Question about Scythe Answer Carbon Bmx Pro Cruiser Fork 24"
2008 1 1/8 answer scythe
Hi ive got a set of 08 answer scythe carbon forks for a cruiser 1 1/8 how much weight can they take thanks craig
    Problem Solver:
  • 7 Answers
What is fork oil capacity
This is the answer by LostReader that I've found in Google:
I'm fairly certain the stock is 7.5 weight oil.
If starting fresh you'll need almost a quart for each fork, the correct amount isn't determined by volume, it's determined by measurement.
60 mm from the top, spacer installed, fork fully compressed. Or was that with spring installed....? maybe someone can confirm....
you need one of these to correctly measure fork oil.
http://www.motionpro.com/motorcycle/partno/08-0121/
On ebay you can get a service manual for cheap from a Canadian seller who ships worldwide.
cheers
Jul 10, 2015 | Motorcycles
HOW I CAN LET MY YUKON FX 2013 LIGHTER ?
Hi Vicente,
Lots of things to consider, but keep in mind that this will be expensive, every gram you shave off will add a dollar or more...
  1. Your best investment would be in a lighter wheelset, because here not only pure weight but also rotational weight counts against you. You can go for lighter rims, as well as tyres, but don't skimp to much on tyres that is too thin, otherwise you could get sidewall cuts.
  2. Next, consider your seatpost, stem and handle bars, you might consider carbon components for these.
  3. Front fork/shock can add al lot of weight, look for a air shock.
  4. Lastly, pedals and crankset, probably your heaviest components, look for hollow tech or carbon cranks, lighter pedals.
Look for options and compare prices on sites like these:
Components Chain Reaction Cycles
This air fork has kashima coating and a thru axle, the best option.
This XTR crank has hollow tech hollow crank arms to save weight:
For even more weight savings, consider a carbon crank, like this with only one chainring in front, this limits your gears, but you save the weight of the other chainrings as well as the front selector and cabling.
So there you have some things to consider, but the ultimate would be a carbon fame as well!
Sep 23, 2013 | Giant Yukon FX
Fork oil weight
Hi, Anonymous sorry you can't find the first and best tool you ever bought for your Ducati despair not, for a mere $17 you can download another one. For more information about your issue and free valuable downloads that you will need please visit the websites below. Good luck and have a nice day.
Front Forks Internals Update
hlins High Perferformace 1Liter Fork Oil Ducati Diavel Carbon 2011 Quick...
DOWNLOAD 2011 Ducati Diavel Carbon
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Aug 15, 2013 | 2011 Ducati Diavel Carbon
Boss hoss 350 2001 forks leaking oil how to brake down to fix to replace seal or packing
Hi, Anonymous I am sorry you can't find the first and best tool you ever bought for your Boss Hoss but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
Motorcycle Fork Seal Change Part 1 of 2 Cartridge Type
Fork Seal Replacement Part 1 of 2 Twin Chamber Style Forks
http://antakesuma.xyz/fds/b/boss-hoss-bhc-3-ls2-2008-custom-cruiser-v8-automatic-repair-manual.pdf
https://www.bosshoss.com/parts.asp
Boss Hoss Cycles Contact Us
Jun 13, 2013 | Boss Hoss BHC 355 Motorcycles
I have a 08 Hyosung gt250r, i wanna know if i could lower it?
yes you can,but it needs to be done by a professional for your size and weight if you drop the front or rear it changes the way it handles and not for the good,you need to change the internals in the forks,and then for the back shock needs to be altered inside as well as the mountings.if it is too hi to put your feet on the ground it might help by lowering the foam in the seat could be a lot cheaper cheers hope this helps
Jun 19, 2011 | 2008 Hyosung GT250R
Carbon build up in a 08 pt cruiser with 50000 miles
they make a product called lucas fuel injection cleaner that is poured into the gas tank to clean the valves, and help to remove carbon from the cylinders, it works very well, you can purchase this at auto part stores.
Mar 17, 2011 | 2008 Chrysler Pt Cruiser
WHAT WEIGHT FORK OIL DOES 2006 FJR1300 YAMAHA TAKE?
Hi, Buddys7007 for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "Free" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Fork oil weight
Correct fork oil for 2008 Parts and Accessories
Yamaha 2006 FJR1300A Service Manual
OEM parts for Yamaha
https://www.yamahamotorsports.com/assets/service/manuals/2008/LIT-11626-21-63_FJR1300A_1543.pdf
Feb 05, 2011 | 2006 Yamaha FJR 1300 A
How can I add air to my 2008 Fox van 36 rc2 fork?
http://www.foxracingshox.com/fox_tech_center/owners_manuals/08/eng/2008_om_eng.htm
This will get you directly to the interactive tech manual that explains how to set all aspects of your fork.
Nice ride by the way.
Have fun.
Nov 16, 2010 | Fox Racing Shox Fox 36 VAN RC2 Mountain...
Need setting for 450 sx 08 forks and shock im 16st junor rider
what is that your looking for?? need to know alittle more before i can point you towards your answer
Feb 21, 2010 | 2008 KTM 450 SX-F
Scythe Answer  Carbon Bmx Pro Cruiser Fork 24" Logo
171 people viewed this question
Top Scythe Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Scythe Cycling Expert? Answer questions, earn points and help others
