Question about Sharp VL-PD1U Camcorder
Sharp VL-PD1 playback is pixelated (mosaic) from DV port
When i connect the camcorder to the DV port and connect via firewire the playback is garbled or heavily mosaiced/pixelated this is not present on the view finder or the LCD screen as the playback is crystal clear there. Its only when i connect to the DV port i get a screen full of pixels, you can make out what is happening but the blocks are offset and it looks as if its interlaced somehow. I also have the JVC GR-D21EK which hooks up %100 ok to the dv port so its not a computer thing. Could it be a software thing as i can still control the sharps playback rewind etc but can view the pictures properly. Thanks Spencer
2 Suggested Answers
SOURCE: Playback on Sharp VL-PD1
I would like to buy an original charger for my digital camera VL-PD1 (second hand), ore new.
You can contact me on my email adress
walid: vi_ibrahim@hotmail.com
Posted on Oct 28, 2009
How can i download the contents of my mini tape onto the pc ?
you don't convert the files, you just downlod them via a firewire comnnection.
If you have a mini dv (cassette) camcorder....
Your dv camcorder needs a firewire connection (ieee 1394) in order to download video, your PC probably did not come with a firewire port, so you will have to buy one and install it, since most computers (except possibly brand new) don't come with a firewire port, your camcorder did not come with a firewire cord so you have to purchase a cord too. Your camcorder did come with a USB cord and that is used for downloading stills from your camcorder. Make sure your camera is in playback mode.
Open your editing program and choose the capture mode.
The fine print in your manual makes reference to firewire (ieee 1394) connection....
thanks.
Apr 11, 2011 | Cameras
I need the part # that will allow me to connect my Sharp Viewcam Z VL-Z1 to my computer to download video. Please help.
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection for stills (if they have one) and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card.
Suitable Firewire (DV) cables can usually be found on Amazon or eBay. Try a search on your camera model number. Most cameras need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other.
Nov 16, 2010 | Sharp Viewcam VL-Z1 Mini DV Digital...
I want to transfer my videos taken on my Sharp
You will need a firewire cable and a firewire port on your computer. If you don't have such a port then you can buy a firewire pci card.
See this for info and pictures
http://en.wikipedia.org/wiki/IEEE_1394_interface
Feb 07, 2010 | Sharp Viewcam VL-Z1H Mini DV Digital...
I want to connect my viewcam VL-Z3 to my latop, but I dont have a driver to support it. Can you help?
I had this problem too.
I searched the web high and low. Even wasted 2.99 on what claimed was the driver but turned out to only be instalation directions.
From what I understand, Sharp no longer supports camcorders, so obtaining the dirver from them is out of the question.
Connecting your camcorder to your computer via USB is only used to transfer photos from your SD on your camcorder. You cannot transfer video via this method.
Here`s what I did to solve the problem of not having the driver.
I got a $10 SD card reader for my computer and this solved the problem.
To transfer video from your VL-Z3U to your computer, all you need is a firewire cable .
Assuming that you have a firewire port on your computer, simply connect your camcorder to your computer via firewire, power up your camcorder and your computer should automaticly recognize your device.
You can now transfer video to your computer using your normal video capture/editing software.
Hope this helps
Aug 07, 2009 | Sharp Viewcam VL-Z3U Mini DV Digital...
Viewcam Z VL-Z100
You may need what's called a 'firewire' port, which was the transfer port of choice for most DV models of the time.
My contact at the local RadioShack advised me that a DV-to-USB cable might work to allow transfers since firewire isn't really supported these days. I've not tested it myself though. The cable should cost less than $20.00... and if you're careful with the packaging, you could always return it if it proves useless.
HOWEVER, this is what you may need to allow correct transfer from the cam to the laptop:
http://www.amazon.com/Sabrent-SBT-PCA4-Firewire-CardBus-Adapter/dp/B0007UY662/ref=sr_1_7?ie=UTF8&s=electronics&qid=1252477568&sr=8-7
Check, first, to make sure that the pc-end of the cable is, in fact, a firewire connector.
Jul 20, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
SHARP Viewcam z vl-Z500H-S Camcorder
To transfer video you need to use firewire, not usb. If you use firewire to connect, set the camera to the 'play' icon and then open up a capture program (ie, movie maker) you should be able to just record/capture from there. Good luck!
Jun 17, 2008 | Sharp VL-Z500H Mini DV Digital Camcorder
Help!! Can not connect my Sharp ViewCam Z VL-Z3U Through FireWire
Try searching these posts to see if they will help your problem. Seems this is common. See the link below.
http://www.fixya.com/tags/VL_Z3U
Mar 26, 2008 | Sharp Viewcam VL-Z3U Mini DV Digital...
How to get video onto a pc
use your cd to install the drivers onto your computer. Connect camera via usb and use the pixel software that came with your camera or you can use Windows Movie Maker to download your recordings.
Mar 09, 2008 | Sharp VL-Z500H Mini DV Digital Camcorder
Nov 01, 2007 | Sharp VL-PD1U Camcorder
Sharp VL-PD1U Camcorder Logo
91 people viewed this question
Top Sharp Video Cameras Experts
NOEL
NOEL
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
