Question about Toshiba Satellite A200-0ET00X Notebook
My toshiba A200 screen occasionally turns black and music also stops. When i try manually restarting my laptop, sometimes it works but most of the time it doesnt boot at all. Sometimes it doesnt even go into the Toshiba screen and stays black. The power light is on but when it stays black, the 4th light wont turn on either.
  • li_felix162 Jun 19, 2009
    Well i've had the laptop for more than two years. And yes i do tend to leave the laptop on. Theres no beep noises or any error messages, it jus turns black. I don't think its been overheated but i cant be sure. I'll try replacing the hard drive thanks.
    Scholar:
  • 74 Answers
This sounds like a hard drive is, or has failed. Either that or the RAM (memory has gone bad)
Did you let the laptop overheat? Was it left on for a long time? Or is this just an old machine ?
I would replace the hard drive, and reload the operating system, that is if you really want to keep the laptop. If that solves it great! Also, did you notice if there are any "beep" noises, or error messages when it acts up? Often times, you can go on the internet and find out what the messages mean.
Posted on Jun 19, 2009
Toshiba equim has ablack screen
Assuming the laptop IS running at least the POST tests:-
1. Try shining a torch into the screen t see if you can see any figures or characters. If so, your backlight is defective.
2. Try connecting an external monitor via the 15 pin D-type connector usually found on most laptops. If it works, get into the BIOS to check he BOOT SCREEN setting is set to LAPTOP LCD or LCD+EXT. If the LCD is dark in any case it could be the graphics chip OR the LCD is faulty.
Sep 21, 2014 | Toshiba Equium A200 Series Satellite A205...
Toshiba Satellite A200 - Logging In
Please restart in the safe mode once.And run a virus scan after that turn off your laptop and turn it on again now don't go into the safe mode just start the windows normally,enter your password and see if you face the same problem.
Jun 24, 2008 | Toshiba Satellite A200-0ET00X Notebook
Toshiba Satellite Pro A200 BIOS Password Request
for removing the password,
you have to open the memory cover and remove the two RAM s,
after that remove a black or whit plastic film depending on your model, you will loacte for B500 marqued ( XXX ) or J1 you have at least short
the two point with a flat screwdriver and put the upper memory and power on the laptop will holding the screew driver till you see the toshiba screen, if it doen't work just try again. it works 100%
Jun 15, 2010 | Toshiba Satellite Pro A200-EZ2204X...
I have a Toshiba A200 and the screen is completely
Sounds like the screen is faulty I would check the screen connection to make sure its not lose but I would say the screen is almost gone.
You may need to replace it.
Feb 25, 2010 | Toshiba Satellite A200-19501F Notebook
I have got a Toshiba Equium A200 series that won't bootup
if the fan is not running continuously then its the fan ans board problem.because the board is getting hot and fan is not running so the board is getting overheated and the machine is nor working.and if the power light is ON and fan is running but only the screen is black/blank then its the problem of inverterboard.the cost of new board is $25 get it replaced fromn near by laptop repair center. thanks.
Aug 30, 2009 | Computers & Internet
INITIAL SETUP PASSWORD-TOSHIBA SATELLITE A200
try checking out this link
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=1702271&rpn=PSAF0U&modelFilter=A200-ST2041&selCategory=3&selFamily=1073768663
this will resolve the issue. the good news is they are aware of it. the bad news. you gotta send in your unit to be serviced.
Good Luck!
Ruben
Jul 23, 2009 | Toshiba Satellite 2410-S203 Notebook
Toshiba A200 Notebook Computer Screen Black Out
LCD monitor work based on backlight illumination, they have a fluorescent tube of high intensity usually located at the bottom ot top of the monitor sometimes they may even have two of these one on each side or on top and on the bottom of the screen, this tubes illuminate the screen from the side into the LCD device. The lights are powered by a high voltage switching power supply. A number of things may happen that can cause the symptons you are experiencing. You may have a bad high voltage power supply (locvated inside the laptop body or sometimes depending on the model inside the actual LCD lid.), you may also have a bad light tube or a bad flat cable that connects from the power supply to the LCD lid. Usually is not worth to pay for a repait like this as it is time consuming to dissasemble the whoel laptop to fix or replace any of the components involved in this. If you want a fast and cheaper solution, get a cheap LCD monitor and conenct it to the external RGB port of yoru laptop if you want to keep using it. Otherwise look for replacement parts online for the light tube, power supply assembly and cabling then get somebody to replace them for you.
Jun 02, 2009 | Toshiba Satellite A200-0ET00X Notebook
Toshiba Satellite A200-0ET00X Notebook Logo
262 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
