Question about Bissell 1425 Little Green ProHeat Handheld Steam Vacuum
WILL NOT SPRAY
THE BISSELL LITTLE GREEN MACHINE WILL NOT SPRAYSOLUTION. i CLEANED THE LINES AND STILL DOES NOT WORK.THE MOTOR RUNS BUT NOTHING HAPPENS WHEN I TRY AND SPRAY THE SOLUTION. RENE'E
  • Marvin
    Marvin May 11, 2010
    check the linkage from the spray button to the valve.
  • 17 Answers
Here is what to do
Posted on Feb 09, 2010
I just tried the video above, but it was a bit overkill for my problem. I don't use my unit very often, so I doubted there would be build up in my heating mechanism. Turns out the blockage was in the tube, right before the switch in the handle. If I were to do it over again - I would take apart the handle, unplug from the handle switch the tube coming from the unit, then turn the machine on. I bet it will spray out a bunch of the gunk. Then reattach the tube and it should work. If that doesn't work, check the line running through the unit - look for a big clump of debris blocking the tube. Check the water switch in the handle and the tube on the far side of the switch on the handle - where the water actually sprays out of. If water runs through those parts fine, then they are clear and the blockage is elsewhere. If that doesn't work, then try taking apart the heater (I have the newer version of the green machine - it's white with clear green plastic water holders. The heating mechanism is in a different place, easy enough to find if you unscrew the main body. Look for the rectangular black box - that's it. Good luck!)
Before you take that whole mechanism apart, first take apart the handle unplugging the
Posted on Apr 02, 2010
I purchased a Bissell big green carpet cleaner. I have only used it twice but the flow indicator has stopped showing any flow. I am assuming because there appears to be no flow. What do I do? HELP!!
Try putting vinegar white and water 50 50 in tank and try to spray let it sit overnight try again if nothing happens the Selinoid is stuck dalways rinse these machines after use and only use bissell oxy clean
May 30, 2018 | Bissell Vacuums
How can I download Bissell Little Green Clean Machine manual?
direct
https://canada.bissell.com/support
or the first link has it, also videos
  • BISSELL LITTLE GREEN 1400 SERIES USER MANUAL Pdf ...
    www.manualslib.com > ... > Vacuum Cleaner > Little Green 1400 SERIES
    Bissell LITTLE GREEN 1400 SERIES User Manual. ... Vacuum Cleaner Bissell Little Green 1400 SERIES User ... Rcvd a used bissell little green machine w stagnant ...
  • Bissell Little Green Machine ' Walmart.ca
    www.walmart.ca > Walmart.ca > Appliances > Vacuums > Steamers
    • 4.1/5
    • 185 REVIEWS
    • $99.96
    Bissell Little Green Machine for sale at Walmart Canada. ... Powerful suction lifts stains and spots with water or any of the Bissell cleaning solutions.
  • Little Green® Portable Carpet Cleaner ' BISSELL®
    www.bissell.com > ... > Browse By Type > Carpet Cleaners > Portable
    The Little Green® portable carpet cleaner is produced with a minimum of 50 ... Coupon code for purchases on bissell.com: ... (including all accessories and manuals) ...
  • BISSELL LITTLE GREEN CLEAN MACHINE PDF - fenbook.me
    fenbook.me/get-it-free/b/bissell-little-green-clean-machine-manual.pdf · PDF file
    Get Free Read Online Ebook PDF Bissell Little Green Clean Machine at our Ebook Library. Get Bissell Little Green Clean Machine PDF file for free from our online library
  • Bissell Little Green Owners Manual ; Bissell Little Green ...
    www.youtube.com/watch?v=PpQji8obNz4
    • BY BOTHSHOOP
    • 4 MIN
    • 11K VIEWS
    2012-11-07 · Video embedded · Bissell Little Green Owners Manual ; ... Bissell Little Green Owners Manual ; Bissell Little Green Machine ... How to fix a Bissell Carpet
  • Bissell LITTLE GREEN 1400 SERIES User Manual
    May 24, 2016 | Bissell Vacuums
    Little green machine will not spray cleaner
    Have you checked the tiny hole that the spray comes out of. I have one and sometimes it becomes clogged. I take a small needle and run it thru it.
    Oct 09, 2014 | Bissell THE BISSELL LITTLE GREEN MACHINE...
    Bissell big green clean machine extention hose not spraying
    Hey, sorry you're having difficulty with the spray on the hose.
    Here's a quick link to troubleshooting steps to assist you:
    http://www.bissell.com/FAQDetail.aspx?id=23646&cid=ccsocial
    Feb 28, 2013 | Bissell Big Green Deep Cleaning Machine...
    Won't spray solution
    if its not spraying solution there are two possible problems,
    1. the solution carrying line that runs from the unit along inside the hose could be blocked.
    2.there mite be a clog somewhere inside the solution tank or leading from the solution tank
    Sep 19, 2012 | Bissell THE BISSELL LITTLE GREEN MACHINE...
    Little green machine will not spray. Can I fix it?
    yes according to the model you have look up a schematic on line and take it apart you will see the pump assy the pump # is 6035029 this can be purchased on line i got mine at VacParts Warehouse.com think it was about 14 or 15$
    Sep 11, 2010 | Bissell THE BISSELL LITTLE GREEN MACHINE...
    Biseell little green machine wont squirt water out
    The Pumps on these go bad after a couple of months. They rust and will sometimes spray and other times not then eventually not work at all. If your a handy man pull the top off it and remove the pump motor and replace it yourself. The part number is 603-5029 you can put this number in google shipping and get it to your door for about $15 and replace it yourself or have a friend do it. Ebay has tons of them once again just put in the part number and a list of them will come up.
    Thanks and have a good one
    Sincerely, CRTN
    May 22, 2010 | Bissell THE BISSELL LITTLE GREEN MACHINE...
    I think the pump needs to be replaced in my Bissell little green machine. Some water/solution is being pushed through but not enough to spray only drip, if I hold the machine up high while using it (ie on...
    I got my Little Green ProHeat when the product was first unveiled several years ago. Shortly thereafter, the nozzle itself developed a clog in the spray jet. Remove the nozzle from the end of the hose, and with the machine running pull the trigger. If a great amount of solution comes out of the supply hole, then your nozzle is clogged. You can try clearing it with a very thin pin and then rinsing it out.
    In about 6 months, my pump would no longer spray solution at all but I could hear the tiny pump still running inside the machine when I would pull the trigger. Remove the tanks, unplug the unit, and look carefully and you will see the few screws holding the unit together. Pull it apart carefully and don't use much force as some of it snaps together and you don't want to break those tabs. Once open, you can find the solution pump, a little fella. The drive shaft on the motor that spins the pump had rusted away completely! Design flaw. In lieu of getting it repaired, I simply started using a spray bottle for my solution application. Several years later and I'm ready to take the time to replace the pump - a very simple process. From the research I've done, the part number for the solution pump is:
    Manufacturer's Part Number: 6035029
    If you google search "Bissell 6035029 VacPartsWarehouse" without the quotes, you should find your part there for around $9.
    Try this direct link to VacPartsWarehouse's website:
    VacPartsWarehouse Bissell 1425-2 Little Green ProHeat
    Click item #9. It's very simple to install. If you can wield a philips screwdriver, and pay attention to how you've disassembled the unit and then just reverse the steps, you can fix this yourself on the cheap.
    Good luck! :)
    Dan
    May 29, 2009 | Bissell 1400 Little Green Pro Canister...
    My Bissell Little Green won't spray the solution. The suction seems to be working fine and the lines are all connected as they should be. What's up and how can I fix it?
    I also had the same problem as you.
    Try suctioning up a full tank of hot tap water into the collection tank to soften/release a possible kink in the tubing inside of the vacuum hose that carries solution out to the spray tip.
    I did this a couple of times and it worked. This info I found on the Bissell website.
    Good Luck!
    Aug 15, 2008 | Bissell 1425 Little Green ProHeat Handheld...
    Bissel Little Green Spray Motor
    Motor was seized. Probably from lack of use combined with the moisture involved with such a device. I loosened the motor with a pliers, gave it a small shot of wd-40, and off we go. Works fine.
    Mar 09, 2008 | Bissell Vacuums
    Bissell 1425 Little Green ProHeat Handheld Steam Vacuum Logo
    1,653 people viewed this question
    Top Bissell Vacuums Experts
    Jim Parker
    Jim Parker
    Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
