Question about Sanyo DP42848 LCD TV
8 1/2 month old TV went out.
We had lightning strike near out home last Friday (6-12-09). My Sanyo LCD TV, Direct TV, and DVD player were all on a surge protector. The TV went out. It will come on for just a second and then turns inself off. It stay a black screen. I paid $942.95 for this TV on 9-24-08. The serial number is: B8220943223391 Model number is: DP42848.
It is still under warranty, how do I get my TV fixed?
  • qrwebb Jun 18, 2009
    They will only take it back if it is under 90 days.
  • 4 Answers
Lightning damage is not a covered repair by any mfg warranty item. If you bought it at Walmart of Sams, and if you purchased the extended warranty, The extended warranty will pick it up and cover the repair. Hope this helps. Lee
Posted on May 08, 2010
  • 52 Answers
Take it back to where you bought it if it's still under warranty, they are obliged to fix it!
Posted on Jun 17, 2009
Sanyo AVM-3651G fuse box?
Should be on the board near where the power cord connects. It should be a fuse with pigtails that is soldered to the board. If you had a true lightning strike then the power diodes are probably shot ad well and more than likely the power transistor.
Aug 16, 2016 | Sanyo Televison & Video
How do I get my TV out of standby mode
The main board to your TV should be checked. Contact any service technician. Faults occurred due to lightning is not predictable to any body. In most cases, the main board might need replacement. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 21, 2014 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
MY SANYO LCD TV MODEL 24 K 50 WAS OFF WHEN LIGHTNING STRUCK NEAR OUR HOUSE AND SINCE THEN IT DOES NOT TURN ON
Replace or have the powrer supply tested and eventually serviced.
Lightning strikes affect two types of boards in televisions - the power supply by means of entering through the AC line and main boards by means of entering from the external signal sources. External antennas are worst and can totally toast the main board whereas a signal entering through HDMI cable from another device is less likely to be affected by a power surge.
So naturally you start your quest with the power board , which is the usual suspect.
As of right now I do not believe we have an announced service for the power supply board of Sanyo LCD-24K50, but if you do not have any other options you can always try and send the power board for examination/repair through
http://www.coppelltvrepair.com/newservice.
Sep 29, 2013 | Sanyo 42 in. LCD TV
Sony Bravia KDL-46S5100 There was a lightning strike and we lost power for a few minutes. When power came back on the only thing we have is a black screen and no sound. Is there something on our tv that...
Your Sony Bravia KDL-46S5100 might have been affected and damaged by the lightning strike. You cannot fix it without the help of qualified technician. It must be brought to your nearest service center.
Nov 03, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sanyo dp32648 possible lighting strike, whats needed to fix and a possible cost an can i repair myself?
It wont turn on? Well if it is damaged by lightning the only thing damaged would be the varactors on the power supply. They are there to absorb tremendous surge of electricity. The same way a surge protector works. A worse case scenario is the power supply board is fried up. Then being a non electronic technician you can purchase the whole board or order on line and install them yourself. If you brought it to a shop they will charged you for the labor and the board. Don't buy used boards on the internet because a lot of them are no good in my own experience. Get a new one for about a little over a hundred buck or so.
Jun 26, 2010 | Sanyo DP32648 32 in. LCD TV
No picture onTV screen only audio after lightning
May be your picture tube got damaged in that lightning. This may be an effect of the magnetization of the picture tube due to a huge electric current passing near it. Try demagnetizing the tube and if it doesn't work get it replaced. Try having a properly working tube of an older television as modern picture tubes lack quality.
Apr 17, 2010 | Televison & Video
Have direct TV, need to hook up sanyo tv to a panasonic DVD.
leave direct tv cables where they are, and hook up dvd player directly to tv (do not hook up dvd player to direct tv box, it will not work)
Mar 15, 2009 | Sanyo Televison & Video
Have a Toshiba MW24F11 combo tv. Near lightning strike through surge suppressor. Will not turn on. 6.3 amp fuse blown; replace, blew again. Next step, or start looking for replacement. Set is 25...
power surges generally damage diodes and capacitors causing the fuse to blow, any reputable tv shop can repair for a fraction of replacing this set.
Sep 15, 2008 | Televison & Video
Sanyo DVD Home Theater System DC-TS760
Change the TV.
I had same problem since 3 years after moving from dubai to bucharest i believed that my home theater was damaged during transportation. I tryed all repair shops in my area but no luck, so i used it as a simple mp3 player at home.
Last week, after 3 years, i changed my old CRT tv with an LG LS3000 lcd tv and SURPRISE...my dvd have colours again.
Jan 09, 2008 | Sanyo DVW-5000 DVD Player/VCR
Sanyo DP42848 LCD TV Logo
607 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
