDS840JQ1 Gas Dryer NOT HEATING
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 20, 2010 | Estate TGDS840JQ Gas Dryer
Whirlpool gas dryer model #LGR3624EQ1. Our dryer is not producing heat. Gas line is working and the vent is clear. It has airflow through the lint trap. It also continues to run and won't shut off. ...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 24, 2010 | Dryers
Kitchen aid dryer Partial drying the cloth
First you should make sure the exhaust vent and ducting and lint trap is not clogged or restricted, birds/insect nests, or lint build up. If the dryer is heating up it is most likely an airflow issue.
Jun 05, 2010 | KitchenAid KGYS850LT Gas Dryer
The burner goes out after five minutes. I have completely cleaned the lint ducts and made sure the dryer vent is clear. There is no airflow problem. How does the dryer sense flame? Is there a high-limit...
Hello, This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis The coils are mounted to the gas safety valve, This should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Nov 04, 2009 | Estate TGDS840JQ Gas Dryer
Estate gas dryer heats up but then flame goes out after around 30 seconds. Replaced the gas valve coils and the thermal fuse, but problem continues
It's likely the problem with the airflow. High limit thermostat is turning the gas valve off. Clean/replace the vent and lint trap.Check if there is anything stuck to the grille inside the dryer.
Oct 13, 2009 | Estate TGDS840JQ Gas Dryer
Timer not working on estate model TGDS840JQ1
Try first tripping the circuit breaker for ten minutes and see if this reset the board.
Here is the part: PS394424
Check also the connector:PS345626
Here all diagrams for your appliance.
Parts must be tested before replacement.
May 07, 2009 | Estate TGDX640JQ Gas Dryer
DRYER RUNS GAS HEAT STARTS BUT THAN TURN OFF
Solenoids inside the dryer base at gas valves is most likely the problem. Let me know, Sea Breeze
Mar 19, 2009 | Whirlpool LGR5636L Gas Dryer
Dryer not drying clothes very well
Is the dryer getting hot? Is the airflow coming out of the exhaust strong? If the airflow is good, but not hot, the problem is most likely a thermal limit sensor.(These sensors determine the air temperature, and cycle the heat source) If the airflow is not forceful, but the vent hose, exhaust vent, and lint trap are clear, then the blower/fan may be encrusted with lint, or broken. The sensors and blower can be difficult to get to, for cleaning or replacement, but possible. It depends on your skill level. Remember to always disconnect the power when attempting a repair on any electrical device!
Dec 02, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Excess dryer lint
It is strongly recommended that you DON'T trap the lint. Doing so, can cause the lint to back up inside the ducting and eventually cause longer dry times on your clothing, and/or your heating circuits to over heat and fail. A dryer requires proper (unobstructed) air flow in order to work efficiently. I would recommend that you reroute your dryer ducting to divert the exhaust away from your pool pump. Please let me know if you require further assistance.
Jul 24, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
401 people viewed this question
Top Estate Dryers Experts
Tim Whalen
Mike
John Tripp
John Tripp
Are you an Estate Dryer Expert? Answer questions, earn points and help others
