Question about HP LaserJet 3000 Printer
NO YELLOW ON MAGENTA ON PRINTOUT
I HAVE REPLACED YELLOW AND MAGENTA TONER AND INSTALLED NEW TRANSFER BELT.
STILL NO YELLOW OR MAGENTA ON PRINTOUT.
WHEN PRINTING TROUBLESHOOTING PADE ON SOLID CLOUR THERE IS NO YELOW AND MAGENTA SLIGHTLY THERE
ANY IDEAS?
    Problem Solver:
  • 10 Answers
Your printer's gear box time seting is not in its place so you dont have the right colors
Posted on Jun 23, 2009
Sp c821dn printer displays "out of toner" magenta message even when magenta toner is replaced with new one.
is their toner in the new cartridge installed? if not you have to refill the magenta cartridge and do the calibration of the printer
Apr 07, 2017 | Magenta Office Equipment & Supplies
I have a LexMark C752L. when i go to print first thing in the morning i get a 3/4" verticle stripe on the right hand side of the page. With each page i print this stripe gets less noticable until it...
Based on your description I would assume this has something to do with the Transfer belt, where in the cleaning blade of the belt is already worn or defective.
You may need to replace the printers transfer belt unit.
For further diagnosis and assistance, please contact Lexmark Technical Support.
Regards!
Sep 22, 2011 | Lexmark C752 Printer
Excess cyan toner is on electrostatic transfer sheet even after wiping it. All black and white pages are printed with cyan background.I am even using original cartridges.
Since you have Cyan toner in places where it should not be then the only possible cause is a defective Cyan Toner cartridge. I worked on one just last week where the customer complained about Magenta toner on their prints. I also noticed Magenta toner on the Transfer Belt just as you see Cyan toner on the Transfer Belt. I replaced the Magenta Toner Cartridge and everything cleared up nicely. The Transfer Belt Unit can also cause similar problems but it would not be ONLY one color like Cyan. It would be a mixture of all colors. My bet is replace the Cyan toner and you will be fine. If you have an old empty one just shake it up a bit and try it as well. This might allow you to verify before buying a new cartridge.
Good Luck and Thank You for using Fixya.
Wheatland Services
Feb 06, 2011 | HP Color LaserJet 2600n Printer
Hi Everytning I print has a very narrow pink line straight down the centre of the page, also every so often the print has a black/yellow/blue/pink thick line running across the page. Thanks
The narrow pink line is coming from your magenta toner/drum cartridge. You may be able to open the from cover and look at the 4 toners. If you look at the magenta (like pink) cartridge, you might see the thin line on the drum surface.
The multicolored band that sometimes shows up on your prints is most likely the transfer belt unit. This is caused by an area of the belt that is not being cleaned very well. This probably tends to show up when you are running mutilple prints of a page.
So it looks like to may need to replace your magenta toner and look at getting a transfer belt unit.
May 13, 2010 | HP Color LaserJet 2600n Printer
I have a HP color laserjet 4650dn that when you print a document, there are pink spots all throughout the document. Is this due to replacing the fuser or transfer bar? There are no warning indications on...
It depends on the true color of the spots. If what you describe as pink are actually Magenta colored spots then I would suspect the Magenta toner/drum cartridge. It is definately not the fuser. The transfer bar or actually transfer belt unit in this case is doubtful to be the cause. A defect in the tranfer belt unit does not normally show up as 1 color. It is usally multiple colors. I would open the front cover and at least visually inspect the Magenta toner cartridge. If you have a spare unit, even an old one to swap it out with even better. Look at the color of the Magenta toner and compare it to the spots you are seeing. If they are similar then in my opinion the problem is in the Magenta drum unit.
Apr 21, 2010 | HP Color LaserJet 4650DTN Printer
Getting green stripe across top of prints
this printer uses leds to charge drums. if you lift top cover you will see 4 black windows ( 1 above each drum) make sure they do not have toner on them. green usually means you have some toner on the magenta led which causes missing magenta (yellow and blue make green) if it is on black and white prints it could be something else like a pile of toner under transfer belt (which you can pull out, after you take out drums) check the leds first
Aug 04, 2009 | OKI C5200n Laser Printer
Oki 5150 color are not print right
You need to replace the magenta drum. Just because there is life left; it's possible it is scratched. Also, take a cotton ball dip in alcohol and wipe the LED's off when the cover is open; those black things that are hanging down from the cover. Also, make sure your drums are installed in the proper spots (magenta in magenta slot). If the toner "rubs off" after it prints... then the fuser is defective.
Jun 25, 2009 | OKI C5150n Led Printer
Deteriorating image quality
Good Evening Robert,
The setting for non dell toner only controls the fuser temperature, and will not cause you any print quality issues. Toner is actually made up of ink and plastic. The fuser melts the plastic to "fuse" the image to the paper. Dell toner is set to "fuse" at a specific temperature. when you use non Dell toners, the temperature required to fuse may be different, and when set to non dell toner setting, the fuser temperature is raised to the maximum to ensure the other toner fuses properly. The down side to this is that you will wear out the fuser sooner then it should.
As far as the print quality issue you are having, it is most likey caused by the imaging drum.
Regardless of the estimated life for the imaging drum as stated by the printer, this is just an estimate. Many things can and will cause the imaging drum need replacing. ( Just yesterday I replaced a black toner in a 3115 that was less then a month old... genuine Dell... with more then 75% expected usage left because it was defective).
On this printer, each of the 3 colors and the black are all independent of each other with the exception of the imaging drum. Even within the imaging drum, cyan and black are independent of magenta and yellow on the first stage of transfer. When you have deteriorated print quality that effects more then one color, the first step is to replace the imaging drum.
The Primary transfer, secondary transfer, and tertiary transfer of the image are ALL contained within the imaging drum.
The chances of having 3 or 4 bad Developers is very very slim. If your print quality issue was related to only ONE color, then I would say you had a bad developer unit ( the 4 items located behind the imaging drum when removed). These are far more difficult and expensive to change.
The BTR ( bios transfer roller ) is the only other item that "could" effect your print quality, however, based on the symptoms you discribed, I doubt it. Besides, if i am not mistaken, the imaging drum kit comes with a new btr anyway.
Although I am sure you may be disappointed with the fact the drum unit is failing while showing it still has life remaining, the solution to replace it should restore your unit to full operation. The unit is light sensative, and effected by physical age as well as the number of prints it has supplied.
Please evaluate the solution i have provided and, rate the solution appropriately to show your support.
Thanks,
Cory
Oct 11, 2008 | Dell 5100cn Laser Printer
Samsung CLP-550 - magenta bands
I have the same problem. Any solution?
Dec 19, 2006 | Samsung CLP-500 Laser Printer
HP LaserJet 3000 Printer Logo
173 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
